TLP181GB-S
TLP181GB-S
    UMW(友台)
    SOP-4
    光电耦合器 If=50mA Vr=5V Pc=150mW
TLP181GB-S 数据手册
UMW R UMW TLP181 OFFICE MACHINE PROGRAMMABLE CONTROLLERS AC/DC-INPUT MODULE TELECOMMUNICATION The UMW MINI FLAT COUPLER TLP181 is a small outline coupler, suitable for surface mount assembly. TLP181 consist of a photo transistor optically coupled to a gallium arsenide infrared emitting diode in a four lead plastic DIP package. • Collector-Emitter Voltage : 80V(Min.) • Current Transfer Ratio Rank GB • Isolation Voltage : 50%(Min.) : 100%(Min.) : 3750Vnns(Min.) • UL Recognized : UL1577, File No. E492440 1: Anode 3: Cathode 4: Emitter 6: Collector www.umw-ic.com 1 友台半导体有限公司 UMW R UMW TLP181 CURRENT TRANSFER RATIO TYPE CLASSIFICATION *1 TLP181 �URRENT TRANSFER RATIO(%) (Ir,/ IF) IF=5mA,VcE=5V,Ta=25°C MARKING OF CLASSIFICATION MIN. MAX. (None) 50 600 BLANK,Y,Y曰G,G•,B,B•,GB Rank Y 50 150 Y,y ■ Rank GR 100 300 G,G• Rank BL 200 600 B,B ■ Rank GB 100 600 G,G•,B,B•,GB *1 : EX,Rank GB : UMW TLP181GB www.umw-ic.com 2 友台半导体有限公司 UMW R UMW TLP181 MAXIMUM RATINGS (Ta= 25 °C) SYMBOL CHARACTERISTIC Forward Current IF Forward Current Detating L1IF/ oc 目占 Pulse Forward Current lFP VR Tj Reverse Voltage Junction Temperature Collector-Emitter Voltage 恳 且 仁 VcEO VECO Emitter-Collector Voltage Collector Current Ic Pc Collector Power Dissipation (1 Circuit) Collector Power Dissipation Derating (1 Circuit Ta�25°0) L1Pc1 °c Ti Tstg Junction Temperature Storage Temperature Range 。 T Dr Tsol Operating Temperature Range Lead Soldering Temperature Total Package Power Dissipation 旰 丛"f/ °C Total Package Power Dissipation Derating (Ta�25°C) Isolation Voltage Note 1 (Note 1) BVg RATING 50 -0.7 (Ta;;;; 邸 UNIT oc mA ) 1 (lOOµs pulse, lOOpps) mA/ °C A 5 125 V oc 80 V 7 V mA 50 150 mW -1.5 mW/ °C 125 oc -55~125 oc 260 (10s) oc oc -55~100 mW 200 -2.0 3750 (AC, lmin., RH�60%) mW/ °C Vrrns Device considered a two-terminal device : Pin 1, 3 shorted together and pins 4, 6 shorted together www.umw-ic.com 3 友台半导体有限公司 UMW R UMW TLP181 INDIVIDUAL ELECTRICAL CHARACTERISTICS (Ta= 25 °C) CHARACTERISTIC Forward Voltage VF Reverse Current IR CT Capacitance I 届仁 SYMBOL TEST CONDITION IF=lOmA VR=5V MIN. TYP. MAX. UNIT 1.0 V=O, f=lMHz 1.15 1.3 V 10 µA pF 30 Collector-Emitter Breakdown Voltage IV(BR)CEO Ic=0.5mA 80 V