Shenzhen Orient Components Co ., Ltd
OR-3H4
ORIENT
Photo coupler
Product Data Sheet
Part Number:
OR-3H4
Customer:
Date:
SHENZHEN ORIENT COMPONENTS CO.,LTD.
Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD
TEL:0755-29681816
FAX:0755-29681200
www.orient-opto.com
Copyright© 2020 Orient .All rights Reserved
1
V11
OR-3H4
1. Features
(1)
(2)
(3)
(4)
(5)
Current transfer ratio(CTR) : MIN. 20% at IF = ±1mA, VCE = 5V, Ta=25 ℃
High input-output isolation voltage.(VISO=3,750Vrms)
BVCEO = 80V(MIN)
Operating temperature:-55℃ to 125℃
Safety approval
UL approved(No.E323844)
VDE approved(No.40029733)
CQC approved (No.CQC19001231256)
(6) In compliance with RoHS, REACH standards
(7) MSL Class Ⅰ
2. Instructions
The OR-3H4 series device contains two infrared led and a photo transistor
detector.They are encapsulated in a 4-pin SOP, free of halogens and Sb2O3
3. Application Range
(1) Hybrid substrates that require high density mounting
(2) Programmable controller
(3) System apparatus,measuring instruments
4. Max Absolute rated Value (Normal Temperature=25℃)
Parameter
Symbol
Rated Value
Unit
Forward Current
IF
50
mA
Peak forward current(t=10us)
IFM
1
A
Reverse Voltage
VR
6
V
Power Dissipation
P
65
mW
Junction Temperature
Tj
125
Collector and emitter Voltage
VCEO
80
VECO
V
Emitter and collector Voltage
7
Collector Current
IC
50
mA
Power Dissipation
PC
150
mW
Tj
125
Total Power Dissipation
Ptot
200
mW
*1 Insulation Voltage
Viso
3750
Vrms
Operating Temperature
Topr
-55 to +125
Storage Temperature
Tstg
-55 to +150
*2 Soldering Temperature
Tsol
260
Input
Output
2
V11
OR-3H4
*1. AC For 1 Minute, R.H. = 40 ~ 60%
Isolation voltage shall be measured using the following method.
(1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side.
(2) The isolation voltage tester with zero-cross circuit shall be used.
(3) The waveform of applied voltage shall be a sine wave.
*2.soldering time is 10 seconds.
5. Opto-electronic Characteristics(Normal Temperature=25℃)
Parameter
Input
Symbol
Min
Typ.*
Max
Unit
Forward Voltage
VF
1.2
1.4
V
Terminal Capacitance
Ct
60
pF
Collector Dark Current
ICEO
100
nA
BVCEO
80
V
BVECO
7
V
*1 Current Transfer Ratio
CTR
Collector Current
IC
2
40
mA
Collector-Emitter
Saturation
Voltage
VCE(sat)
0.4
V
IF=±8mA
IC= 2.4mA
Insulation Impedance
Riso
Ω
DC500V
40~60%R.H.
Floating Capacitance
Cf
0.8
1
pF
V=0, f=1MHz
Response Time
tr
3
18
μs
Descend Time
tf
4
18
μs
Collector-Emitter Breakdown Voltage
Output
Emitter-Collector Breakdown Voltage
Transforming
Characteristics
5×1010 1×1011
Condition
IF=±20mA
V=0, f=1KHz
VCE=20V,IF=0mA
IC=0.1mA IF=0mA
IE=0.1mA IF=0mA
IF=±1mA
VCE=5V
VCE=10V
IC=2mA
RL=100Ω
Current Conversion Ratio = IC / IF × 100%
3
V11
OR-3H4
6. Rank table of current transfer ratio CTR
MODEL NO.
CTR Rank
Min.
Max.
NO mark
A
50
250
B
100
400
C
100
200
GR
100
300
OR-3H4
Unit
Condition
Unit
IF=±1mA, VCE=5V, Ta=25℃
IF=±5mA, VCE=5V, Ta=25℃
7. Order Information
Part Number
OR-3H4W-X-Y-Z
Note
W = CTR Rank (A, B, C, GR or none)
X = Tape and reel option (TP or TP1).
Y = ‘V’ code for VDE safety (This options is not necessary).
Z = ‘G’ code for Halogen free.
* VDE Code can be selected.
Option
Description
Packing quantity
TP
Surface mount lead form (low profile) + TP tape & reel option
3000 units per reel
TP1
Surface mount lead form (low profile) + TP1 tape & reel option
3000 units per reel
4
V11
OR-3H4
8. Naming Rule
1.
Manufacturer : ORIENT.
2.
Part Number : 3H4.
3.
Rank Code
4.
Year Code
5.
