CB5717
CB5717
    CHIPBETTER(芯百特)
    QFN16_EP
    5GHZ WLAN前端模块
CB5717 数据手册
PRELIMINARY CB5717 5 GHz WLAN Front-End Module DESCRIPTION EN TI A L CB5717 is a highly integrated RF Front-End Integrated Circuit which incorporates key RF functionality needed for IEEE 802.11a/n/ac WLAN systems operating in the 5.15-5.9GHz range. CB5717 integrates a high-efficiency high-linearity power amplifier (PA), a low noise amplifier (LNA) with bypass, the associated matching network, LO rejection, and harmonic filters all in one device. CB5717 has simple and low-voltage control logic, and requires minimal external components. A power detector is also integrated for accurate monitoring of output power from the PA. CB5717 is assembled in a compact, low-profile 2.5x2.5x0.55mm 16-lead QFN package. CB5717 is the ideal RF front-end solution for implementing 5GHz high-power WLAN systems supporting multiple standards including 802.11ac. RX 2 ANT 14 13 NF ID 1 15 12 GND 11 VCC CO GND GND 16 RX_EN LNA_EN BLOCK DIAGRAM 10 VCC VDD 4 9 N/C 8 TX 7 GND 6 TE R 5 TX_EN 3 VDET GND Figure 1. CB5717 Block Diagram BE T FEATURES  Integrated high performance 5GHz PA, LNA with bypass and T/R switch Fully-matched input and output Integrated power detector Transmit gain: 28.5dB Receive gain: 10dB Output power: +20dBm @ 1.8% EVM, VHT80/MCS9, 5V Output power: +21dBm @ 3% EVM, HT40/MCS7, 5V Integrated 2.4GHz Notch Filter ESD protection circuitry on all PINs DC decoupled RF ports Minimal external components required Small package: QFN16 2.5mm x 2.5mm x0.55mm (MSL3, 260℃ per JEDEC J-STD-020) RoHS and REACH Compliant IP      CH        APPLICATIONS Chipbetter Microelectronics Inc.         - 1 / 11 - 802.11ac Wi-Fi Devices Tablets / MIDs Wi-Fi Media Gateways Consumer Electronics s Notebook / Netbook / Ultrabook Access Points / Routers Set Top Boxes / Wireless IPTVs Other 5GHz ISM Platforms www.chipbetter.com PRELIMINARY CB5717 5 GHz WLAN Front-End Module 3 VDD 4 RX_EN GND ANT AL GND 13 12 GND 11 VCC 10 VCC 9 VDET 5 6 7 8 TX 2 14 NF ID EN TI RX 15 GND 1 16 TX_EN GND LNA_EN PIN-OUT DIAGRAM N/C Figure 2. CB5717 Pin out (Top View) Name VDD VDET TX_EN TX NC VCC ANT RX_EN LNA_EN Description Ground – Must Be Connected to GND in the Application Circuit RF Output Port from LNA or Bypass LNA/Switch/Regulator Supply Voltage Analog Voltage Proportional to the PA Power Output Input to Control TX Enable RF Input Port from the Transceiver Internally Not Connected PA Supply Voltage Antenna Port RF Signal from the PA or RF Signal Applied to the LNA Input to Control RX Enable Input to Control LNA Enable or Bypass Mode CH IP BE T 4 5 6 8 9 10,11 13 15 16 GND RX TE R Pin 1,3,7,12,14 2 CO PIN ASSIGNMENTS Chipbetter Microelectronics Inc. - 2 / 11 - www.chipbetter.com PRELIMINARY CB5717 5 GHz WLAN Front-End Module ABSOLUTE MAXIMUM RATINGS Test Condition VDD and VCC Minimum 4.5 2.0 0 Typical 5.0 3.0 Maximum 5.5 0.3 50 -40 85 Units V V V uA °C CH IP BE T TE R CO Parameters DC Supply Voltage Control Pin Voltage “High” Control Pin Voltage “Low” Control Pin DC Current Operation Temperature NF ID RECOMMENDED OPERATING CONDITIONS EN TI A L Parameters Test Condition Minimum