BY25Q80BSTIG(R)
BY25Q80BSTIG(R)
    BOYAMICRO(博雅)
    SOP-8
    8M BIT 串行接口闪存
BY25Q80BSTIG(R) 数据手册
Boya Microelectronics Memory Series BY25Q80BS 8M BIT SPI NOR FLASH Features ● Serial Peripheral Interface - Standard SPI: SCLK, /CS, SI, SO, /WP, /HOLD - Dual SPI: SCLK, /CS, IO0, IO1, /WP, /HOLD - Quad SPI: SCLK, /CS, IO0, IO1, IO2, IO3 - QPI: SCLK, /CS, IO0, IO1, IO2, IO3 ● Read - Normal Read (Serial): 55MHz clock rate - Fast Read (Serial): 108MHz clock rate with 30PF load - Dual I/O data transfer up to 216Mbits/S - Quad I/O data transfer up to 432Mbits/S - Allows XIP (execute in place) Operation: Continuous Read with 8/16/32/64-byte Wrap ● Program - Serial-input Page Program up to 256bytes - Program Suspend and Resume ● Erase - Block erase (64/32 KB) - Sector erase (4 KB) - Chip erase - Erase Suspend and Resume ● Program/Erase Speed - Page Program time: 0.6ms typical - Sector Erase time: 50ms typical - Block Erase time: 0.15/0.25s typical - Chip Erase time: 4s typical ● Flexible Architecture - Sector of 4K-byte - Block of 32/64K-byte ● Low Power Consumption - 20mA maximum active current - 5uA maximum power down current ● Software/Hardware Write Protection - 3x256-Byte Security Registers with OTP Locks - Discoverable Parameters (SFDP) register - Enable/Disable protection with WP Pin - Write protect all/portion of memory via software - Top or Bottom, Sector or Block selection ● Single Supply Voltage - Full voltage range: 2.7~3.6V ● Temperature Range - Commercial (0℃ to +70℃) - Industrial (-40℃ to +85℃) - Industrial (-40℃ to +105℃) ● Cycling Endurance/Data Retention - Typical 100k Program-Erase cycles on any sector - Typical 20-year data retention Apr 2021 Rev 2.1 1 / 81 Contents BY25Q80BS Contents 1. Description...................................................................................... 4 2. Signal Description .......................................................................... 6 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 Input/Output Summary.................................................................................. 6 Chip Select (/CS)........................................................................................... 6 Serial Clock (SCLK) ..................................................................................... 6 Serial Input (SI)/IO0...................................................................................... 6 Serial Data Output (SO)/IO1 ......................................................................... 7 Write Protect (/WP)/IO2 ............................................................................... 7 HOLD (/HOLD)/IO3..................................................................................... 7 VCC Power Supply ....................................................................................... 8 VSS Ground .................................................................................................. 8 3. Block/Sector Addresses ................................................................. 9 4. SPI Operation ............................................................................... 10 4.1 4.2 4.3 4.4 Standard SPI Instructions ............................................................................ 10 Dual SPI Instructions .................................................................................. 10 Quad SPI Instructions.................................................................................. 10 QPI Instructions........................................................................................... 10 5. Operation Features ...................................................................... 11 5.1 Supply Voltage .............................................................................................11 5.1.1 Operating Supply Voltage ............................................................... 11 5.1.2 Power-up Conditions ....................................................................... 11 5.1.3 Device Reset..................................................................................... 11 5.1.4 Power-down ...................................................................................... 11 5.2 Active Power and Standby Power Modes ....................................................11 5.3 Hold Condition .............................................................................................11 5.4 Status Register ............................................................................................. 13 5.4.1 Status Register Table ...................................................................... 13 5.4.2 The Status and Control Bits ........................................................... 13 5.4.3 Status Register Protect Table......................................................... 15 5.4.4 Write Protect Features .................................................................... 15 5.4.5 Status Register Memory Protection .............................................. 16 6. Device Identification ..................................................................... 17 7. Instructions Description................................................................ 18 7.1 Configuration and Status Instructions ......................................................... 23 7.1.1 Write Enable (06H) .......................................................................... 23 7.1.2 Write Disable (04H).......................................................................... 23 7.1.3 Read Status Register (05H or 35H) .............................................. 24 7.1.4 Write Status Register (01H or 31H) .............................................. 25 7.1.5 Write Enable for Volatile Status Register (50H) .......................... 27 7.1.6 Enter QPI Mode (38H)..................................................................... 28 7.1.7 Exit QPI Mode (FFH) ....................................................................... 28 7.2 Read Instructions ......................................................................................... 29 7.2.1 Read Data (03H) .............................................................................. 29 7.2.2 Fast Read (0BH) .............................................................................. 30 7.2.3 Dual Output Fast Read (3BH) ........................................................ 31 7.2.4 Quad Output Fast Read (6BH) ...................................................... 32 7.2.5 Dual I/O Fast Read (BBH) .............................................................. 33 7.2.6 Quad I/O Fast Read (EBH)............................................................. 35 7.2.7 Quad I/O Word Fast Read (E7H) .................................................. 37 Apr 2021 Rev 2.1 2 / 81 Contents BY25Q80BS 7.2.8 Octal Word Read Quad I/O (E3h).................................................. 39 7.2.9 Set Burst with Wrap (77H) .............................................................. 41 7.2.1 Set Read Parameters (C0H) .......................................................... 42 7.2.2 Burst Read with Wrap (0Ch) .......................................................... 42 7.3 ID and Security Instructions........................................................................ 44 7.3.1 Read Manufacture ID/ Device ID (90H)........................................ 44 7.3.2 Dual I/O Read Manufacture ID/ Device ID (92H) ........................ 45 7.3.3 Quad I/O Read Manufacture ID/ Device ID (94H) ...................... 46 7.3.4 Read JEDEC ID (9FH) .................................................................... 47 7.3.5 Read Unique ID Number (4Bh)...................................................... 48 7.3.6 Deep Power-Down (B9H) ............................................................... 49 7.3.7 Release from Deep Power-Down/Read Device ID (ABH)......... 50 7.3.8 Read Security Registers (48H) ...................................................... 52 7.3.9 Erase Security Registers (44H) ..................................................... 53 7.3.10 Program Security Registers (42H) ................................................ 54 7.3.11 Enable Reset (66H) and Reset Device (99H) ............................. 55 7.3.12 Read Serial Flash Discoverable Parameter (5AH) ..................... 56 7.4 Program and Erase Instructions................................................................... 57 7.4.1 Page Program (02H) ....................................................................... 57 7.4.2 Quad Page Program (32H)............................................................. 58 7.4.3 Fast Page Program (F2H) .............................................................. 59 7.4.4 Sector Erase (20H) .......................................................................... 60 7.4.5 32KB Block Erase (52H) ................................................................. 61 7.4.6 64KB Block Erase (D8H) ................................................................ 62 7.4.7 Chip Erase (60/C7H) ....................................................................... 63 7.4.8 Erase / Program Suspend (75H) ................................................... 64 7.4.9 Erase / Program Resume (7AH).................................................... 66 8. Electrical Characteristics.............................................................. 67 8.1 8.2 8.3 8.4 8.5 8.6 8.7 Absolute Maximum Ratings........................................................................ 67 Operating Ranges ........................................................................................ 67 Latch Up Characteristics ............................................................................. 68 Power-up Timing ......................................................................................... 68 DC Electrical Characteristics ...................................................................... 69 AC Measurement Conditions ...................................................................... 71 AC Electrical Characteristics ...................................................................... 71 9. Package Information .................................................................... 76 9.1 9.2 9.3 Package 8-Pin SOP 150- mil ........................................................................ 76 Package 8-Pin SOP 208- mil ........................................................................ 77 Package USON8 (2*3mm) .......................................................................... 78 10. Order Information ......................................................................... 79 10.1 10.2 Valid part Numbers and Top Side Marking ................................................. 80 Minimum Packing Quantity (MPQ)............................................................ 80 11. Document Change History........................................................... 