TP301121180
TP301121180
    ROCPU(台普)
    插件,12.8x5.7mm
    检测开关 插件,12.8x5.7mm 单刀双掷 操作寿命1万次
TP301121180 数据手册
A B D C E F G 0.50 ± ] 5 6 0[0.4 8 . 1 1 1 3-0.90 [0.035] 5.08 [0.200] 3.80 [0.150] 技术参数值(Technical Parameters) 1.电气额定值(Electrical Rating):1A 250VAC 2.温度等级(Temperature grade):T85 3.动作力(OF):1.0±0.4N 4.动作行程(PT):≤0.8mm 5.接触电阻(Contact Resistance):≤50mΩ 6.绝缘电阻(Insulation Resistance):≥100MΩ 7.耐压(Withstand Voltage):端-端500VAC/5S, 漏电流5mA,端-壳1500VAC/5S,漏电流5mA。 8.电气寿命(Electrical Service Life):10,000 9.耐漏电起痕(Proof Tracking Index):175V 9.80[0.386]±0.50(FP) 0[0 . 2.00[0.079] Ø2 .0 6.50 [0.256] 0.50 [0.020] 3.60 [0.142] 2 1.50 [0.059] 07 9] 1 5.08 [0.200] 5.80 [0.228] 6.50 [0.256]±0.10 2 12.80[0.504] 3 电路简图 5 压柄 Pressing handle 1 不锈钢 SUS 4 塑盖 Plastic cover 1 PBT 3 动触片组件 Contact parts 1 铍青铜+银丝 Beryllium bronze + silver wire 2 推动子 Push parts 1 尼龙66 PA66 1 底座组件 Bottom assembly 1 PBT+黄铜+银丝 PBT + brass + silver wire 序号 Serial number 零件名称 Part name 数量 quantity 材质 Texture of material Z1 Z2 S 4 L N UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED DATE 2019 CHECKED BY APPROVAL B 黑色 black 灰色 grey 4 备注 REMARK PRODUCT NAME: TOLERANCE A3 5 MM 3 COCO ALEN MODEL NO: TP301121180 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E F G 5
TP301121180 价格&库存
很抱歉,暂时无法提供与“TP301121180”相匹配的价格&库存,您可以联系我们找货
TP301121180
    • 1+3.21840
    • 10+2.52720
    • 30+2.22480
    • 100+1.85760
    库存:403
