CB2402
CB2402
    CHIPBETTER(芯百特)
    QFN16_3X3MM_EP
    2.4GHZ WLAN发送/接收FEM QFN16_3X3MM_EP
CB2402 数据手册
PRELIMINARY CB2402 2.4GHZ WLAN TRANSMIT/RECEIVE FEM DESCRIPTION AL The CB2402 is a fully integrated, single-chip, single die RF Front-end Integrated Circuit. which incorporates all the RF functionality needed for today’s wireless communications. NF ID EN TI The CB2402 architecture integrates the PA, LNA, Transmit and Receive switching circuitry, the associated matching network, and the harmonic filter all in a CMOS single-chip device. The CB2402 is designed for use in 802.11b/g/n applications operating at 2.4GHz. Combining superior performance, high sensitivity and efficiency, low noise, small form factor, and low cost, the CB2402 is the ideal solution for single antenna applications, and the ideal building block for MIMO applications. CB2402 has simple and low-voltage CMOS control logic, and requires minimal external components for system implementation. The PA power detector circuit is also integrated. BLOCK DIAGRAM GND 17 VDD 16 GND 15 VDD 14 DNC 13 12 1 GND RX 11 2 GND GND 10 3 ANT GND 9 4 CO TX 5 TXEN 6 RXEN 7 DET GND 8 GND TE R Figure 1. CB2402 Block Diagram FEATURES   BE T  2.4GHz ISM, Single Chip, Single-Die RF FrontEnd IC Separate TX and RX Transceiver Port and Single Antenna Port 2.4GHz Power Amplifier with Low-Pass Harmonic Filter Low Noise Amplifier Transmit / Receive Switch Circuitry High Transmit Signal Linearity Meeting Standards for OFDM and CCK Modulation Integrated Power Detector for Transmit Power Monitor and Control Compatible with Low Voltage (1.2V) CMOS Control Logic or levels up to VDD ESD Protection Circuitry on All Ports DC Decoupled RF Ports Internal RF Decoupling on All VDD Bias Pins Low Noise Figure for Receive Channels    IP  CH      Chipbetter Microelectronics Inc.        High Power Capability for Received Signals Very Low DC Power Consumption Full On-chip Matching and Decoupling Circuitry Minimal External Components Required 50-Ohm Input / Output Matching Market Proven CMOS Technology 3 x 3 x 0.55mm Small Outline QFN-16 Package with Exposed Ground Pad APPLICATIONS       - 1 / 11 - 802.11b/g/n Embedded Applications 802.11b/g/n NIC PC Card 802.11b/g/n Multimedia Applications 802.11b/g/n Mobile Platforms Other 2.4GHz Transceivers 802.11b/g/n Access Point www.chipbetter.com PRELIMINARY CB2402 2.4GHZ WLAN TRANSMIT/RECEIVE FEM PIN-OUT DIAGRAM 15 16 1 GND 2 17 4 TX 13 GND 3 GND 14 DNC 6 5 TXEN 12 GND 11 GND 10 ANT 9 GND NF ID EN TI RX VDD AL GND VDD RXEN 7 8 DET GND Figure 2. CB2402 Pin out (Top View) PIN ASSIGNMENTS Name RX Description Received RF Signal from the LNA to the Transceiver; DC Shorted to GND 2, 3, 8, 9,11,12, 15, 17 4 5 6 7 GND TX TXEN RXEN DET Ground – Must be connected to Ground in the Application Circuit Transmitted RF signal from the Transceiver to the PA: DC Shorted to GND CMOS Input to Enable the PA CMOS Input to Enable the LNA Analog Voltage Proportional to the PA Power Output Antenna port RF Signal from the PA or RF Signal Applied to the LNA; DC Shorted to GND Reserved – Do Not Connect in the Application Circuit Voltage Supply Connection DNC VDD CH IP BE T 13 14,16 ANT TE R 10 CO Pin 1 Chipbetter Microelectronics Inc. - 2 / 11 - www.chipbetter.com PRELIMINARY CB2402 2.4GHZ WLAN TRANSMIT/RECEIVE FEM CB2402 ABSOLUTE MAXIMUM RATINGS Storage Ambient Temperature Minimum 0 0 All Operating Modes When RX is “ON” No RF and DC Voltages Applied Appropriate care required according to JEDEC Standards Human Body Model Maximum 4.5 3.6 350 1 +10 +5 Units V V mA uA dBm dBm +150 °C AL Conditions All VDD Pins Through 1Kohm resistor Through VDD Pins when TX is “ON” NF ID EN TI Parameters DC VDD Voltage Supply DC Control Pin Voltage DC VDD Current Consumption DC Control Pin Current Consumption TX RF Input Power ANT RF Input Power -50 ESD Voltage (HBM) 1000 V NOTE: Sustained operation at or above the Absolute Maximum Ratings for any single or combinations of the above parameters may result in permanent damage to the device and is not recommended. All Maximum RF Input Power Ratings assume 50Ohm terminal impedance. RECOMMENDED OPERATING CONDITIONS Conditions CO All VDD Pins All Operating Modes Minimum 2.4 2.7 1.2 Typical 3.3 2.0 0 1 Maximum 2.5 3.6 VDD 0.3 5 0.8 50 -40 +85 Units GHz V V V μA μA µsec Ω °C CH IP BE T TE R Parameters Operating Frequency DC VDD Voltage Supply Control Voltage “High” Control Voltage “Low” Control Pin Current Consumption DC Shutdown Current PA Turn On/Off Time Input/Output Single-Ended Impedance Operating Ambient Temperature Chipbetter Microelectronics Inc. - 3 / 11 - www.chipbetter.com PRELIMINARY CB2402 2.4GHZ WLAN TRANSMIT/RECEIVE FEM CB2402 ELECTRICAL SPECIFICATIONS1 +20 16 POUT = +20dBm at ANT 2.525 -35 -35 -10 -10 50 -7 GHz dBm dBm dBm dBm dB dB mA mA mV dBc dBc dB dB Ohm dBm +22 +21 16 17 26 26.5 95 160 2500 All non-harmonically related spurs less than -43 dBm/Hz 4:1 6:1 N/A No damage 8:1 10:1 N/A Parameters Standby Mode: DC Shutdown Current TX-ANT Insertion Loss (S21) TX Port Return Loss (S11) ANT-RX Insertion Loss (S21) RX Port Return Loss (S22) Transmit-Receive Switching Time Shut-Down and “ON” State Switching Time Min Test Condition CH Pin < -20dBm From TX Port Pin < -20dBm From RX Port - 4 / 11 - Typ. 2.4 Max Units 2.525 GHz dB dB dB dB Ohm mA dBm Max Units 5 uA dB dB dB dB ns ns 10 3.5 -10 -10 50 10mA 2 TE R BE T Units 250 Min IP Max 2.4 Parameters Test Condition Receive Mode:(VDD=3.3V; T=+25℃) Operating Frequency Band All RF Pins Terminated by 50 Ohms Gain Noise Figure Input Return Loss Output Return Loss RF Port Impedance RX Quiescent Current No RF Applied Input P1dB No RF Applied Chipbetter Microelectronics Inc. Typ. NF ID EN TI All RF Pins Terminated by 50 Ohms CW 1Mbps CCK, Mask Compliance 54Mbps OFDM, EVM< -33dB at ANT 54Mbps OFDM, EVM 1.2V) 2. “0” denotes low voltage stage (
CB2402 价格&库存
很抱歉,暂时无法提供与“CB2402”相匹配的价格&库存,您可以联系我们找货