81 Apr 2021 Rev 2.1 3 / 81 Description BY25Q80BS 1. Description The BY25Q80BS is 8M-bit Serial Peripheral Interface(SPI) Flash memory, and supports the Dual/Quad SPI as well as 2-clocks instruction cycle Quad Peripheral Interface (QPI): Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (/WP), and I/O3 (/HOLD) . The Dual I/O data is transferred with speed of 216Mbits/s and the Quad I/O & Quad output data is transferred with speed of 432Mbits/s. The device uses a single low voltage power supply, ranging from 2.7 Volt to 3.6 Volt. Additionally, the device supports JEDEC standard manufacturer and device ID and three 256-bytes Security Registers. In order to meet environmental requirements, Boya Microelectronics offers 8-pin SOP 208mil, 8pad WSON 6x5-mm, and other special order packages, please contacts Boya Microelectronics for ordering information. Figure 1. Logic diagram VCC SCLK SO SI /CS BY25QXX /WP /HOLD VSS Figure 2. Pin Configuration SOP8 Top View /CS (IO1)SO 1 8 2 VCC 7 /HOLD(IO3) SCLK SOP8 Apr 2021 (IO2)/WP 3 6 VSS 4 5 Rev 2.1 SI(IO0) 4 / 81 Description BY25Q80BS Figure 3.1. Pin Configuration WSON 5*6mm /CS 1 8 VCC (IO1)SO 2 7 /HOLD(IO3) SCLK Top View (IO2)/WP 3 6 VSS 4 5 SI(IO0) Figure 3.2. Pin Configuration USON 2*3mm /CS 1 8 VCC (IO1)SO 2 7 /HOLD(IO3) Top View Apr 2021 (IO2)/WP 3 6 SCLK VSS 4 5 SI(IO0) Rev 2.1 5 / 81 Signal Description BY25Q80BS 2. Signal Description During all operations, VCC must be held stable and within the specified valid range: VCC (min) to VCC (max). All of the input and output signals must be held High or Low (according to voltages of VIH, VOH, VIL or VOL, see Section 8.6, DC Electrical Characteristics on page 67&68). These signals are described next. 2.1 Input/Output Summary Table 1. Signal Names Pin Name I/O /CS I SO (IO1) I/O /WP (IO2) I/O VSS Chip Select Serial Output for single bit data Instructions. IO1 for Dual or Quad Instructions. Write Protect in single bit or Dual data Instructions. IO2 in Quad mode. The signal has an internal pull-up resistor and may be left unconnected in the host system if not used for Quad Instructions. Ground SI (IO0) I/O SCLK I /HOLD (IO3) I/O VCC Description Serial Input for single bit data Instructions. IO0 for Dual or Quad Instructions. Serial Clock Hold (pause) serial transfer in single bit or Dual data Instructions. IO3 in Quad-I/O mode. The signal has an internal pull-up resistor and may be left unconnected in the host system if not used for Quad Instructions. Core and I/O Power Supply 2.2 Chip Select (/CS) The chip select signal indicates when a instruction for the device is in process and the other signals are relevant for the memory device. When the /CS signal is at the logic high state, the device is not selected and all input signals are ignored and all output signals are high impedance. Unless an internal Program, Erase or Write Status Registers embedded operation is in progress, the device will be in the Standby Power mode. Driving the /CS input to logic low state enables the device, placing it in the Active Power mode. After Power Up, a falling edge on /CS is required prior to the start of any instruction. 2.3 Serial Clock (SCLK) This input signal provides the synchronization reference for the SPI interface. Instructions, addresses, or data input are latched on the rising edge of the SCLK signal. Data output changes after the falling edge of SCLK. 2.4 Serial Input (SI)/IO0 This input signal is used to transfer data serially into the device. It receives instructions, addresses, and data to be programmed. Values are latched on the rising edge of serial SCK clock signal. SI becomes IO0 an input and output during Dual and Quad Instructions for receiving instructions, addresses, and data to be programmed (values latched on rising edge of serial SCK clock signal) as well as shifting out data (on the falling edge of SCK). Apr 2021 Rev 2.1 6 / 81 Signal Description BY25Q80BS 2.5 Serial Data Output (SO)/IO1 This output signal is used to transfer data serially out of the device. Data is shifted out on the falling edge of the serial SCK clock signal. SO becomes IO1 an input and output during Dual and Quad Instructions for receiving instructions, addresses, and data to be programmed (values latched on rising edge of serial SCK clock signal) as well as shifting out data (on the falling edge of SCK). 2.6 Write Protect (/WP)/IO2 When /WP is driven Low (VIL), while the Status Register Protect bits (SRP1 and SRP0) of the Status Registers (SR2[0] and SR1[7]) are set to 0 and 1 respectively, it is not possible to write to the Status Registers. This prevents any alteration of the Status Registers. As a consequence, all the data bytes in the memory area that are protected by the Block Protect, TB, SEC, and CMP bits in the status registers, are also hardware protected against data modification while /WP remains Low. The /WP function is not available when the Quad mode is enabled (QE) in Status Register 2 (SR2[1]=1). The /WP function is replaced by IO2 for input and output during Quad mode for receiving addresses, and data to be programmed (values are latched on rising edge of the SCK signal) as well as shifting out data (on the falling edge of SCK). /WP has an internal pull-up resistance; when unconnected; /WP is at VIH and may be left unconnected in the host system if not used for Quad mode. 2.7 HOLD (/HOLD)/IO3 The /HOLD function is only available when QE=0, If QE=1, The /HOLD function is disabled, the pin acts as dedicated data I/O pin The /HOLD signal goes low to stop any serial communications with the device, but doesn’t stop the operation of write status register, programming, or erasing in progress. The operation of HOLD, need /CS keep low, and starts on falling edge of the /HOLD signal, with SCLK signal being low (if SCLK is not being low, HOLD operation will not start until SCLK being low). The HOLD condition ends on rising edge of /HOLD signal with SCLK being low (If SCLK is not being low, HOLD operation will not end until SCLK being low). The Hold condition starts on the falling edge of the Hold (/HOLD) signal, provided that this coincides with SCK being at the logic low state. If the falling edge does not coincide with the SCK signal being at the logic low state, the Hold condition starts whenever the SCK signal reaches the logic low state. Taking the /HOLD signal to the logic low state does not terminate any Write, Program or Erase operation that is currently in progress. /CS SCLK /HOLD HOLD HOLD Apr 2021 Rev 2.1 7 / 81 Signal Description BY25Q80BS 2.8 VCC Power Supply VCC is the supply voltage. It is the single voltage used for all device functions including read, program, and erase. 2.9 VSS Ground VSS is the reference for the VCC supply voltage. Apr 2021 Rev 2.1 8 / 81 Block/Sector Addresses BY25Q80BS 3. Block/Sector Addresses Table 2. Block/Sector Addresses of BY25Q80BS Memory Density Block(64k byte) Block(32k byte) Sector 0 Sector Size(KB) 4 000000h-000FFFh : : : Sector 7 4 007000h-007FFFh Sector 8 4 008000h-008FFFh : 4 : Sector 15 4 00F000h-00FFFFh Sector 16 4 010000h-010FFFh : : : Sector 23 4 017000h-017FFFh Sector 24 4 018000h-018FFFh : : : Sector 31 4 01F000h-01FFFFh : : : Sector 224 4 0E0000h-0E0FFFh Sector No. Half block 0 Block 0 Half block 1 Half block 2 Block 1 Half block 3 8Mbit : : Half block 28 Block 14 : : : Sector 231 4 0E7000h-0E7FFFh Sector 232 4 0E8000h-0E8FFFh : : : Sector 239 4 0EF000h-0EFFFFh Sector 240 4 0F0000h-0F0FFFh : : : Sector 247 4 0F7000h-0F7FFFh Sector 248 4 0F8000h-0F8FFFh : : : Sector 255 4 0FF000h-0FFFFFh Half block 29 Half block 30 Block 15 Address range Half block 31 Notes: 1. Block = Uniform Block, and the size is 64K bytes. 2. Half block = Half Uniform Block, and the size is 32k bytes. 3. Sector = Uniform Sector, and the size is 4K bytes. Apr 2021 Rev 2.1 9 / 81 SPI Operation BY25Q80BS 4. SPI Operation 4.1 Standard SPI Instructions The BY25Q80BS features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (/CS), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. 4.2 Dual SPI Instructions The BY25Q80BS supports Dual SPI operation when using the “Dual Output Fast Read” (3BH), “Dual I/O Fast Read” (BBH) and “Read Manufacture ID/Device ID Dual I/O” (92H) instructions. These instructions allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI instruction the SI and SO pins become bidirectional I/O pins: IO0 and IO1. 4.3 Quad SPI Instructions The BY25Q80BS supports Quad SPI operation when using the “Quad Output Fast Read”(6BH), “Quad I/O Fast Read” (EBH) ,”Quad I/O word Fast Read”(E7H),”Read Manufacture ID/Device ID Quad I/O”(94H) and “Quad Page Program”(32H) instructions. These instructions allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI instruction the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and /WP and /HOLD pins become IO2 and IO3. Quad SPI instructions require the non -volatile Quad Enable bit (QE) in Status Register to be set. 4.4 QPI Instructions The BY25Q80BS supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enter QPI (38h)” instruction. The typical SPI protocol requires that the byte-long instruction code being shifted into the device only via DI pin in eight serial clocks. The QPI mode utilizes all four IO pins to input the instruction code, thus only two serial clocks are required. This can significantly reduce the SPI instruction overhead and improve system performance in an XIP environment. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given time. “Enter QPI (38h)” and “Exit QPI (FFh)” instructions are used to switch between these two modes. Upon power -up or after a software reset using “Enable Reset (66h)”and “Reset (99h)” instruction, the default state of the device is Standard/Dual/Quad SPI mode. To enable QPI mode, the non -volatile Quad Enable bit (QE) in Status Register-2 is required to be set to 1. When using QPI instructions, the DI and DO pins become bidirectional IO0 and IO1, and the /WP and /HOLD pins become IO2 and IO3 respectively. Apr 2021 Rev 2.1 10 / 81 Operation Features BY25Q80BS 5. Operation Features 5.1 Supply Voltage 5.1.1 Operating Supply Voltage Prior to selecting the memory and issuing instructions to it, a valid and stable VCC voltage within the specified [VCC(min), VCC(max)] range must be applied (see operating ranges of page 65). In order to secure a stable DC supply voltage, it is recommended to decouple the VCC line with a suitable capacitor (usually of the order of 10nF to 100nF) close to the VCC/VSS package pins. This voltage must remain stable and valid until the end of the transmission of the instruction and, for a Write instruction, until the completion of the internal write cycle (tW). 5.1.2 Power-up Conditions When the power supply is turned on, VCC rises continuously from VSS to VCC. During this time, the Chip Select (/CS) line is not allowed to float but should follow the VCC voltage, it is therefore recommended to connect the /CS line to VCC via a suitable pull-up resistor. In addition, the Chip Select (/CS) input offers a built-in safety feature, as the /CS input is edge sensitive as well as level sensitive: after power-up, the device does not become selected until a falling edge has first been detected on Chip Select (/CS). This ensures that Chip Select (/CS) must have been High, prior to going Low to start the first operation. 5.1.3 Device Reset In order to prevent inadvertent Write operations during power -up (continuous rise of VCC), a power on reset (POR) circuit is included. At Power-up, the device does not respond to any instruction until VCC has reached the power on reset threshold voltage (this threshold is lower than the minimum VCC operating voltage defined in Power-up Timing). When VCC is lower than VWI , the device is reset. 5.1.4 Power-down At Power-down (continuous decrease in VCC), as soon as VCC drops from the normal operating voltage to below the power on reset threshold voltage, the device stops responding to any instruction sent to it. During Power-down, the device must be deselected (Chip Select (/CS) should be allowed to follow the voltage applied on VCC) and in Standby Power mode (that is there should be no internal Write cycle in progress). 5.2 Active Power and Standby Power Modes When Chip Select (/CS) is Low, the device is selected, and in the Active Power mode. The device consumes ICC. When Chip Select (/CS) is High, the device is deselected. If a Write cycle is not currently in progress, the device then goes in to the Standby Power mode, and the device consumption drops to ICC1. 5.3 Hold Condition The Hold (/HOLD) signal is used to pause any serial communications with the device without resetting the clocking sequence. During the Hold condition, the Serial Data Output (SO) is high impedance, and Serial Data Input (SI) and Serial Clock (SCLK) are Don’t Care. To enter the Hold condition, the device must be selected, with Chip Select ( /CS) Low. Normally, the device is kept selected, for the whole duration of the Hold condition. Deselecting the device while it is in the Hold condition, has the effect of resetting the state of the device, and this mechanism can be used if it is required to reset any processes that had been in progress. Apr 2021 Rev 2.1 11 / 81 Operation Features BY25Q80BS The Hold condition starts when the Hold (/HOLD) signal is driven Low at the same time as Serial Clock (SCLK) already being Low (as shown in Figure 4).The Hold condition ends when the Hold (HOLD) signal is driven High at the same time as Serial Clock (C) already being Low. Figure 4 also shows what happens if the rising and falling edges are not timed to coincide with Serial Clock (SCLK) being Low. Figure 4. Hold condition activation /CS SCLK /HOLD HOLD HOLD Apr 2021 Rev 2.1 12 / 81 Operation Features BY25Q80BS 5.4 Status Register 5.4.1 Status Register Table See Table 3 for detail description of the Status Register bits. Table 3. Status Register S15 SUS1 S14 CMP S13 LB3 S12 LB2 S11 LB1 S10 SUS2 S9 QE S8 SRP1 S7 S6 S5 S4 S3 S2 S1 S0 SRP0 BP4 BP3 BP2 BP1 BP0 WEL WIP 5.4.2 The Status and Control Bits 5.4.2.1 WIP bit The Write in Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register progress, when WIP bit sets 0, means the device is not in program/erase/write status register progress. 