Week Code
6.
VDE Code
7.
HF Code ‘G’: Halogen Free.
8.
Anode.
: CTR Rank
: '0' means '2020' and so on.
: 01 means the first week, 02 means the second week and so on.
. (Optional)
5
V11
OR-3H4
9. Outer Dimension
10. Recommended Foot Print Patterns (Mount Pad) (unit:mm)
6
V11
OR-3H4
11. Taping Dimensions
(1)OR-3H4-TP
(2)OR-3H4-TP1
type
Symbol
Dimensions: mm (in.)
bandwidth
W
12±0.3 (0.47)
pitch
P0
4±0.1 (0.15)
F
5.5±0.1 (0.217)
P2
2±0.1 (0.079)
P1
8±0.1 (0.315)
pitch
interval
Encapsulation type
TP/TP1
Quantity (pieces)
3000
7
V11
OR-3H4
12. Package Dimension
(1) package dimension
Packing Information
Packing type
Reel type
Tape Width
12mm
Qty per Reel
3,000pcs
Small box (inner) Dimension
345*345*45mm
Large box (Outer) Dimension
480x360x360mm
Max qty per small box
6,000pcs
Max qty per large box
60,000pcs
(2)Packing Label Sample
Note:
1.
2.
Material Code :Product ID.
P/N :Contents with "Order
Information" in the specification.
3. Lot No. :Product data.
4. D/C :Product weeks.
5. Quantity :Packaging quantity.
8
V11
OR-3H4
13. Reliability Test
NO.
1
ITEMS
RSH
耐焊接热
Reliability Testing
QTY.
(Pcs)
22
Condition
260±5℃
Process
Device
Standard
锡炉
JESD22-A106
高温烤箱
测试仪
JESD22-A103
低温箱
测试仪
JESD22-A119
300
cycle
冷热冲击机
JESD22-A104
300
cycle
冷热冲击机
JESD22-A106
高温烤箱
测试仪、老
化电路板
JESD22-A108
ESD静电测
试仪
JESD22-A114
锡炉
JESD22-B102
高温烤箱
,测试仪
JESD22-A103
恒温恒湿
机,测试仪
JESD22-A101
压力锅
JESD22-A102
10s/3 次
168 hrs
2
HTSL
高温存储
77
125℃
500 hrs
1000 hrs
168 hrs
3
LTSL
低温存储
77
-55℃
500 hrs
1000 hrs
TC
4
温度循环
5
温度冲击
6
7
8
9
10
11
TS
HTOL
高温操作
ESD-HBM
人体模式
SD
可焊性
HTRB
高温反向偏压
H3TRB
温湿度反向偏
压,寿命试验
Autoclave
压力锅
77
77
77
H:125℃ 15min
∫5min
L:-55℃ 15min
H:100℃ 5min
∫15s
L:-40℃ 5min
110°C
IF=10mA
Vce=5V
168 hrs
500 hrs
1000 hrs
22
≥8KV 1Cycle
1次
22
Pb-free
245±5℃
5S/1次
77
HTRB
@125℃
Vce=80v
77
77
H3TRB
85℃,85%RH
Vce=80v
Ta=121
℃,100%RH,2atm
168 hrs
500 hrs
1000 hrs
168 hrs
500 hrs
1000 hrs
96hrs
9
V11
OR-3H4
14. Temperature Profile Of Soldering
(1)IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown
below. Do not solder more than three times.
Profile item
Conditions
Preheat
- Temperature Min (T Smin )
150˚C
- Temperature Max (T Smax )
200˚C
- Time (min to max) (ts)
90±30 sec
Soldering zone
- Temperature (TL )
217˚C
- Time (t L )
60 sec
Peak Temperature
260˚C
Peak Temperature time
20 sec
Ramp-up rate
3˚C / sec max.
Ramp-down rate from peak temperature
3~6˚C / sec
Reflow times
≤3
10
V11
OR-3H4
(2)Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature
260+0/-5˚C
Time
10 sec
Preheat temperature
25 to 140˚C
Preheat time
30 to 80 sec
(3)Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature
380+0/-5˚C
Time
3 sec max
11
V11
OR-3H4
15. Characteristics Curve
12
V11
13
OR-3H4
V11
14
OR-3H4
V11
很抱歉,暂时无法提供与“OR-3H4B-TP-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.52690
- 200+0.34100
- 1500+0.29590
- 3000+0.26180
- 国内价格
- 5+0.46749
- 20+0.42625
- 100+0.38500
- 500+0.34375
- 1000+0.32450
- 2000+0.31075
- 国内价格
- 5+0.51225
- 50+0.40079
- 150+0.34506
- 500+0.30327
- 3000+0.28847
- 6000+0.27173