Emitter-Collector Breakdown Voltage K7°(BR)ECO 玩=O.lmA 7 V Collector Dark Current Capacitance (Collector to Emitter) ICEO CcE VcE=48V, (Ambient Light Below 1000 lx) VcE=48V, Ta=85°C, (Ambient Light Below 1000 lx) V=O, f=lMHz 0.01 (2) 0.1 (10) µA 2 (4) 50 (50) µA pF 10 COUPLED ELECTRICAL CHARACTERISTICS (Ta= 25°C) CHARACTERISTIC Current Transfer Ratio Saturated CTR Collector-Emitter Saturation Voltage Off-State Collector Current SYMBOL Ic/IF Ic/IF(sat) TEST CONDITION IF=5mA, VcE=5V Rank GB IF=lmA, VcE=0.4V Rank GB MIN. TYP. MAX. UNIT 50 600 100 600 60 0.4 VCE(sat) Ic=0.2mA, IF=lmA Rank GB IC(o仔) % 30 Ic=2.4mA, IF=8mA % V 0.2 0.4 VF=0.7V, VcE=48V 1 10 µA ISOLATION CHARACTERISTICS (Ta= 25 ° C) CHARACTERISTIC SYMBOL TEST CONDITION Capacitance (Input to Output) Cs Vg=OV, f=lMHz Isolation Resistance Rs Vg=500V Isolation Voltage BVg AC, 1 minute www.umw-ic.com MIN. TYP. MAX. UNIT 0.8 pF 5Xl0 1 0 10 1 4 n 3750 AC, 1 second, in oil 10000 DC, 1 minute, in oil 10000 4 Vrms Vdc 友台半导体有限公司 UMW R UMW TLP181 SWIC HING CHARACTERISTICS (Ta = 25 °C) CHARACTERISTIC Rise Time Fall Time SYMBOL tr 坏 Turn-on Time ton Turn-off Time toff Turn-on Time Storage Time turn-off Time tQN ts tQFF MIN. TYP. MAX. UN吓 TEST CONDITION 2 3 Vcc=lOV, Ic=2mA RL=lOOD 3 µs 3 2 RL=1.9k0. (Fig.1) Vcc=5V, IF=16mA 25 µs 40 RECOMMENDED OPERATING CONDITIONS CHARACTERISTIC Supply Voltage Forward Current Collector Current Operating Temperature SYMBOL vee IF Ic Topr MIN. -25 TYP. MAX. UNIT 5 48 16 20 V mA 1 10 85 mA oc Fig.1 SWITCHING TIME TEST CIRCUIT IF vee 4.5V 0.5V V eE www.umw-ic.com 5 友台半导体有限公司 UMW R UMW TLP181 m V 弓 3g SOI) )』 仁ag m g V仁Q 1'1V (言 、、 I 的) g 20) 。 -20 0 20 40 60 80 9 IO oO O Od 6N另凸F d 、、 0o.L S 斗o AMBIENT TEMPERATURE Ta ('C) 仁 001 00 0 0 1 3 10-2 3 0 20 40 60 80 100 120 IF - VF / '/ J J i3i I(ann Gt )V ilA\ 丘 uI110 I11 V g 10• I I 0.01 I' =as•c二 芍 巨 25屯 1.2 0.8 0.4 2 。 0.001 1.6 FORWARD VOLTAGE VF (V) IFP - VFP . 3 2 4 2 0 2 、、 .... 6 1 I I 1L ) 100I a 30 归 Na -- 3 o曰a 』 aA 0.3 0.5 1 3 5 10 30 50 FORWARD CURRENT IF (mA) , ,1 50I II , i f I 6 10 如 / 3 8 0 S'lfld -0. :300 05 1 - �i--.. 2 1 6JAg 2 w4AV 仁 33E 』g8 mHU V 总 nE 30VLI OA9 I V匕笑 匕 t,.VF/t,.Ta - IF I /'』 0.1 DUTY CYCLE RATIO炖 -3.2 I 』 10-l 3 、 I II 30) -• 。 