5.4.2.2 WEL bit The Write Enable Latch bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Register, Program or Erase instruction is accepted. 5.4.2.3 BP4, BP3, BP2, BP1, BP0 bits The Block Protect (BP4, BP3, BP2, BP1, BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase instructions. These bits are written with the Write Status Register instruction. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table 6 and Table 7).becomes protected against Page Program, Sector Erase and Block Erase instructions. The Block Protect ( BP4, BP3, BP2, BP1, BP0) bits can be written provided that the Hardware Protected mod e has not been set. The Chip Erase(CE) instruction is executed, if the Block Protect(BP2,BP1,BP0)bits are 0 and CMP=0 or The Block Protect (BP2, BP1, BP0) bits are1 and CMP=1. 5.4.2.4 SRP0, SRP1 bits The Status Register Protect (SRP0 and SRP1) bits are non-volatile Read/Write bits in the status register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. 5.4.2.5 QE bit The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the /WP pin and /HOLD pin are enable. When the QE pin is set to 1, the Quad IO2 and IO3 pins are enabled. (Th e QE bit should never be set to 1 during standard SPI or Dual SPI operation if the /WP or /HOLD pins directly to the power supply or ground). Apr 2021 Rev 2.1 13 / 81 Operation Features BY25Q80BS QE bit is required to be set to 1 before issuing an “Enter QPI (38h)” instruction to switch the device from Standard/Dual/Quad SPI mode to QPI mode; otherwise the command (38h) will be ignored. When the device is in QPI mode, QE bit will remain to be 1. A “Write Status Register” command in QPI mode cannot change QE bit from 1 to 0. 5.4.2.6 LB bit The LB bit is a non-volatile One Time Program (OTP) bit in Status Register (S13–S11) that provide the write protect control and status to the Security Registers. The default state of LB is 0, the security registers are unlocked. LB can be set to 1 individually using the Write Register instruction. LB is One Time Programmable, once they are set to 1, the Security Registers will become read only permanently. 5.4.2.7 CMP bit The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction the SEC-BP0 bits to provide more flexibility for the array protection. Please see the Status registers Memory Protection table for details. The default setting is CMP=0. 5.4.2.8 SUS1/SUS2 bit The SUS1 and SUS2 bits are read only bits in the status register2 (S15 and S10) that are set to 1 after executing an Erase/Program Suspend (75H) instruction (The Erase Suspend will set SUS1 to 1, and the Program Suspend will set the SUS2 to 1). The SUS1 and SUS2 bits are cleared to 0 by Erase/Program Resume (7AH) instruction as well as a power-down, power-up cycle. Apr 2021 Rev 2.1 14 / 81 Operation Features 5.4.3 BY25Q80BS Status Register Protect Table The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the Status Register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. Table 4. Status Register protect table SRP1 SRP0 /WP 0 0 X 0 1 0 0 1 1 1 0 X 1 1 X Status Register Software Protected Hardware Protected Hardware Unprotected Description The Status Register can be written to after a Write Enable instruction, WEL=1.(Factory Default) /WP=0, the Status Register locked and cannot be written. /WP=1, the Status Register is unlocked and can be written to after a Write Enable instruction, WEL=1. Power Supply Lock-Down(1) One Time Program(2) Status Register is protected and cannot be written to again until the next Power-Down, Power-Up cycle. Status Register is permanently protected and cannot be written to. Notes: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. The One time Program feature is available upon special order. Please contact Boya Microelectronics for details. 5.4.4 1. 2. 3. 4. 5. Write Protect Features Software Protection: The Block Protect (BP4, BP3, BP2, BP1, BP0) bits define the section of the memory array that can be read but not change. Hardware Protection: /WP going low to protected the writable bits of Status Register. Deep Power-Down: In Deep Power-Down Mode, all instructions are ignored except the Release from deep Power-Down Mode instruction. Write Enable: The Write Enable instruction is set the Write Enable Latch bit. The WEL bit will return to reset by following situation: -Power –up -Write Disable -Write Status Register (Whether the SR is protected, WEL will return to reset) -Write Extended Address Register (when in 3-Byte Address Mode) -Page Program (Whether the program area is protected, WEL will return to reset) -Sector Erase/Block Erase/Chip Erase (Whether the erase area is protected, WEL will return to reset) -Software Reset One Time Program (OTP) write protection for array and Security Registers using Status Register. Apr 2021 Rev 2.1 15 / 81 Operation Features 5.4.5 BY25Q80BS Status Register Memory Protection 5.4.5.1 Protect Table Table 5. BY25Q80BS Status Register Memory Protection (CMP=0) Status Register Content BP4 X 0 0 0 0 0 0 0 0 0 X 1 1 1 1 1 1 1 1 BP3 X 0 0 0 0 1 1 1 1 X X 0 0 0 0 1 1 1 1 BP2 0 0 0 0 1 0 0 0 1 1 1 0 0 0 1 0 0 0 1 BP1 0 0 1 1 0 0 1 1 0 0 1 0 1 1 0 0 1 1 0 BP0 0 1 0 1 0 1 0 1 0 1 X 1 0 1 X 1 0 1 X Memory Content Blocks NONE 15 14 to 15 12 to 15 8 to 15 0 0 to 1 0 to 3 0 to 7 0 to 15 0 to 15 15 15 15 15 0 0 0 0 Addresses NONE 0F0000H-0FFFFFH 0E0000H-0FFFFFH 0C0000H-0FFFFFH 080000H-0FFFFFH 000000H-00FFFFH 000000H-01FFFFH 000000H-03FFFFH 000000H-07FFFFH 000000H-0FFFFFH 000000H-0FFFFFH 0FF000H-0FFFFFH 0FE000H-0FFFFFH 0FC000H-0FFFFFH 0F8000H-0FFFFFH 000000H-000FFFH 000000H-001FFFH 000000H-003FFFH 000000H-007FFFH Density NONE 64KB 128KB 256KB 512KB 64KB 128KB 256KB 512KB 1MB 1MB 4KB 8KB 16KB 32KB 4KB 8KB 16KB 32KB Portion NONE Upper 1/16 Upper 1/8 Upper 1/4 Upper 1/2 Lower 1/16 Lower 1/8 Lower 1/4 Lower 1/2 ALL ALL Top Block Top Block Top Block Top Block Bottom Block Bottom Block Bottom Block Bottom Block Table 6 BY25Q80BS Status Register Memory Protection (CMP=1) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X 0 0 0 0 0 0 0 0 0 0 1 1 1 1 X 0 0 0 0 1 1 1 1 X X 0 0 0 0 0 0 0 0 1 0 0 0 1 1 1 0 0 0 1 0 0 1 1 0 0 1 1 0 0 1 0 1 1 0 0 1 0 1 0 1 0 1 0 1 X 1 0 1 X 0 to 15 0 to 14 0 to 13 0 to 11 0 to 7 1 to 15 2 to 15 4 to 15 8 to 15 NONE NONE 0 to 15 0 to 15 0 to 15 0 to 15 000000H-0FFFFFH 000000H-0EFFFFH 000000H-0DFFFFH 000000H-0BFFFFH 000000H-07FFFFH 010000H-0FFFFFH 020000H-0FFFFFH 040000H-0FFFFFH 080000H-0FFFFFH NONE NONE 000000H-0FEFFFH 000000H-0FDFFFH 000000H-0FBFFFH 000000H-0F7FFFH 1MB 960KB 896KB 768KB 512KB 960KB 896KB 768KB 512KB NONE NONE 1020KB 1016KB 1008KB 992KB ALL Lower 15/16 Lower 7/8 Lower 3/4 Lower 1/2 Upper 15/16 Upper 7/8 Upper 3/4 Upper 1/2 NONE NONE L-255/256 L-127/128 L-63/64 L-31/32 1 1 1 1 1 1 1 1 0 0 0 1 0 1 1 0 1 0 1 X 0 to 15 0 to 15 0 to 15 0 to 15 001000H-0FFFFFH 002000H-0FFFFFH 004000H-0FFFFFH 008000H-0FFFFFH 1020KB 1016KB 1008KB 992KB U-255/256 U-127/128 U-63/64 U-31/32 Apr 2021 Rev 2.1 16 / 81 Device Identification BY25Q80BS 6. Device Identification Three legacy Instructions are supported to access device identification that can indicate the manufacturer, device type, and capacity (density). The returned data bytes provide the information as shown in the below table. Table 7. BY25Q80BS ID Definition table Operation Code M7-M0 ID15-ID8 ID7-ID0 9FH 90H/92H/94H 68 68 40 14 13 ABH Apr 2021 13 Rev 2.1 17 / 81 Instructions Description BY25Q80BS 7. Instructions Description All instructions, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after /CS is driven low. Then, the one byte instruction code must be shifted in to the device, most significant bit first on SI, each bit being latched on the rising edges of SCLK. See Table 8/9/10, every instruction sequence starts with a one-byte instruction code. Depending on the instruction, this might be followed by address bytes, or by data bytes, or by both or none. /CS must be driven high after the last bit of the instruction sequence has been shifted in. For the instruction of Read, Fast Read, Read Status Register or Release from Deep Power Down, and Read Device ID, the shifted-in instruction sequence is followed by a data out sequence. /CS can be driven high after any bit of the data-out sequence is being shifted out. For the instruction of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down instruction, /CS must be driven high exactly at a byte boundary, otherwise the instruction is rejected, and is not executed. That is /CS must driven high when the number of clock pulses after /CS being driven low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Apr 2021 Rev 2.1 18 / 81 Instructions Description BY25Q80BS Table 8. Instruction Set Table 1 (Standard/Dual/Quad SPI Instructions) (1) Instruction Nam e Byte 1 Write Enable 06h Volatile SR Write Enable 50h Write Disable 04h Byte 2 05h (S7-S0) (2) 01h (S7-S0) (4) Read Status Register-2 35h (S15-S 8)(2) Write Status Register-2 31h (S15-S 8) Chip Erase C7h/60h Erase Suspend 75h Erase Resume 7Ah Read Status Register-1 Write Status Register-1 (4) Byte 3 Byte 4 Byte 5 Power-dow n B9h Release Power-dow n / ID ABh Dummy Dummy Dummy (ID7-ID0)(2) Manufactu rer/ D evic e ID 90h Dummy Dummy 00h (MF7-MF0) JEDEC ID 9Fh (MF7-MF0) (ID15-ID8) (ID7-ID0)(2) Enter QPI Mode 38h Enable Reset 66h Reset Device Read Serial Flash Discoverable Paramet er 99h 5Ah A23-A16 A15-A8 A7-A0 Dummy Byte 6 (ID7-ID0)(2) (D7-D0) Next bytes Instruction Nam e Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 ~ Byte 13 Read Unique ID 4Bh Dummy Dummy Dummy Dummy (UID63-UID0) Apr 2021 Rev 2.1 19 / 81 Instructions Description BY25Q80BS Table 9. Instruction Set Table 2 (Standard/Dual/Quad SPI Instructions) (1) Instruction Nam e Byte 1 Byte 2 Byte 3 Page Program 02h A23-A16 A15-A8 A7-A0 D7-D0(3) Next bytes Quad Page Program 32h A23-A16 A15-A8 A7-A0 D7-D0(3)(9) Next bytes Sector Erase (4KB) 20h A23-A16 A15-A8 A7-A0 Block Erase (32KB) 52h A23-A16 A15-A8 A7-A0 Block Erase (64KB) D8h A23-A16 A15-A8 A7-A0 Read Data 03h A23-A16 A15-A8 A7-A0 (D7-D0) Fast Read 0Bh A23-A16 A15-A8 A7-A0 Fast Read Dual Output 3Bh A23-A16 A15-A8 A7-A0 Fast Read Quad Output Erase Security Register (5) Program Security Register (5) Read Security Register (5) Byte 4 6Bh A23-A16 A15-A8 A7-A0 44h A23-A16 A15-A8 A7-A0 42h A23-A16 A15-A8 A7-A0 48h A23-A16 A15-A8 A7-A0 (6) (6) Fast Read Dual I/O BBh A23-A16 Mftr./Device ID Dual I/O 92h A23-A16(6) A15-A8(6) A15-A8 A7-A0 Byte 5 Byte 6 Next bytes Dummy (D7-D0) Next bytes Dummy (D7-D0)(7) Next bytes Dummy (9) Next bytes Dummy A7-A0(6) (D7-D0) M7-M0 (6) (D7-D0) (D7-D0) M7-M0(6) (MF7-MF0)(7) (D7-D0)(7) 77h Dummy Dummy Dummy W8-W0 EBh A23-A16(8) A15-A8(8) A7-A0(8) M7-M0(8) E7h A23-A16 (8) A15-A8 (8) (8) M7-M0 (8) Dummy A23-A16 (8) A15-A8 (8) M7-M0 (8) (9) A23-A16 (8) A15-A8 (8) M7-M0 (8) Mftr./Device ID Quad I/O Apr 2021 E3h 94h A7-A0 (8) A7-A0 (8) A7-A0 Rev 2.1 Next bytes (7) Set Burst w ith Wrap Word Read Quad I/O Octal Word Read Quad I/O(13) Byte 9 Next bytes Fast Read Quad I/O(10) (11) (12) Byte 8 (D7-D0) D7-D0(3) (6) Byte 7 Dummy (D7-D0) Dummy (D7-D0)(9) Dummy (D7-D0) (9) Next byte Next bytes Next bytes Dummy (MF7-MF0)(9) (ID7-ID0)(9) 20 / 81 Instructions Description BY25Q80BS Table 10. Instruction Set Table 3 (QPI Instructions) (14) Instruction Nam e Byte 1 Write Enable 06h Volatile SR Write Enable 50h Write Disable 04h Byte 2 Byte 3 05h (S7-S0)(2) Write Status Register-1 01h (S7-S0)(4) Read Status Register-2 35h (S15-S8)(2) Write Status Register-2 31h (S15-S8) Chip Erase C7h/60h Read Status Register-1 (4) Erase Suspend 75h Erase Resume 7Ah Pow er-down B9h Set Read Parameters C0h P7-P0 Release Pow erdown / ID ABh Dummy JEDEC ID 9Fh Exit QPI Mode FFh Enable Reset 66h (MF7-MF0 ) Byte 4 Dummy (2) (ID15-ID8) Byte 5 Dummy (2) (ID7-ID0) Byte 6 (ID7-ID0)(2) (2) Reset Device 99h Page Program 02h A23-A16 A15-A8 A7-A0 D7-D0(3)(9) Next bytes Sector Erase (4KB) 20h A23-A16 A15-A8 A7-A0 Block Erase (32KB) 52h A23-A16 A15-A8 A7-A0 Block Erase (64KB) D8h A23-A16 A15-A8 A7-A0 0Bh A23-A16 A15-A8 A7-A0 Dummy (15) (D7-D0) 0Ch A23-A16 A15-A8 A7-A0 Dummy (15) (D7-D0) A7-A0 (15) (D7-D0) Fast Read Burst Read w ith Wrap (16) Fast Read Quad I/O EBh A23-A16 A15-A8 M7-M0 Notes: 1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “( )” indicate data output from the device on 1, 2 or 4 IO pins. 2. The Status Register contents and Device ID will repeat continuously until /CS terminates the instruction. 