CBG9326
CBG9326
    CHIPBETTER(芯百特)
    EMSOP8_3X3MM_EP
    Gaas HBT MMIC DRIVER AMPLIFIER,30-4.5 GHZ
CBG9326 数据手册
PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz DESCRIPTION The device is provided in an EMSOP8 package. BLOCK DIAGRAM VPD 1 GND 2 RFIN 3 GND 4 NF ID EN TI AL The CBG9326 is high efficiency GaAs HBT MMIC driver amplifier which operates between 3.0 and 4.5 GHz. The amplifier is packaged in a low cost, surface mount 8 leaded package with an exposed base for improved RF and thermal performance. The amplifier provides 19 dB of gain and +25 dBm of saturated power from a +3.3V supply voltage,and 23dB of gain and +26dBm of saturated power from a +5V supply voltage. Power down capability is available to conserve current consumption when the amplifier is not in use. Internal circuit matching was optimized to provide greater than 40% PAE. RX OUT 8 VCC 7 GND 6 RFOUT 5 GND CO GND TE R Figure 1. CBG9326 Block Diagram FEATURES Psat Output Power: +26 dBm PAE > 40% Output IP3: +32 dBm High Gain: 24 dB Vs: +5V Ultra-Small Package: EMSOP8 (MSL1, 260℃ per JEDEC J-STD-020)    Microwave Radios Broadband Radio Systems Wireless Local Loop Driver Amplifier CH IP BE T       APPLICATIONS Chipbetter Microelectronics Inc. - 1 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz RX OUT VCC 2 7 GND RFIN 3 6 RFOUT GND 4 5 GND 1 GND NF ID EN TI 8 VPD AL PIN-OUT DIAGRAM GND Figure 2. CBG9326 Pin out (Top View) PIN ASSIGNMENTS Description Control Voltage Ground Pin 5 6 Name GND RFOUT Description Ground RF Output Power 3 RFIN RF Input Power 7 GND Ground 4 GND Ground 8 VCC Collector Bias Voltage CO Name VPD GND CH IP BE T TE R Pin 1 2 Chipbetter Microelectronics Inc. - 2 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz ABSOLUTE MAXIMUM RATINGS Parameters Collector Bias Voltage (Vcc) Control Voltage Range (Vpd) VCC VPD PIN Symbol Min Max +5.5 +5.5 +15 Units V V dBm CH IP BE T TE R CO NF ID EN TI AL RF Input Power (RFIN)(Vs = Vpd = +5Vdc) Supply current ICC 800 mA Storage temperature Tst -40 +150 °C Operating Temperature TC -40 +85 Junction Temperature TJ +150 °C Continuous Pdiss (T = 85 °C) (derate 14 mW/°C above 85 °C) 0.92 W Electrostatic discharge: Human Body Model (HBM) 1000 V NOTE: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device. ESD HANDLING: Although this device is designed to be as robust as possible, electrostatic discharge (ESD) can damage this device. This device must be protected at all times from ESD when handling or transporting. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD handling precautions should be used at all times. Chipbetter Microelectronics Inc. - 3 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz CBG9326 ELECTRICAL SPECIFICATIONS1 Parameters Symbol Test Condition (TC = +25℃, Input/Output Load = 50 Ω, Unless Otherwise Noted) Frequency f Main frequency band Input return loss |S11| Output return loss |S22| Output Power for 1dB Compression P1dB Saturated Output Power Psat PAE@Psat Output Third Order Intercept Noise Figure PAE IP3 NF Pin = -30dBm Pin = -30dBm CW, Pin =8dBm Vpd = 0V Icq Vpd = 3.3V/Vcc = 3.3V Vpd = 5V/Vcc = 5V MHz 20 21.5 5V 21 24 28 3.3V 9 5V 11 3.3V 7 5V 6 dB dB 23 24 5V 21 24 3.3V 24 25 25.5 27 35 42 30.5 5 Ipd tON/tOFF dB dBm dBm 50 % dBm dB 0 1 uA 20 25 mA 90 95 7 10 mA mA ns CH IP BE T TE R Control Current Switching time 4500 16 5V @Psat Units 3.3V CW, Reference to small signal gain 3.3V CO Supply Current Pin = -30dBm 3000 Max AL G Typ. NF ID EN TI Gain Min Chipbetter Microelectronics Inc. - 4 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz PERFORMANCE PLOTS (Test conditions unless otherwise noted: Temp. = +25 °C, Input/Output Load = 50 Ω) Gain 30 3.3V 5V -10 -15 -20 3.00 24 21 18 3.25 3.50 3.75 4.00 4.25 4.50 Frequency (GHz) 15 3.00 3.25 3.50 4.25 4.50 10 3.3V 5V CO 3.3V 5V -5 Noise 8 -10 6 4 TE R -15 -20 3.00 3.25 3.50 3.75 4.00 4.25 2 4.50 0 3.00 BE T Frequency (GHz) P1dB 3.25 3.50 3.75 4.00 4.25 4.50 Frequency(GHz) Psat 30 30 3.3V 5V 3.3V 5V 28 Psat (dBm) IP 25 P1dB (dBm) 4.00 Noise Figure 0 CH 3.75 Frequency (GHz) Output