10I 50) 10 II 40 100 、、 100) 3 10 ( V日)仑 IIL N3aan3o avAao』 臼gU氐 、 300) 、 80 v PULSE WIDTH至100匹 Ta=26°C 500) I AMBIENT TEMPERATURE Ta (屯) IFP - DR ) ,f 120 -20 120 100 、 160 ll 60) PC - Ta 200 凶ma 目 匕 m IF - Ta 1001 ,. J , I 1.0 PULSE WIDTHa.10严 REPE'I士l'IVE FREQUENCY= lOOHz Ta=25"C 1.4 1.8 2.2 PULSE FORWARD VOLTAGE VFP v 2.6 3.0 (V) 仑 n o www.umw-ic.com 6 友台半导体有限公司 UMW R UMW TLP181 Ic - VcE 片 98 i .J L 3 售 9aoX 3日〉9 一 巨g g9a89n8 Ta = 25"C 叫 2 4 6 Ic - VcE 30 Ta = 25屯 20 10 10 8 0.2 COLLECTOR-EMITTER VOLTAGE VcE (V) IC - IF 60) 30) 111 >§ 亏s. 矗 . SAMPLE B Ill 0.3 0.6 1 3 10 6 30 60 I I 11 300) SAMPLE A VEI 0巨W子I 去兰乏 I 云)- I 』 9 9 1 。。 4衫 ) 50) ) \ 、 . , ', r'/ ) 一及 20 , r-...... I ........ , 24 10 5= , , I / / I 三 / '/ -歹 40 60 80 100 心 、 、 1, /V —VCE = lOV ---- VcE = 5V - • - VcE = 0.4V , 18 、、 `` . SAMPLE B " � 多 .. ·r- 1.0 AMBIENT TEMPERATURE Ta (屯) \ 妒 � V , 10 •I �,.. .`一 , I/ Ta 26屯 500) / /V o 1 ICIIF - IF 100 , 儿 YI VcE 48V 31 FORWARD CURRENT IF (mA) I o 1 1 ln} ). J 0.8 10°I1 21 VcE lOV ---- Vc = 5V E -·- Vc = 0.4V E 。 1 35 0 ; 0 I • 臼 mm 0:i 111 va竺0R ) 3TI O3 4 ,,, 干 ,: J.l I � 1 ' ..� 1111 MPLE A ·-, o 0 53 1 3 9 g 29a3自 目 匕8 - 8 I )( o:.I : : m a1 ( W1 100) 0.6 ICEO - Ta 10 I --·- .... Ta-25°C 0.4 COLLECTOR-EMITTER VOLTAGE VcE (V) 0.3 0.5 1 3 5 10 30 50 FORWARD CURRENT IF (mA) www.umw-ic.com 7 友台半导体有限公司 UMW R UMW TLP181 4 3 o VCE (sat) - Ta 0 91 lmA 50 41 0 o 义。 -20 0 20 40 60 80 AMBIENT TEMPERATURE Ta ("C) 100 10 i t-- 卜- I- -0.51, 0.33 1 1 L..-- 匕 I/ 1,1 20 ...._0.5 40 '-- 一户 60 80 AMBIENT TEMPERATURE Ta (°C) 100 50I 30I ta 7 � ----- 1 1 www.umw-ic.com toFF _一 ts 10I , I 勺N 0.5, 3 、 SWITCHING TIME - Ta 160 5 : -20 - 1 6 v ./ , �.. / ( S n) :i! NLLONIHOJ. Ut\. S ( s l'l rl ) :ii I J.DNIH:J J. I A\ S 7 。 50I , I 。 — vcc = 5V I 10I -- r--i-..... Ta = 25屯 IF = 16mA 300I 30I I , SWITCHING TIME - RL 10001 500I 」 ;I 0.1 _. . 10 5 8 0 o . 3ao5 :l!TIOO u1 IL zaat 2 1 o ) 1� 上 VCE 5V 叶 。1 30 ..... 2V 1 o -- i--. IC - Ta 100 IF = 0.2mA o ( A) ( l UB ) :il :::l A民 W .5 OA 巴匕 N3士Q5 m TO9 VSH: .L lfi 巳11 No- Ic = 0.3 toN 3 5 10 LOAD RESISTANCE RL 30 (kO) 50 0.1 100 8 -20 0 20 40 lF = 16mA vcc = 5V RL = l.9U 60 80 AMBIENT TEMPERATURE Ta (°C) 100 友台半导体有限公司
TLP181GB-S 价格&库存
很抱歉,暂时无法提供与“TLP181GB-S”相匹配的价格&库存,您可以联系我们找货
TLP181GB-S
  • 5+0.46474
  • 20+0.42350
  • 100+0.38225
  • 500+0.34100
  • 1000+0.32175
  • 2000+0.30800
库存:5517