3. At least one byte of data input is required for Page Program, Quad Page Program and Program Security Registers, up to 256 bytes of data input. If more than 256 bytes of data are sent to the device, the addressing will wrap to the beginning of the page and overwrite previously sent data. 4. Write Status Register-1 (01h) can also be used to program Status Register-1&2, see section 7.1.4. 5. Security Register Address: Security Register 1 A23-16 = 00h A15-8 = 10h A7-0 = byte address Security Register 2 A23-16 = 00h A15-8 = 20h A7-0 = byte address Security Register 3 A23-16 = 00h A15-8 = 30h A7-0 = byte address 6. Dual SPI address input format: IO0 = A22, A20, A18, A16, A14, A12, A10, A8, A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9, A7, A5, A3, A1, M7, M5, M3, M1 7. Dual SPI data output format: IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 8. Quad SPI address input format: IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 Apr 2021 Rev 2.1 21 / 81 Instructions Description BY25Q80BS 9. Quad SPI data input/output format: IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 10. Fast Read Quad I/O data output format: IO0 = (x, x, x, x, D4, D0, D4, D0) IO1 = (x, x, x, x, D5, D1, D5, D1) IO2 = (x, x, x, x, D6, D2, D6, D2) IO3 = (x, x, x, x, D7, D3, D7, D3) 11. Word Read Quad I/O data output format: IO0 = (x, x, D4, D0, D4, D0, D4, D0) IO1 = (x, x, D5, D1, D5, D1, D5, D1) IO2 = (x, x, D6, D2, D6, D2, D6, D2) IO3 = (x, x, D7, D3, D7, D3, D7, D3) 12. For Word Read Quad I/O, the lowest address bit must be 0. (A0 = 0) 13. For Octal Word Read Quad I/O, the lowest four address bits must be 0. (A3, A2, A1, A0 = 0) 14. QPI Command, Address, Data input/output format: CLK # 0 1 2 3 4 5 6 7 8 9 10 11 IO0 = C4, C0, A20, A16, A12, A8, A4, A0, D4, D0, D4, D0 IO1 = C5, C1, A21, A17, A13, A9, A5, A1, D5, D1, D5, D1 IO2 = C6, C2, A22, A18, A14, A10, A6, A2, D6, D2, D6, D2 IO3 = C7, C3, A23, A19, A15, A11, A7, A3, D7, D3, D7, D3 15. The number of dummy clocks for QPI Fast Read, QPI Fast Read Quad I/O & QPI Burst Read with Wrap is controlled by read parameter P7 – P4. 16. The wrap around length for QPI Burst Read with Wrap is controlled by read parameter P3 – P0. Apr 2021 Rev 2.1 22 / 81 Instructions Description BY25Q80BS 7.1 Configuration and Status Instructions 7.1.1 Write Enable (06H) See Figure 5, the Write Enable instruction is for setting the Write Enable Latch bit. The Write Enable Latch bit must be set prior to every Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register instruction and Erase/Program Security Registers instruction. The Write Enable instruction sequence: /CS goes low sending the Write Enable instruction /CS goes high. Figure 5. Write Enable Sequence Diagram for SPI Mode (left) or QPI Mode (right) /CS /CS SCLK Mode 3 Mode 3 Mode 0 0 1 2 3 4 5 6 7 Mode 3 Mode 0 06H SO High_Z 7.1.2 0 1 Mode 3 Mode 0 Mode 0 Instruction 06H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Instruction SI SCLK Write Disable (04H) See Figure 6, the Write Disable instruction is for resetting the Write Enable Latch bit. The Write Disable instruction sequence: /CS goes low -> sending the Write Disable instruction -> /CS goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase , Erase/Program Security Registers and Reset instructions. Figure 6. Write Disable Sequence Diagram for SPI Mode (left) or QPI Mode (right) /CS /CS SCLK Mode 3 Mode 3 Mode 0 0 1 2 3 4 5 6 04H SO High_Z Apr 2021 Mode 3 Mode 0 SCLK 0 Rev 2.1 1 Mode 0 Mode 3 Mode 0 Instruction 04H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Instruction SI 7 23 / 81 Instructions Description 7.1.3 BY25Q80BS Read Status Register (05H or 35H) See Figure 7.a(SPI mode)& Figure 7.b (QPI mode)the Read Status Register (RDSR) instruction is for reading the Status Register. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write in Progress (WIP) bit before sending a new instruction to the device. It is also possible to read the Status Register continuously. For instruction code “05H”, the SO will output Status Register bits S7~S0. The instruction code “35H”, the SO will output Status Register bits S15~S8. Figure 7.a. Read Status Register Sequence Diagram (SPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 0 7 6 18 19 20 21 22 23 1 0 Instruction SI 05H or 35H SO High_Z Status Register-1/2 out 7 MSB 6 4 5 3 Status Register-1/2 out 1 2 5 4 3 MSB Figure 7.b. Read Status Register Sequence Diagram (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 Instruction SI (IO0) Apr 2021 05H/35H 4 0 4 0 4 SO (IO1) 5 1 5 1 5 /WP (IO2) 6 2 6 2 6 /HOLD (IO3) 7 3 7 3 7 SR-1/2 out Rev 2.1 SR-1/2 out 24 / 81 2 7 Instructions Description 7.1.4 BY25Q80BS Write Status Register (01H or 31H) See Figure 8.a (SPI mode)& Figure 8.b (QPI mode), the Write Status Register instruction allows new values to be written to the Status Register. Before it can be accepted, a Write Enable instruction must previously have been executed. After the Write Enable instruction has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register instruction has no effect on S15, S1 and S0 of the Status Register. /CS must be driven high after the eighth or sixteen bit of the data byte has been latched in. If not, the Write Status Register instruction is not executed. As soon as /CS is driven high, the self -timed Write Status Register cycle (whose duration is t W ) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable La tch is reset. The Write Status Register instruction allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, BP0) bits, to define the size of the area that is to be treated as read -only, as defined in Table 3. The Write Status Register instruction also allows the user to set or reset the Status Register Protect (SRP1 and SRP0) bits in accordance with the Write Protect (/WP) signal. The Status Register Protect (SRP1 and SRP0) bits and Write Protect (/WP) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register instruction is not executed once the Hardware Protected Mode is entered. Figure 8.a. Write Status Register Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Status Register in Instruction SI 01H or 31H 7 6 5 2 3 4 1 0 MSB High_Z SO Figure 8.b. Write Status Register Sequence Diagram (QPI mode) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) Apr 2021 01H/31H 2 3 SR1/2in 4 0 SO (IO1) 5 1 /WP (IO2) 6 2 /HOLD (IO3) 7 3 Rev 2.1 Mode 3 Mode 0 25 / 81 Instructions Description BY25Q80BS The BY25Q80BS is also backward compatible to BoyaMicro’s previous generations of serial flash memories, in which the Status Register-1&2 can be written using a single “Write Status Register-1 (01h)” command. To complete the Write Status Register- 1&2 instruction, the /CS pin must be driven high after the sixteenth bit of data that is clocked in as shown in Figure 8.c(SPI mode) & Figure 8.d(QPI mode). If /CS is driven high after the eighth clock, the Write Status Register -1 (01h) instruction will only program the Status Register-1, the Status Register-2 will not be affected (Previous generations will clear CMP and QE bits). Figure 8.c. Write Status Register-1/2 Instruction (SPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 7 8 9 11 12 13 14 15 1 0 16 17 01H 6 7 MSB 5 4 2 3 18 19 20 21 22 23 9 8 Status Register-2 in Status Register-1 in Instruction SI 10 15 14 13 12 11 10 MSB SO High_Z Figure 8.d. Write Status Register-1/2 Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) Apr 2021 01H 2 3 SR1 in 4 5 SR2 in 4 0 12 8 SO (IO1) 5 1 13 9 /WP (IO2) 6 2 14 10 /HOLD (IO3) 7 3 15 11 Rev 2.1 Mode 3 Mode 0 26 / 81 Mode 3 Mode 0 Instructions Description 7.1.5 BY25Q80BS Write Enable for Volatile Status Register (50H) See Figure 9, the non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. Write Enable for Volatile Status Register instruction will not set the Write Enable Latch bit, it is only valid for the Write Status Registers instruction to change the volatile Status Register bit values. Figure 9. Write Enable for Volatile Status Register Instruction for SPI Mode (left) or QPI Mode (right) /CS /CS SCLK Mode 3 Mode 3 Mode 0 0 1 2 3 4 5 6 50H SO High_Z Apr 2021 Mode 3 Mode 0 SCLK 0 Rev 2.1 1 Mode 0 Mode 3 Mode 0 Instruction 50H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Instruction SI 7 27 / 81 Instructions Description 7.1.6 BY25Q80BS Enter QPI Mode (38H) The BY25Q80BS support both Standard/Dual/Quad Serial Peripheral Interface (SPI) and Quad Peripheral Interface (QPI). However, SPI mode and QPI mode cannot be used at the same time. “Enter QPI (38h)” instruction is the only way to switch the device from SPI mode to QPI mode. Upon power-up, the default state of the device upon is Standard/Dual/Quad SPI mode. This provides full backward compatibility with earlier generations of BoyaMicro serial flash memories. See Instruction Set Table 1- 2 for all supported SPI commands. In order to switch the device to QPI mode, the Quad Enable (QE) bit in Status Register-2 must be set to 1 first, and an “Enter QPI (38h)” instruction must be issued. If the Quad Enable (QE) bit is 0, the “Enter QPI (38h)” i nstruction will be ignored and the device will remain in SPI mode. See Instruction Set Table 3 for all the commands supported in QPI mode. When the device is switched from SPI mode to QPI mode, the existing Write Enable and Eras e Suspend status, and the Wrap Length setting will remain unchanged. Figure 42. Enter QPI Instruction (SPI Mode only) /CS SCLK 0 Mode 3 Mode 0 1 2 3 4 5 6 7 Mode 3 Mode 0 Instruction 7.1.7 SI 38H SO High_Z Exit QPI Mode (FFH) In order to exit the QPI mode and return to the Standard/Dual/Quad SPI mode, an “Exit QPI (FFh)” instruction must be issued. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch (WEL) and Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 43. Exit QPI Instruction (QPI Mode only) /CS Mode 3 SCLK 0 1 Mode 0 Mode 3 Mode 0 Instruction FFH SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Apr 2021 Rev 2.1 28 / 81 Instructions Description BY25Q80BS 7.2 Read Instructions 7.2.1 Read Data (03H) See Figure 10, the Read Data Bytes (READ) instruction is followed by a 3-byte address (A23-A0), each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The address is automatically incremented to the next higher address after each byte of data is shifted out allowing for a continuous stream of data. This means that the entire memory can be accessed with a single command as long as the clock continues. The command is completed by driving /CS high. The whole memory can be read with a single Read Data Bytes (READ) instruction. Any Read Data Bytes (READ) instruction, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. The Read Data (03h) instruction is only supported in Standard SPI mode. Figure 10. Read Data Bytes Sequence Diagram (SPI Mode only) /CS 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-Bit Address Instruction SI 03H 23 22 21 3 2 1 0 Data Byte1 MSB High_Z SO Apr 2021 7 MSB Rev 2.1 6 5 4 3 High_Z 2 29 / 81 1 0 Instructions Description 7.2.2 BY25Q80BS Fast Read (0BH) See Figure 11.a, the Read Data Bytes at Higher Speed (Fast Read) instruction is for quickly reading data out. It is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is s hifted out on SO, each bit being shifted out, at a Max frequency fc, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Figure 11.a. Fast Read Sequence Diagram (SPI Mode) /CS 0 1 2 4 3 5 6 7 9 8 28 10 29 30 31 SCLK Instruction 24-Bit Address 0BH SI 23 22 21 41 42 43 3 2 46 47 1 0 High_Z SO /CS 32 33 34 35 36 37 38 39 40 44 45 SCLK Dummy Clocks High_Z SI Data byte 1 High_Z SO 6 7 5 4 High_Z 3 2 0 1 Fast Read (0Bh) in QPI Mode The Fast Read instruction is also supported in QPI mode. When QPI mode is enabled, the number of dummy clocks is configured by the “Set Read Parameters (C0h)” instruction to accommodate a wide range of applications with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 4, 4, 6 or 8. The default number of dummy clocks upon power up or after a Reset instruction is 4. Figure 11.b. Fast Read Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 Instruction SI (IO0) 0Bh A23-16 7 8 A7-0 A15-8 9 10 11 12 13 14 15 IOs switch from Input to Output Dummy* 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 Byte 1 Byte 2 *”Set Read Parameters” instruction(C0h)can set the number of dummy clocks. Apr 2021 Rev 2.1 30 / 81 Instructions Description 7.2.3 BY25Q80BS Dual Output Fast Read (3BH) See Figure 12, the Dual Output Fast Read instruction is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Figure 12. Dual Output Fast Read Sequence Diagram (SPI Mode only) /CS 0 1 2 3 4 5 6 7 9 8 28 10 29 30 31 SCLK Instruction 24-Bit Address 3BH SI SO 23 22 21 41 42 43 3 2 1 0 High_Z /CS 32 33 34 35 36 37 38 39 40 44 45 46 47 6 4 2 0 SCLK Dummy Clocks SI 6 4 2 0 Data Byte 2 Data Byte 1 High_Z SO Apr 2021 7 Rev 2.1 5 3 1 7 5 3 1 31 / 81 High_Z High_Z Instructions Description 7.2.4 BY25Q80BS Quad Output Fast Read (6BH) See Figure 13, the Quad Output Fast Read instruction is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Figure 13. Quad Output Fast Read Sequence Diagram (SPI Mode only) /CS 0 1 3 2 4 5 6 8 7 9 28 10 29 30 31 SCLK 24-Bit Address Instruction SI (IO0) 6BH SO (IO1) High_Z /WP (IO2) High_Z /HOLD (IO3) High_Z /CS 32 33 34 35 36 22 23 37 38 39 40 3 2 1 45 46 47 21 41 42 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 7 3 Byte1 7 3 7 3 Byte3 43 44 0 SCLK SI (IO0) Dummy Clocks SO (IO1) High_Z /WP (IO2) High_Z /HOLD (IO3) High_Z Apr 2021 Rev 2.1 Byte2 3 7 Byte4 High_Z High_Z High_Z High_Z 32 / 81 Instructions Description 7.2.5 BY25Q80BS Dual I/O Fast Read (BBH) See Figure 14.a, the Dual I/O Fast Read instruction is similar to the Dual Output Fast Read instruction but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte 2-bit per clock by SI and SO, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Dual I/O Fast Read with “continuous Read Mode” The Dual I/O Fast Read instruction can further reduce instruction overhead through setting the “continuous Read Mode” bits (M7-4) after the inputs 3-byte address A23-A0).If the “continuous Read Mode” bits(M5-4)=(1,0),then the next Dual I/O fast Read instruction (after CS/ is raised and then lowered) does not require the BBH instruction code. The instruction sequence is shown in the following Figure14.b.If the “continuous Read Mode” bits (M5-4) does not equal (1,0),the next instruction requires the first BBH instruction code, thus returning to normal operation. A “continuous Read Mode” Reset instruction can be used to reset (M5-4) before issuing normal instruction. Figure 14.a. Dual I/O Fast Read Sequence Diagram (Initial command or previous (M5-4) ≠ (1,0)),SPI mode only) /CS 0 1 2 3 4 5 6 7 9 8 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Instruction SI (IO0) BBH SO (IO1) High_Z 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 /CS SCLK 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SI (IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO (IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 3 5 Byte 4 1 Byte 1 Apr 2021 Byte 2 Byte 3 Rev 2.1 High_Z High_Z 33 / 81 Instructions Description BY25Q80BS Figure 14.b. Dual I/O Fast Read Sequence Diagram (Previous command set (M5 -4) =(1,0),SPI mode only) /CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI (IO0) 6 SO (IO1) 7 /CS Apr 2021 0 6 4 0 6 4 2 0 6 4 2 0 5 3 1 A23-16 7 5 3 1 A15-8 7 5 3 A7-0 1 7 5 3 M7-0 1 4 2 2 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI (IO0) 6 4 2 0 6 4 0 6 4 2 0 6 SO (IO1) 7 5 3 Byte1 1 7 5 3 1 Byte2 7 5 3 Byte3 1 7 2 Rev 2.1 2 0 5 3 Byte4 1 4 34 / 81 Instructions Description 7.2.6 BY25Q80BS Quad I/O Fast Read (EBH) See Figure 15.a, the Quad I/O Fast Read instruction is similar to the Dual I/O Fast Read instruction but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte and 4-dummy clock 4-bit per clock by IO0, IO1, IO3, IO4, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register must be set to enable for the Quad I/O Fast read instruction. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits (A23-0), as shown in Figure 16, If the “Continuous Read Mode” bits (M5-4 )= (1,0), then the next Fast Read Quad I/O instruction(after /CS is raised and then lowered) does not require the EBH instruction code, The instruction sequence is shown in the followed Figure 15.b . If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction requires the first EBH instruction code, thus returning to normal operation. A “Continuous Read Mode” Reset command can also be used to reset (M5 -4) before issuing normal command. Figure 15.a. Quad I/O Fast Read Sequence Diagram (Initial command or previous (M5-4≠ (1,0)),SPI mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 7 9 A23-16 Instruction SI (IO0) 8 10 11 12 A15-8 13 A7-0 14 15 M7-0 16 17 Dummy 18 19 20 22 21 23 IOs switch from Input to Output Dummy 20 16 12 8 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 7 EBH Byte1 Byte2 Byte3 Figure 15.b. Quad I/O Fast Read Sequence Diagram (Previous command set (M5 -4)=(1,0)), SPI mode) /CS SCLK Mode 3 Mode 0 0 1 A23-16 2 3 4 A15-8 5 A7-0 6 7 M7-0 8 9 Dummy 10 11 12 13 14 15 IOs switch from Input to Output Dummy SI (IO0) 20 16 12 8 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 Byte1 Byte2 7 Byte3 Quad I/O Fast Read with “8/16/32/64-Byte Wrap Around” The Quad I/O Fast Read instruction can also be used to access a specific portion within a page by issuing a “Set Burst with Wrap” (77H) instruction prior to EBH. The “Set Burst with Wrap” (77H) instruction can either enable or disable the “Wrap Around” feature for the following EBH instructions. When “Wrap Around” is enabled, the data being accessed can be limited to either an 8, 16, 32 or 64-byte section of a 256-byte page. The output data starts at the initial address specified in the instruction, once it reaches the ending boundary of the 8/16/32/64 -byte section, the output will wrap around to the beginning boundary automatically until /CS is pulled high to terminate the instruction. Apr 2021 Rev 2.1 35 / 81 Instructions Description BY25Q80BS The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64 -byte) of data without issuing multiple read instructions. The “Set Burst with Wrap” instruction allows three “Wrap Bits”, W6-4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-5 are used to specify the length of the wrap around section within a page. Quad I/O Fast Read (EBh) in QPI Mode The Quad I/O Fast Read instruction is also supported in QPI mode, as shown in Figure 15.c Figure 15.d. When QPI mode is enabled, the number of dummy clocks is configured by the “Set Read Parameters (C0h)” instruction to accommodate a wide range of applications with different needs for either maximum Fast Read frequency or minimum data access latency. Depen ding on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 4, 4, 6 or 8. The default number of dummy clocks upon power up or after a Reset instruction is 4. In QPI mode, the “Continuous Read Mode” bits M7-0 are also considered as dummy clocks. In the default setting, the data output will follow the Continuous Read Mode bits immediately. “Continuous Read Mode” feature is also available in QPI mode for Quad I/O Fast Read instruction. Please refer to the description on previous pages. “Wrap Around” feature is not available in QPI mode for Quad I/O Fast Read instruction. To perform a read operation with fixed data length wrap around in QPI mode, a dedicated “Burst Read with Wrap” (0Ch) instruction must be used. Figure 15.c. Quad I/O Fast Read Sequence Diagram (Initial instruction or previous (M5 -4≠(1,0)) , QPI mode) /CS SCLK 0 Mode 3 Mode 0 1 2 3 4 5 6 Instruction A23-16 EBH SI (IO0) 7 A7-0 A15-8 8 9 10 11 12 13 14 IOs switch from Input to Output M7-0* 20 16 12 8 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 Byte 1 Byte 2 7 Byte 3 *”Set Read Parameters” instruction(C0h)can set the number of dummy clocks. Figure 15.d. Quad I/O Fast Read Sequence Diagram (Initial instruction or previous (M5 -4=(1,0)) , QPI mode) /CS 0 SCLK SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) 2 1 3 6 5 4 7 8 9 10 11 4 0 4 0 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 7 3 Byte1 A23-16 A15-8 A7-0 M7-0* 7 3 Byte2 *”Set Read Parameters” instruction(C0h)can set the number of dummy clocks. Apr 2021 Rev 2.1 36 / 81 Instructions Description 7.2.7 BY25Q80BS Quad I/O Word Fast Read (E7H) The Quad I/O Word Fast Read instruction is similar to the Quad Fast Read instruction except that the lowest address bit (A0) must equal 0 and 2-dummy clock. The instruction sequence is shown in the followed Figure 16.a, the first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Word Fast Read instruction. Quad I/O Word Fast Read with “Continuous Read Mode” The Quad I/O Word Fast Read instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte Address bits (A23-0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read instruction (after /CS is raised and then lowered) does not require the E7H instruction code, the instruction sequence is shown in the followed Figure 16.b. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction requires the first E7H instruction code, thus returning to normal operation. A “Continuous Read Mode” Reset command can also be used to reset (M5-4) before issuing normal command. Figure 16.a. Quad I/O Word Fast Read Sequence Diagram (Initial command or previous (M5-4)≠ (1,0),SPI mode only) /CS 0 1 2 3 4 5 6 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 8 7 SCLK SI (IO0) Instruction E7H SO (IO1) High_Z /WP (IO2) High_Z /HOLD (IO3) High_Z 4 0 4 0 4 0 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 A23-16 A15-8 7 3 A7-0 7 3 M7-M0 Dummy 7 3 Byte1 7 3 Byte2 7 3 Byte3 Figure 16.b. Quad I/O word Fast Read Sequence Diagram (Previous command set (M5 -4) =(1,0), SPI mode only) /CS 0 SCLK SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) 1 3 4 6 5 7 8 9 10 11 12 13 14 15 4 0 4 0 4 0 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 A23-16 Apr 2021 2 A15-8 A7-0 7 3 Dummy Byte1 M7-0 Rev 2.1 3 7 3 Byte2 7 3 Byte3 37 / 81 Instructions Description BY25Q80BS Quad I/O Word Fast Read with “8/16/32/64-Byte Wrap Around” in standard SPI mode The Quad I/O Fast Read instruction can also be used to access a specific portion within a page by issuing a “Set Burst with Wrap” (77H) instruction prior to E7H. The “Set Burst with Wrap” (77H) instruction can either enable or disable the “Wrap Around” feature for the following E7H instructions. When “Wrap Around” is enabled, the data being accessed can be limited to either an 8, 16, 32 or 64-byte section of a 256-byte page. The output data starts at the initial address specified in the instruction, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around to the beginning boundary automatically until /CS is pulled high to terminate the instruction. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64 -byte) of data without issuing multiple read instructions. The “Set Burst with Wrap” instruction allows three “Wrap Bits”, W6-4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-5 are used to specify the length of the wrap around section within a page. Apr 2021 Rev 2.1 38 / 81 Instructions Description 7.2.8 BY25Q80BS Octal Word Read Quad I/O (E3h) The Octal Word Read Quad I/O (E3h) instruction is similar to the Fast Read Quad I/O (EBh) instruction except that the lower four Address bits (A0, A1, A2, A3) must equal 0. As a result, the dummy clocks are not required, which further reduces the instruction overhead allowing even faster random access for code execution (XIP). The Quad Enable bit (QE) of Status Register-2 must be set to enable the Octal Word Read Quad I/O Instruction. Octal Word Read Quad I/O with “Continuous Read Mode” The Octal Word Read Quad I/O instruction can further reduce instruction overhead thro ugh setting the “Continuous Read Mode” bits (M7- 0) after the input Address bits (A23-0), as shown in Figure 17.a. The upper nibble of the (M7-4) controls the length of the next Octal Word Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the IO pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Octal Word Read Quad I/O instruction (after /CS is raised and then lowered) does not require the E3h instruction code, as shown in Figure 17.b. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after /CS is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after /CS is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFh on SI for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation. Figure 17.a. Octal Word Read Quad I/O Instruction (Initial instruction or previous M5 -4 ≠ 10, SPI Mode only) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 Instruction SI (IO0) 5 6 7 8 9 A23-16 10 11 12 A15-8 13 A7-0 14 15 16 17 18 19 20 21 IOs switch from Input to Output M7-0 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 /HOLD IO3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 E3H Byte1 Byte2 Byte3 7 Byte4 Figure 17.b. Octal Word Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode only) Apr 2021 Rev 2.1 39 / 81 Instructions Description BY25Q80BS /CS SCLK Mode 3 Mode 0 0 1 A23-16 2 3 4 A15-8 5 A7-0 6 7 8 9 10 11 12 13 IOs switch from Input to Output M7-0 SI (IO0) 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 Byte1 Apr 2021 Rev 2.1 Byte2 Byte3 40 / 81 Byte4 Instructions Description 7.2.9 BY25Q80BS Set Burst with Wrap (77H) See Figure 18, The Set Burst with Wrap instruction is used in conjunction with ”Quad I/O Fast Read” and “Quad I/O Word Fast Read” instruction to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap instruction sequence:/CS goes low ->Send Set Burst with Wrap instruction ->Send24 Dummy bits ->Send 8 bits “Wrap bits”->/CS goes high. If W6-4 is set by a Set Burst with Wrap instruction, all the following “Fast Read Quad I/O” and “Word Read Quad I/O” instructions will use the W6-4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap instruction should be issued to set W4=1. The default value of W4 upon power on is 1. W4 = 0 W4 =1 (DEFAULT) W6 , W5 Wrap Around Wrap Length Wrap Around Wrap Length 0 0 Yes 8-byte No N/A 0 1 Yes 16-byte No N/A 1 0 Yes 32-byte No N/A 1 1 Yes 64-byte No N/A Figure 18. Set Burst with Wrap Sequence Diagram (SPI mode only) /CS 0 1 2 3 4 5 6 7 8 9 11 10 12 13 14 15 SCLK SI (IO0) SO (IO1) Instruction x x x x x x W4 x High_Z x x x x x x x High_Z W5 x x x x x x x High_Z W6 x x x x x x x x High_Z /WP (IO2) High_Z /HOLD (IO3) High_Z Byte1 Apr 2021 High_Z 77H Rev 2.1 Byte2 Byte3 Byte4 41 / 81 Instructions Description BY25Q80BS 7.2.1 Set Read Parameters (C0H) In QPI mode, to accommodate a wide range of applications with different needs for either maximum read frequency or minimum data access latency, “Set Read Parameters (C0h)” instruction can be used to configure the number of dummy clocks for “Fast Read (0Bh)”, “Fast Read Quad I/O (EBh)” & “Burst Read with Wrap (0Ch)” instructions, and to configure the number of bytes of “Wrap Length” for the “Burst Read with Wrap (0Ch)” instruction. In Standard SPI mode, the “Set Read Parameters (C0h)” instruction is not accepted. The dummy clocks for various Fast Read instructions in Standard/Dual/Quad SPI mode are fixed, please refer to the Instruction Table 2 for details. The “Wrap Length” is set by W5-4 bit in the “Set Burst with Wrap (77h)” instruction. This setting will remain unchanged when the device is switched from Standard SPI mode to QPI mode. The default “Wrap Length” after a power up or a Reset instruction is 8 bytes, the default numbe r of dummy clocks is 4. The number of dummy clocks is only programmable for “Fast Read (0Bh)”, “Fast Read Quad I/O (EBh)” & “Burst Read with Wrap (0Ch)” instructions in the QPI mode. Whenever the device is switched from SPI mode to QPI mode, the number of dummy clocks and “Wrap Length” should be set again, prior to any 0Bh, EBh or 0Ch instructions. P5 – P4 DUMMY CLOCKS MAXIMUM READ FREQ. MAXIMUM READ FREQ. (A[1:0]=0,0 VCC=2.7V~2.9V) MAXIMUM READ FREQ. (A[1:0]=0,0 VCC=3.0V~3.6V) P1 – P0 WRAP LENGTH 0 0 4 55MHz 80MHz 80MHz 0 0 8-byte 0 1 4 55MHz 80MHz 80MHz 0 1 16-byte 1 0 6 80MHz 80MHz 108MHz 1 0 32-byte 1 1 8 80MHz 80MHz 108MHz 1 1 64-byte Figure 41. Set Read Parameters Instruction (QPI Mode only) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) 7.2.2 C0H 2 3 Mode 3 Mode 0 Read Parameters P4 P0 SO (IO1) P5 P1 /WP (IO2) P6 P2 /HOLD (IO3) P7 P3 Burst Read with Wrap (0Ch) The “Burst Read with Wrap (0Ch)” instruction provides an alternative way to perform the read operation with “Wrap Around” in QPI mode. The instruction is similar to the “ Fast Read (0Bh)” instruction in QPI mode, except the addressing of the read operation will “Wrap Around” to the beginning boundary of the “Wrap Length” once the ending boundary is reached. The “Wrap Length” and the number of dummy clocks can be configured by the “ Set Read Parameters (C0h)” instruction. Apr 2021 Rev 2.1 42 / 81 Instructions Description BY25Q80BS Figure 19. Burst Read with Wrap Instruction (QPI Mode only) /CS Mode 3 SCLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Mode 0 Instruction A23-16 0CH SI (IO0) A15-8 A7-0 IOs switch from Input to Output Dummy* 20 16 12 8 4 0 4 0 4 0 4 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 Byte1 Byte2 *”Set Read Paraments” instruction(C0h)can set the number of dummy clocks. Apr 2021 Rev 2.1 43 / 81 Byte3 Instructions Description BY25Q80BS 7.3 ID and Security Instructions 7.3.1 Read Manufacture ID/ Device ID (90H) See Figure 20, The Read Manufacturer/Device ID instruction is an alternative to the Release from Power-Down/Device ID instruction that provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The instruction is initiated by driving the /CS pin low and shifting the instruction code “90H” followed by a 24-bit address (A23-A0) of 000000H. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 20. Read Manufacture ID/ Device ID Sequence Diagram (SPI Mode only) /CS 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Instruction SI 24-Bit Address 3 2 23 22 21 90H High_Z SO 1 0 /CS 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI SO Apr 2021 7 6 Manufacturer ID 5 4 3 2 1 0 7 Rev 2.1 6 5 Device ID 3 2 4 1 0 44 / 81 Instructions Description 7.3.2 BY25Q80BS Dual I/O Read Manufacture ID/ Device ID (92H) See Figure 21, the Dual I/O Read Manufacturer/Device ID instruction is an alternative to the Release from Power-Down/Device ID instruction that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by Dual I/O. The instruction is initiated by driving the /CS pin low and shifting the instruction code “92H” followed by a 24-bit address (A23-A0) of 000000H. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 21. Dual I/O Read Manufacture ID/ Device ID Sequence Diagram (SPI Mode only) /CS 0 1 2 4 3 5 6 7 9 8 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Instruction SI (IO0) 92H SO (IO1) High_Z 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 Dummy /CS SCLK 23 24 25 26 27 28 29 30 SI (IO0) 6 4 2 0 6 4 2 0 SO (IO1) 7 5 3 1 7 5 3 1 40 41 42 43 6 44 45 46 47 0 6 7 5 3 1 MFR ID(repeat) 7 4 2 4 2 0 High_Z High_Z MFR ID Apr 2021 39 31 32 Device ID MFR and Device ID (repeat) Rev 2.1 3 1 5 Device ID(repeat) 45 / 81 Instructions Description 7.3.3 BY25Q80BS Quad I/O Read Manufacture ID/ Device ID (94H) See Figure 22, the Quad I/O Read Manufacturer/Device ID instruction is an alternative to the Release from Power-Down/Device ID instruction that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by quad I/O. The instruction is initiated by driving the /CS pin low and shifting the instruction code “94H” followed by a 24-bit address (A23-A0) of 000000H and4 dummy clocks. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 22. Quad I/O Read Manufacture ID/ Device ID Sequence Diagram (SPI mode only) /CS 0 1 2 3 4 5 6 7 9 8 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Instruction SI (IO0) 94H SO (IO1) High_Z WP (IO2) High_Z HOLD (IO3) High_Z 4 0 4 0 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 dummy dummy MFR ID Device ID /CS SCLK 23 24 25 26 27 28 29 30 31 SI (IO0) 4 0 4 0 4 0 4 0 SO (IO1) 5 1 5 1 5 1 5 1 WP (IO2) 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 HOLD (IO3) Apr 2021 MFR ID DID ID MFR ID DID ID (repeat) (repeat) (repeat) (repeat) Rev 2.1 46 / 81 Instructions Description 7.3.4 BY25Q80BS Read JEDEC ID (9FH) The JEDEC ID instruction allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte, and the memory capacity of the device in the second byte. JEDEC ID instruction while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The JEDEC ID instruction should not be issued while the device is in Deep Power -Down Mode. See Figure 23.a (SPI mode)&Figure 23.b (QPI mode), The device is first selected by driving /CS to low. Then, the 8-bit instruction code for the instruction is shifted in. This is followed by the 24-bit device identification, stored in the memory, being shifted out on Serial Data Output, each bit being shifted out during the falling edge of Serial Clock. The JEDEC ID instruction is terminat ed by driving /CS to high at any time during data output. When /CS is driven high, the device is put in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute instructions. Figure 23.a. JEDEC ID Sequence Diagram (SPI Mode) /CS 0 1 2 3 6 5 4 7 8 10 9 11 12 13 14 15 SCLK 9FH Instruction SI Manufacturer ID /CS 6 7 MSB SO 16 17 18 19 20 21 22 23 24 5 25 26 3 4 27 28 29 2 0 1 30 31 SCLK SI SO 7 Memory Type ID15-ID8 1 6 5 4 3 2 0 MSB 6 7 Capacity ID7-ID0 5 4 3 2 1 0 MSB Figure 23.b. Read JEDEC ID Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 Instruction SI (IO0) 4 5 6 7 Mode 3 Mode 0 IOs switch from Input to Output 9FH 12 8 4 0 SO (IO1) 13 9 5 1 /WP (IO2) 14 10 6 2 15 11 7 3 /HOLD (IO3) 68H Apr 2021 3 Rev 2.1 ID15-8 ID7-0 47 / 81 Instructions Description 7.3.5 BY25Q80BS Read Unique ID Number (4Bh) The Read Unique ID Number instruction accesses a factory-set read-only 64-bit number that is unique to each BY25Q80BS device. The ID number can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID instruction is initiated by driving the /CS pin low and shifting the instruction code “4Bh” followed by a four b ytes of dummy clocks. After which, the 64-bit ID is shifted out on the falling edge of SCLK as shown in Figure 24. Figure 24. Read Unique ID Sequence Diagram (SPI Mode only) /CS SCLK 0 Mode 3 Mode 0 1 2 3 4 5 6 7 8 9 10 Instruction SI 11 12 13 14 15 16 Dummy Byte 1 17 18 19 20 21 22 23 Dummy Byte 2 4BH SO High_Z /CS 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 100 101 102 103 SCLK Dummy Byte 3 Dummy Byte 4 SI SO Apr 2021 High_Z 63 MSB Rev 2.1 62 2 1 0 64-bit Unique Serial Number 48 / 81 Mode 3 Mode 0 Instructions Description 7.3.6 BY25Q80BS Deep Power-Down (B9H) Although the standby current during normal operation is relatively low, standby current can be further reduced with the Deep Power-down instruction. The lower power consumption makes the Deep Power-down (DPD) instruction especially useful for battery powered applications (see ICC1 and ICC2). The instruction is initiated by driving the /CS pin low and shifting the instruction code “B9h” as shown in Figure 25.a (SPI mode) &Figure 25.b (QPI mode). The /CS pin must be driven high after the eighth bit has been latched. If this is not done the Deep Power down instruction will not be executed. After /CS is driven high, the power -down state will entered within the time duration of tDP. While in the power -down state only the Release from Deep Power-down / Device ID instruction, which restores the device to normal operation, will be recognized. All other Instructions are ignored. This includes the Read Status Register instruction, which is always available during normal operation. Ignoring all but one instruction also makes the Power Down state a useful condition for securing maximum write protection. The device always powers-up in the normal operation with the standby current of ICC1. Figure 25.a. Deep