Return Loss Output Return Loss (dB) NF ID EN TI -5 3.3V 5V 27 Gain(dB) Input Return Loss (dB) 0 AL Input Return Loss 20 26 24 15 22 10 3.00 3.25 3.50 3.75 4.00 4.25 20 3.00 4.50 Frequency (GHz) Chipbetter Microelectronics Inc. 3.25 3.50 3.75 4.00 4.25 4.50 Frequncy (GHz) - 5 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz U3 1 2 3 4 VCC VPD GND CBG9326 GND RFOUT RFIN GND GND 9 2 1 3 2 GND VPD 1 R1 0R VCC C1 330pF 8 C2 330pF L1 5.1nH C5 2.2uF 7 6 C4 5 C3 0.7pF 4pF 3 VPD 2 1 2 3 4 5 6 7 8 9 10 NF ID EN TI VCC AL EVALUATION BOARD SCHEMATIC 1 U2 CH IP BE T TE R CO Figure 3. CBG9326 Evaluation Board Schematic Chipbetter Microelectronics Inc. - 6 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz NF ID EN TI AL EVALUATION BOARD ASSEMBLY DRAWING Figure 4. CBG9326 Evaluation Board Assembly Drawing BILL OF MATERIALS Value 330pF 330pF 0.7pF 4pF 2.2 μF 5.1nH Size 0402 0402 0402 0402 0805 0402 CO Component Vendor Murata Murata Murata Murata Murata Murata Part Number CH IP BE T TE R C1 C2 C3, C4 C5 L1 Chipbetter Microelectronics Inc. - 7 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz PCB LAND PATTERN 4.40 0.45 1.45 1.75 2.40 0.00 0.00 3.60 Land X1 Land Y1 Tab Land X2 Tab Land Y2 Silkscreen R1 Silkscreen R2 Courtyard V1 Courtyard V2 2 3 AL 2 3 4 5 6 7 8 9 1 8 9 7 6 NF ID EN TI Dimensions 1 B X1 A X2 Y2 Y1 4 5 C CH IP BE T TE R CO Figure 5. CBG9326 PCB Layout Footprint Chipbetter Microelectronics Inc. - 8 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz TYPICAL PART MARKING CBG9326 XXXXXX YYWWVC AL Pin 1 Indicator Part Number NF ID EN TI ChipBetter Lot Code Data Code: YY=Calendar Year WW=Work Week Figure 6. Typical Part Marking for the CBG9326 PACKAGE DIMENSIONS (All Dimensions in mm): 1 P CH 7 6 5 L A H T K .031 0.80 .016 0.40 .200 5.08 .184 4.68 .070[1.78] MAX 3 EXPOED GROUND PADDLE MUST BE CONNECTED TO RF/DC GROUND .037 0.95 .029 0.75 .043[1.10] MAX 9 4 IP .122 3.10 .114 2.90 2 3 8° 0° 4 BE T .122 3.10 .114 2.90 8 Tt W TE R L T W Tt Wt A B M K Wt Y1 B Pin Cout 0.65 8 8 Min Max 4.68 5.08 0.40 0.80 0.22 0.38 2.41 1.78 2.90 3.10 2.90 3.10 1.10 0.00 CO Pitch (P) Pin Package .005 0.13 .000 0.00 .0256[0.65] TYP .015 0.38 .009 0.22 TYP .009 0.22 .003 0.08 .095[2.41] MAX NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS AREIN INCHES [MILLIMETERS] 3. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.15mm PER SIDE 4. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE 5. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND Figure 7. CBG9326 Package Dimension Chipbetter Microelectronics Inc. - 9 / 10 - www.chipbetter.com PRELIMINARY CBG9326 GaAs HBT MMIC DRIVER AMPLIFIER, 3.0 - 4.5 GHz CONTACT INFORMATION For the latest specifications, additional product information, worldwide sales and distribution locations: AL Web: www.chipbetter.com Tel: 0755-26654180 NF ID EN TI DISCLAIMERS ChipBetter reserves the right to make changes without further notice to specifications and product descriptions in this document to improve reliability, function or design. ChipBetter does not assume any liability arising out of the application or use of information or product described in this document. Neither does ChipBetter convey any license under its intellectual property rights nor licenses to any of circuits described in this document to any third party. The information in this document is believed to be accurate and reliable and is provided on an "as is" basis, without any express or implied warranty. Any information given in this document does not constitute any warranty of merchantability or fitness for a particular use. The operation of this product is subject to the user's implementation and design practices. ChipBetter products are not designed or intended for use in life support equipment, devices or systems, or other critical applications, and are not authorized or warranted for such use. CH IP BE T TE R CO Copyright of ChipBetter Microelectronics Co, Ltd. All rights reserved. Chipbetter Microelectronics Inc. - 10 / 10 - www.chipbetter.com
CBG9326 价格&库存
很抱歉,暂时无法提供与“CBG9326”相匹配的价格&库存,您可以联系我们找货