Maximum Units DC Supply Voltage VDD and VCC 0 6.0 V Control Pin Voltage All Control Pins 0 3.6 V DC Current Consumption 600 mA Input Power (50 ohm load) +5 dBm Storage Temperature -40 150 °C Operation Temperature -40 85 °C Junction Temperature 150 °C ESD All PINs, HBM 1000 V NOTE: Sustained operation at or above the Absolute Maximum Ratings for any one or combinations of the above parameters may result in permanent damage to the device and is not recommended. All Maximum RF Input Power Ratings assume 50-ohm terminal impedance. Chipbetter Microelectronics Inc. - 3 / 11 - www.chipbetter.com PRELIMINARY CB5717 5 GHz WLAN Front-End Module CB5717 ELECTRICAL SPECIFICATIONS1 No Permanent Damage @ Pin =+10dBm 10:1 VSWR CH IP BE T TE R Ruggedness CO NF ID EN TI A L Parameters Symbol Test Condition Min Typ. Max Units Transmit Mode:(VDD=VCC= 5V, TX_EN=2.9V, RX_EN=LNA_EN=0V, T = 25℃, Unless Otherwise Noted) Frequency f Main Frequency Band 5.15 5.90 GHz Gain G 26.0 28.5 dB Gain Flatness Over Any 80MHz Bandwidth -0.5 +0.5 dB With -45dB EVM source VHT160/MCS9, 1.8% DEVM, Preamble only +19.0 +19.5 VHT80/MCS9, 1.8% DEVM, Preamble only Output Power POUT +19.5 +20.0 dBm HT40/MCS7, 3% DEVM, Preamble Only +20.0 +21.0 HT20/MCS0, Mask Compliance +22.0 +23.0 CW Signal Current ICC @ No RF 305 335 mA Consumption @+20dBm 340 375 HT20/MCS0 Signal @ +23dBm dBm Harmonics 2fo 2nd harmonics -31 /MHz 3fo 3rd harmonics -42 Isolation ISO From ANT to either TX or RX Pin -27 -30 dB Input Return Loss |S11| -14 -17 dB Output Return Loss |S22| -12 -15 dB VDET @ No RF 0.25 0.30 Power Detector V Output @+20dBm 0.35 0.40 PA Switching Time tSW ShutdownTX 400 500 ns All non-harmonically related outputs less Stability 6:1 VSWR than -36dBm/MHz Chipbetter Microelectronics Inc. - 4 / 11 - www.chipbetter.com PRELIMINARY CB5717 5 GHz WLAN Front-End Module EN TI A L Parameters Symbol Test Condition Min Typ. Max Units Receive LNA Mode:(VDD=VCC= 5V, TX_EN=0V, RX_EN=LNA_EN=3V, T = 25℃, Unless Otherwise Noted) Frequency f Main Frequency Band 5.15 5.90 GHz Gain G 8 10 dB Input 1dB Input -2.0 -0.4 dBm Compression Point P1dB Gain Flatness Over any 80MHz Bandwidth -0.5 +0.5 dB Noise Figure NF 3.5 4.0 dB Input Return Loss |S11| -11 -13 dB Output Return Loss |S22| L -4 -6 dB 3rd Order Input IIP3 0 dBm Intercept Point Switching Time tSW LNATX 800 ns Current IDD @ No RF 15 25 mA Consumption TE R CO NF ID Parameters Symbol Test Condition Min Typ. Max Units Receive Bypass Mode:(VDD=VCC= 5V, TX_EN=LNA_EN=0V, RX_EN=3V, T = 25℃, Unless Otherwise Noted) Frequency f Main Frequency Band 5.15 5.90 GHz Insertion Loss I.L. 9 12 dB Input 1dB Input +8 dBm Compression Point P1dB Input Return Loss |S11| -10 -12 dB Output Return Loss |S22| -8 -10 dB 3rd Order Input IIP3 +15 dBm Intercept Point Switching Time tSW Bypass  LNA 100 200 ns Current IDD @ No RF 13 18 uA Consumption LOGIC TRUTH TABLE LNA_EN 0 0 1 0 All Others RX_EN 0 0 1 1 CH IP BE T Mode TX_EN Shutdown Mode 0 Transmit Mode 1 LNA Low NF Receive Mode 0 Bypass Receive Mode 0 Unsupported NOTE: 1. “1” denotes high voltage state (=3.0V); 2. “0” denotes low voltage state (
CB5717 价格&库存
很抱歉,暂时无法提供与“CB5717”相匹配的价格&库存,您可以联系我们找货