Power-Down Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 tDP 7 SCLK Instruction SI B9H Stand-by mode Power-down mode Figure 25.b. Deep Power-down Instruction (QPI Mode) /CS tDP Mode 3 SCLK 0 1 Mode 3 Mode 0 Mode 0 Instruction B9H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Stand-by current Apr 2021 Rev 2.1 Power-down current 49 / 81 Instructions Description 7.3.7 BY25Q80BS Release from Deep Power-Down/Read Device ID (ABH) The Release from Power-Down or Device ID instruction is a multi-purpose instruction. It can be used to release the device from the Power-Down state or obtain the devices electronic identification (ID) number. See Figure 26.a (SPI mode) &Figure 26.b (QPI mode), to release the device from the Power-Down state, the instruction is issued by driving the /CS pin low, shifting the instruction code “ABH” and driving /CS high Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other instruction are accepted. The /CS pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the Power -Down state, the instruction is initiated by driving the /CS pin low and shifting the instruction code “ABH” followed by 3 -dummy byte. The Device ID bits are then shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in The Device ID value for the BY25Q80BS is listed in Manufacturer and Device Identification table. The Device ID can be read continuously. The instruction is completed by driving /CS high. When used to release the device from the Power-Down state and obtain the Device ID, the instruction is the same as previously described, and shown in Figure 26.c (SPI mode) &Figure 26.d (QPI mode), except that after /CS is driven high it must remain high for a time duration of tRES2 (See AC Characteristics). After this time duration the device will resume normal operation and other instruction will be accepted. If the Release from Power-Down/Device ID instruction is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the instruction is ignored and will not have any effects on the current cycle. Figure 26.a. Release Power-Down Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 tRES1 7 SCLK Instruction SI ABH Power-down mode Stand-by mode Figure 26.b. Release Power-down Instruction (QPI Mode) /CS tRES1 Mode 3 SCLK 0 1 Mode 3 Mode 0 Mode 0 Instruction ABH SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Power-down current Stand-by current Apr 2021 Rev 2.1 50 / 81 Instructions Description BY25Q80BS Figure 26.c. Release Power-down / Device ID Instruction (SPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 7 8 9 23 22 Instruction SI 29 30 31 1 0 32 33 34 35 36 37 38 Mode 3 Mode 0 39 tRES2 3 Dummy Bytes ABH 2 MSB High_Z SO Device ID 5 6 7 MSB 4 3 2 1 0 Power-down current Stand-by current Figure 26.d. Release Power-down / Device ID Instruction (QPI Mode) /CS tRES2 Mode 3 SCLK 0 1 2 3 5 6 7 9 8 Mode 3 Mode 0 Mode 0 Instruction IOs switch from Input to Output 3 Dummy Byte ABH SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) 4 X X X X X X 4 0 X X X X X X 5 1 X X X X X X 6 2 X X X X X X 7 3 Device ID Power-down current Stand-by current Apr 2021 Rev 2.1 51 / 81 Instructions Description 7.3.8 BY25Q80BS Read Security Registers (48H) See Figure 27, the Read Security Registers instruction is similar to Fast Read instruction. The instruction is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is s hifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Once the A7-A0 address reaches the last byte of the register (Byte FFH), it will reset to 000H, the instruction is completed by driving /CS high. Address A23-A16 A15-A12 A11-A8 A7-A0 Security Registers 1 00H 0001 0000 Byte Address Security Registers 2 00H 0010 0000 Byte Address Security Registers 3 00H 0011 0000 Byte Address Figure 27. Read Security Registers instruction Sequence Diagram (SPI Mode only) /CS 0 1 2 3 4 5 6 7 8 9 28 29 30 31 SCLK Instruction SI 48H SO High_Z 24-Bit Address 3 23 22 2 1 0 /CS 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO Apr 2021 7 6 5 4 3 2 1 0 Data Byte 1 7 6 MSB Rev 2.1 5 4 3 2 1 0 52 / 81 Instructions Description 7.3.9 BY25Q80BS Erase Security Registers (44H) The BY25Q80BS provides three 256-byte Security Registers which can be erased and programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. See Figure 28, the Erase Security Registers instruction is similar to Sector/Block Erase instruction. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit. The Erase Security Registers instruction sequence: /CS goes low sending Erase Security Registers instruction /CS goes high. /CS must be driven high after the eighth bit of the instruction code has been latched in otherwise the Erase Security Registers instruction is not executed. As soon as /CS is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the selftimed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. The Security Registers Lock Bit (LB) in the Status Register can be used to OTP protect the security registers. Once the LB bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers instruction will be ignored. Address A23-A16 A15-A12 A11-A8 A7-A0 Security Registers 1 00H 0001 0000 Byte Address Security Registers 2 00H 0010 0000 Byte Address Security Registers 3 00H 0011 0000 Byte Address Figure 28. Erase Security Registers instruction Sequence Diagram (SPI Mode only) /CS 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Instruction SI Apr 2021 44H Rev 2.1 24-Bit Address 23 22 2 1 0 53 / 81 Instructions Description BY25Q80BS 7.3.10 Program Security Registers (42H) See Figure 29, the Program Security Registers instruction is similar to the Page Program instruction. It allows from 1 to 256 bytes Security Registers data to be programmed. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit before sending the Program Security Registers instruction. The Program Security Registers instruction is entered by driving /CS Low, followed by the instruction code (42H), 3-byte address and at least one data byte on SI. As soon as /CS is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is rese t. If the Security Registers Lock Bit (LB3/LB2/LB1) is set to 1, the Security Registers will be permanently locked. Program Security Registers instruction will be ignored. Address A23-A16 A15-A12 A11-A8 A7-A0 Security Registers 1 00H 0001 0000 Byte Address Security Registers 2 00H 0010 0000 Byte Address Security Registers 3 00H 0011 0000 Byte Address Figure 29. Program Security Registers instruction Sequence Diagram (SPI Mode only) /CS 0 4 3 2 1 5 6 7 9 8 10 29 30 28 31 32 33 34 35 36 37 38 39 SCLK Instruction 24-Bit Address 23 22 MSB 42H SI 21 3 Data Byte 1 1 2 0 7 MSB 6 4 5 2 3 1 0 2079 2078 2077 2076 2075 2074 53 54 55 2073 40 41 42 43 44 45 46 47 48 49 50 51 52 2072 /CS SCLK Data Byte 2 SI 7 MSB Apr 2021 6 5 4 3 2 1 0 7 6 MSB Data Byte 3 4 3 2 5 Rev 2.1 1 0 7 6 MSB Data Byte 256 3 2 5 4 54 / 81 1 0 Instructions Description BY25Q80BS 7.3.11 Enable Reset (66H) and Reset Device (99H) Because of the small package and the limitation on the number of pins, the BY25Q 80BS provides a software Reset instruction instead of a dedicated RESET pin. Once the software Reset instruction is accepted, any on-going internal operations will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch (WEL) status, Program/Erase Suspend status, Continuous Read Mode bit setting (M7-M0) and Wrap Bit setting (W6-W4). To avoid accidental reset, both “Enable Reset (66h)” and “Reset (99h)” instructions must be issued in sequence. Any other commands other than “Reset (99h)” after the “Enable Reset (66h)” command will disable the “Reset Enable” state. A new sequence of “Enable Reset (66h)” and “Reset (99h)” is needed to reset the device. Once the Reset command is accepted by the device, the device will take approximately 30us to reset. During this period, no command will be accepted. The Enable Reset (66h) and Reset (99h) instruction sequence is shown in Figure 30.a(SPI mode)& Figure 30.b(QPI mode) . Data corruption may happen if there is an on-going or suspended internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the BUSY bit and the SUS bit in Status Register before issuing the Reset comman d sequence. Figure 30.a. Enable Reset (66h) and Reset (99h) Command Sequence (SPI mode) /CS 0 1 2 3 4 5 6 0 7 1 2 3 4 5 6 SCLK Instruction SI Instruction 99h 66H Figure 30.b. Enable Reset and Reset Instruction Sequence (QPI Mode) /CS SCLK SI (IO0) Mode 3 Mode 0 0 1 Mode 3 Mode 0 0 1 Instruction Instruction 66H 99H Mode 3 Mode 0 SO (IO1) /WP (IO2) /HOLD (IO3) Apr 2021 Rev 2.1 55 / 81 7 Instructions Description BY25Q80BS 7.3.12 Read Serial Flash Discoverable Parameter (5AH) See Figure 31,The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standar d, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216. Figure 31. Read Serial Flash Discoverable Parameter command Sequence Diagram /CS 0 1 2 3 4 5 6 7 8 9 28 29 30 31 SCLK Instruction SI 5AH SO High_Z 24-Bit Address 3 23 22 2 1 0 /CS 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO Apr 2021 7 6 5 4 3 2 1 0 Data Byte 1 7 6 MSB Rev 2.1 5 4 3 2 1 0 56 / 81 Instructions Description BY25Q80BS 7.4 Program and Erase Instructions 7.4.1 Page Program (02H) The Page Program instruction is for programming the memory. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit before sending the Page Program instruction. See Figure 32.a (SPI mode) & Figure 32.b (QPI mode), the Page Program instruction is entered by driving /CS Low, followed by the instruction code, 3-byte address and at least one data byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). /CS must be driven low for the entire duration of the sequence. The Page Program instr uction sequence: /CS goes low-> sending Page Program instruction ->3-byte address on SI ->at least 1 byte data on SI-> /CS goes high. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. /CS must be driven high after t he eighth bit of the last data byte has been latched in; otherwise the Page Program instruction is not executed. As soon as /CS is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. A Page Program instruction applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed. Figure 32.a. Page Program Sequence Diagram (SPI mode) /CS 0 4 3 2 1 5 6 7 9 8 10 31 32 33 34 35 36 37 38 39 29 30 28 SCLK Instruction 24-Bit Address 23 22 21 MSB 02H SI 3 Data Byte 1 1 2 0 7 6 MSB 4 5 2 3 1 0 2079 2077 2078 2076 2075 2074 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2073 2072 /CS SCLK Data Byte 2 7 SI 6 5 4 3 2 1 0 MSB Data Byte 3 4 3 2 1 5 7 6 MSB 7 6 MSB 0 Data Byte 256 3 2 5 4 0 1 Figure 32.b. Page Program Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 2 3 4 5 6 Instruction SI (IO0) 02H A23-16 7 A7-0 A15-8 8 9 Byte 1 10 11 Byte 2 12 13 Byte 3 516 517 518 519 Byte 255 Byte 256 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 0 SO (IO1) 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 1 /WP (IO2) 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 /HOLD (IO3) 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 Apr 2021 Rev 2.1 57 / 81 Mode 3 Mode 0 Instructions Description 7.4.2 BY25Q80BS Quad Page Program (32H) The Quad Page Program instruction is for programming the memory using for pins: IO0, IO1, IO2 and IO3. To use Quad Page Program the Quad enable in status register Bit9 must be set (QE=1). A Write Enable instruction must previously have been executed to set the Write Enable Latch bit before sending the Page Program instruction. The Quad Page Program instruction is entered by driving /CS Low, followed by the command code (32H), three address bytes and at least one data byte on IO pins. The instruction sequence is shown in Figure 33, .If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. /CS must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Quad Page Program instruction is not executed. As soon as /CS is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. A Quad Page Program instruction applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed Figure 33.Quad Page Program Sequence Diagram (SPI mode only) /CS 0 1 2 3 4 5 6 7 30 31 32 33 34 35 36 37 38 39 8 SCLK Instruction SI (IO0) 32H SO (IO1) High_Z WP (IO2) High_Z HOLD (IO3) High_Z 24-bits address 23 22 0 1 4 0 4 0 4 0 4 0 5 1 5 1 5 1 5 1 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 Byte1 Byte2 /CS SCLK 40 41 42 43 44 45 46 47 48 535 536 537 538 539 540 541 542 543 SI (IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO (IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP (IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 Byte 5 7 3 7 3 7 3 7 3 7 3 7 3 7 3 High_Z High_Z High_Z High_Z HOLD (IO3) Apr 2021 Byte 6 Byte 253 Rev 2.1 Byte 256 58 / 81 Instructions Description 7.4.3 BY25Q80BS Fast Page Program (F2H) The Fast Page Program instruction is used to program the memory. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit before sending the Page Program instruction. The Fast Page Program instruction is entered by driving /CS Low, followed by the instruction code, 3-byte address and at least one data byte on SI. If the 8 least significant address bits (A7 -A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). /CS must be driven low for the entire duration of the sequence. The Fast Page Program instruction sequence: /CS goes low ->sending Page Program instruction-> 3-byte address on SI-> at least 1 byte data on SI ->/CS goes high. The command sequence is shown in Figure 34, If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. /CS must be driven high after the eighth bit of the last data byte has b een latched in; otherwise the Fast Page Program instruction is not executed. As soon as /CS is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self -timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. A Fast Page Program instruction applied to a page which is protected by the Block Protect ( BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed. Figure 34.Fast Page Program Sequence Diagram /CS 0 4 3 2 1 5 6 7 9 8 10 29 30 28 31 32 33 34 35 36 37 38 39 SCLK Instruction 23 22 21 MSB F2H SI Data Byte 1 24-Bit Address 3 1 2 0 7 6 MSB 4 5 2 3 1 0 2079 2078 2077 2075 2076 2074 2073 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2072 /CS SCLK Data Byte 2 SI 7 6 MSB Apr 2021 5 4 3 2 1 0 7 6 MSB Data Byte 3 4 3 2 5 Rev 2.1 1 0 7 6 MSB Data Byte 256 3 2 5 4 59 / 81 1 0 Instructions Description 7.4.4 BY25Q80BS Sector Erase (20H) The Sector Erase instruction is for erasing the all data of the chosen sector. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit. The Sector Erase instruction is entered by driving /CS low, followed by the instruction code, and 3 -address byte on SI. Any address inside the sector is a valid address for the Sector Erase instruction. /CS must be driven low for the entire duration of the sequence. See Figure 35.a (SPI mode) & Figure 35.b (QPI mode), The Sector Erase instruction sequence: /CS goes low-> sending Sector Erase instruction-> 3-byte address on SI ->/CS goes high. /CS must be driven high after the eighth bit of the last address byte has been latched in; otherwise the Sector Erase instruction is not executed. As soon as /CS is driven high, the self -timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. A Sector Erase instruction applied to a sector which is protected by the Block Protect ( BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed. Figure 35.a Sector Erase Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Instruction SI 24-Bit Address 23 22 20H 2 1 0 Figure 35.b Sector Erase Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) Apr 2021 20H 2 3 A23-16 4 5 A15-8 6 7 A7-0 20 16 12 8 4 0 SO (IO1) 21 17 13 9 5 1 /WP (IO2) 22 18 14 10 6 2 /HOLD (IO3) 23 19 15 11 7 3 Rev 2.1 Mode 3 Mode 0 60 / 81 Instructions Description 7.4.5 BY25Q80BS 32KB Block Erase (52H) The 32KB Block Erase instruction is for erasing the all data of the chosen block. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit. The 32KB Block Erase instruction is entered by driving /CS low, followed by the instruction code, and 3-byte address on SI. Any address inside the block is a valid address for the 32KB Block Erase instruction. /CS must be driven low for the entire duration of the sequence. See Figure 36.a (SPI mode) & Figure 36.b (QPI mode), the 32KB Block Erase instruction sequence: /CS goes low ->sending 32KB Block Erase instruction ->3-byte address on SI ->/CS goes high. /CS must be driven high after the eighth bit of the last address byte h as been latched in; otherwise the 32KB Block Erase instruction is not executed. As soon as /CS is driven high, the self -timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is rese t. A 32KB Block Erase instruction applied to a block which is protected by the Block Protect ( BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed. Figure 36.a. 32KB Block Erase Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Instruction SI 24-Bit Address 52H 23 22 2 4 6 1 0 Figure 36.b. 32KB Block Erase Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) 52H 2 3 A23-16 5 A15-8 7 A7-0 20 16 12 8 4 0 SO (IO1) 21 17 13 9 5 1 /WP (IO2) 22 18 14 10 6 2 /HOLD (IO3) 23 19 15 11 7 3 Apr 2021 Rev 2.1 Mode 3 Mode 0 61 / 81 Instructions Description 7.4.6 BY25Q80BS 64KB Block Erase (D8H) The 64KB Block Erase instruction is for erasing the all data of the chosen block. A Write Enable instruction must previously have been executed to set the Write Enable Latch bit. The 64KB Block Erase instruction is entered by driving /CS low, followed by the instruction code, and 3-byte address on SI. Any address inside the block is a valid address for the 64KB Block Erase instruction. /CS must be driven low for the entire duration of the sequence. See Figure 37Figure27.a (SPI mode) & Figure 37.b (QPI mode), the 64KB Block Erase instruction sequence: /CS goes low sending 64KB Block Erase instruction 3-byte address on SI /CS goes high. /CS must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 64KB Block Erase instruction is not executed. As soon as /CS is driven high, the self -timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch bit is reset. A 64KB Block Erase instruction applied to a block which is protected by the Block Protect ( BP4, BP3, BP2, BP1, BP0) bits (see Table 5&6) is not executed. Figure 37.a 64KB Block Erase Sequence Diagram (SPI mode) /CS 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Instruction SI 24-Bit Address 23 22 D8H 2 1 0 Figure 37.b. 64KB Block Erase Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 Instruction SI (IO0) D8H 2 3 A23-16 4 5 A15-8 6 7 A7-0 20 16 12 8 4 0 SO (IO1) 21 17 13 9 5 1 /WP (IO2) 22 18 14 10 6 2 /HOLD (IO3) 23 19 15 11 7 3 Apr 2021 Rev 2.1 Mode 3 Mode 0 62 / 81 Instructions Description 7.4.7 BY25Q80BS Chip Erase (60/C7H) The Chip Erase instruction sets all memory within the device to the erased state of all 1s (FFh). A Write Enable instruction must be executed before the device will accept the Chip Erase Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the /CS pin low and shifting the instruction code “C7h” or “60h”. The Chip Erase instruction sequence is shown in Figure 38. The /CS pin must be driven high after the eighth bit has been latched. If this i s not done the Chip Erase instruction will not be executed. After /CS is driven high, the self-timed Chip Erase instruction will commence for a time duration of tCE. While the Chip Erase cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the WIP bit. The WIP bit is a 1 during the Chip Erase cycle and becomes a 0 when finished and the device is ready to accept other Instructions again. After the Chip Erase cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Chip Erase instruction is executed only if all Block Protect (BP2, BP1, and BP0) bits are 0.The Chip Erase instruction is ignored if one or more sectors are protected. Figure 38. Chip Erase Instruction for SPI Mode (left) or QPI Mode (right) /CS /CS SCLK Mode 3 Mode 3 Mode 0 0 1 2 3 4 5 6 C7H or 60H SO High_Z Apr 2021 Mode 3 Mode 0 0 Rev 2.1 1 Mode 0 Mode 3 Mode 0 Instruction C7H/60H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Instruction SI 7 SCLK 63 / 81 Instructions Description 7.4.8 BY25Q80BS Erase / Program Suspend (75H) The Erase/Program Suspend instruction allows the system to interrupt a Sector or Block Erase operation, then read from or program data to any other sector /block which is not in the same big block(4Mbit). The Erase/Program Suspend instruction also allows the system to interrupt a Page Program operation and then read from any other page or erase any other sector or block. The Erase/Program Suspend instruction sequence is shown in Figure 39.a (SPI mode) & Figure 39.b (QPI mode) Figure 39.a. Erase/Program Suspend Command Sequence (SPI mode) /CS 0 1 2 3 4 5 6 0 7 1 2 3 4 5 6 7 SCLK Instruction SI tSUS Instruction During Suspend 75H Figure 39.b. Program/Erase Suspend Instruction (QPI Mode) /CS tSUS 0 Mode 3 SCLK 1 Mode 3 Mode 0 Mode 0 Instruction 75H SI (IO0) SO (IO1) /WP (IO2) /HOLD (IO3) Accept instructions The Write Status Registers instruction (01h) and Erase instructions (20h, 52h, D8h, C7h, 60h, 44h) are not allowed during Erase Suspend. Erase Suspend is valid only during the Sector or Block erase operation. If written during the Chip Erase operation, the Erase Suspend instruction is ignored. The Write Status Registers instruction (01h), and Program instructions (02h, 42h, 32h, F2h) are not allowed during Program Suspend. Program Suspend is valid only during the Page Program operation. Write status register operation can't be suspended. Table 11, Readable or Erasable Area of Memory While a Program Operation is Suspended Readable or Erasable Region Of Memory Array All but the Page being programmed All but the Page being programmed All but the Page being programmed Suspended operation Page Program Fast Page Program Quad Page Program Note1: If read the page being programmed, read instruction will be executed, but the data output may be wrong. Note2: If erase a sector/block that including the page being programmed, the erase instruction will be ignored. Apr 2021 Rev 2.1 64 / 81 Instructions Description BY25Q80BS Table 12, Readable or Programmable Area of Memory While an Erase Operation is Suspended Readable or Programmable Region Of Memory Array All but the Big Block(4Mbit) being Erased All but the Big Block(4Mbit) being Erased All but the Big Block(4Mbit) being Erased Suspended operation Sector Erase(4KB) Block Erase(32KB) Block Erase(64KB) Note3: If read data from the same Big Block(4Mbit), read instruction will be executed, but the data output may be wrong. Note4: If program a page in the same sector/block, the program instruction will be ignored. Note5: If program a page in other sector/block in the same big block(4Mbit), the program instruction will be executed, but it may be timeout, or the data after program may be wrong. Apr 2021 Rev 2.1 65 / 81 Instructions Description 7.4.9 BY25Q80BS Erase / Program Resume (7AH) The Erase/Program Resume instruction “7Ah” must be written to resume the Sector or Block Erase operation or the Page Program operation after an Erase/Program Susp end. The Resume instruction “7AH” will be accepted by the device only if the SUS bit in the Status Register equals to 1 and the WIP bit equals to 0. After the Resume instruction is issued the SUS bit will be cleared from 1 to 0 immediately, the WIP bit will be set from 0 to 1 within 200 ns and the Sector or Block will complete the erase operation or the page will complete the program operation. If the SUS bit equals to 0 or the WIP bit equals to 1, the Resume instruction “7Ah” will be ignored by the device. The Erase/Program Resume instruction sequence is shown in Figure 40.a (SPI mode) & Figure 40.b (QPI mode). Figure 40.a. Erase/Program Resume Command Sequence (SPI mode) /CS 0 1 2 3 4 5 6 7 SCLK Instruction SI 7AH SO High_Z Figure 40.b. Program/Erase Resume Instruction (QPI Mode) /CS SCLK Mode 3 Mode 0 0 1 Mode 3 Mode 0 Instruction SI (IO0) 7AH SO (IO1) /WP (IO2) /HOLD (IO3) Resume previously suspended Program or Erase Apr 2021 Rev 2.1 66 / 81 Electrical Characteristics BY25Q80BS 8. Electrical Characteristics 8.1 Absolute Maximum Ratings PARAMETERS SYMBOL Supply Voltage VCC Voltage Applied to Any Pin VIO Transient Voltage on any Pin VIOT Storage Temperature TSTG Electrostatic Discharge Voltage VESD CONDITIONS RANGE UNIT –0.5 to 4 V Relative to Ground –0.5 to 4 V
BY25Q80BSTIG(R) 价格&库存
很抱歉,暂时无法提供与“BY25Q80BSTIG(R)”相匹配的价格&库存,您可以联系我们找货
BY25Q80BSTIG(R)
    • 1+0.91999
