XKB Connectivity
Doc. No.
DC Socket-122
Page No.
1/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Product Specification
Title:DC Socket
1. SCOPE(适用范围)
This specification covers the performance, tests and quality requirements for the DC Socket .
本规范涵盖了DC Socket 的性能、测试和质量要求。)
2. PRODUCT DESCRIPTION( 产品描述)
DESCRIPTION(描述)
Part Number(料号)
DC连接器 贴片W9.3xD8xH5.3 4P ,内芯1.3
DC-0330-1.3-SMT
3. APPLICABLE DOCUMENT (适用文件)
The following documents form a part of this specification to the extent specified herein. In the event of
conflict between the requirements of this specification and the product drawing, the product drawing
shall take precedence. In the event of conflict between the requirements of this specification and the
referenced documents, this specification shall take
precedence.(下列文件构成本规范的一部分,在此规定的范围内。本规范要求与产品图纸有冲突
时,以产品图纸为准。如果本规范的要求与参考文件发生冲突,应以本规范为准。)
4. REQUIREMENTS (要求)
4.1. Design and Structure (设计和结构)
Product shall be of the design, structure and physical dimensions specified on the applicable product
drawing.(产品的设计、结构和物理尺寸参考所适用的产品图纸)
4.2. Materials/ Finish (材料/表面处理)
Materials used in the structure of product shall be as specified on the applicable product drawing.
(产品结构中使用的材料参考所适用的产品图纸)
4.3. Ratings (额定功率)
Item(项目)
Standard(标准)
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
2/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
Rated Voltage (Maximum)额定电压
50V DC
Rated Current (Maximum)额定电流
1A
Operating temperature range工作温度范围
Storage Temperature Range储存温度范围
-20℃~+70℃
From -20 to +70 egree centigrade
-20℃~+70℃
From -20 to +70 degree centigrade
5.0 TEST STANDARD (测试条件)
5.1 Unless otherwise specified, the standard range of atmospheric conditions for making
measurements and tests are as follows (除另有说明外,用以进行测量和测试的标准
环境条件范围如下)
Ambient temperature(环境温度): 5℃ to 35℃
Normal humidity (正常湿度): 45% to 85%
Air pressure (气压): 86Kpa to 106Kpa
5.2 However if doubt arises on the decision based on the measured Values under the
above-mentioned Conditions.The following conditions shall be employed:
(但是在对判定产生疑问时,按下述状态实施)
Temperature (温度):20±2℃
Relative humidity (相对湿度):65±5%
6. PERFORMANCE AND TEST DESCRIPTION (性能和测试类型)
6.1 APPEARANCE (外观)
ITEM DESCRIPTION(类型)
TEST CONDITION(测试条件)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
3/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
1
Appearance
外观
Visual. 目视
Should not have any flaw
Scratch discoloration and
crushed.无任何裂痕、刮伤、
污染和变形
6.2 ELECTRICAL (电气)
ITEM DESCRIPTION(类型) TEST CONDITION (测试条件)
1
Contact resistance.
接触电阻
Measured at low current (100mA or
less).(在低电流(≤100mA)条件下测试.
REQUIREMENT(要求)
30 mΩ Max.
2
3
Insulation Resistance.
绝缘电阻
Apply a voltage of 100V DC for 1 MIN to
following portions after which measurement
shall be made输入DC
100V,一分钟,按以下接触方法测试 :
(1). Between body and conductor.
插座体与排脚之间
(2). Between conductors not to be contact.
不接触的排脚之间
(3). Between conductors not to be when plug
is inserted DC 100V 1 MIN.
插头插入时不接触的排脚之间
Dielectric strength.
(耐电压)
AC 500V ims(50~60Hz)for 1 MIN trip
current: 0.5mA 输入AC
250V(50~60Hz)/min电压一分钟,漏电电流为:
0.5mA
There shall be no
插座体与排脚之间
breakdown.
无击穿、闪烁现象
不接触的排脚之间
is inserted DC 500V 1 MIN.
插头插入时不接触的排脚之间
100 M min.
6.3 MECHANICAL (机械)
1
Insertion Force
(插入力)
REQUIREMENT(要求)
Measurement shall be made after connecting
and disconnecting using stand plug gauge 3
3~30N
times . 依据标准的PLUG
GAUGE做第3次插拔后测试
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
4/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
2
3
4
Extraction Force
(拔出力)
3~30N
times .依据标准的PLUG
GAUGE做第3次插拔后测试
Terminal Strength
(端子强度)
There shall be no damage to
the terminal such as
A static load of 5N(0.5kgf)/m shall be applied
cracks,Looseness or play
to the tip of the terminal for 1 MIN in any
electrical ,And mechanical
direction.
characteristics shall be
向排脚先端的任意一个方向施加1分钟5N(0.5k
satisfied.在排脚中没有裂开,
gf)的力度
松动等异常,满足于机械,电
气性能
Life Test
(寿命测试)
Without load 无负荷 :
Connection and disconnection shall be made
with the mating plug and jack for 5ˈ000
cycles at a speed of 10 to 25 cycles/MIN.
将结合了的标准Plug(尽量要近于中心的)在
1分钟以10~25的速度,进行5ˈ000次的插入,
拔出
Load 负荷 :
At rating condition ( Non-Inductive Load )
connection and disconnection shall be made
1,000 cycles at a speed 10 to 20 cycles / MIN.
以定格状态(无诱导负荷)在1分钟内以10~20
次的速度进行1,000次插入,拔出
Contact
resistance
接触电阻:30 mΩ Max.
Extraction
Force
拔出力:3~30N
Mechanical and electrical
characteristics
shall
be
satisfied.
满足于机械和电气性能
6.4 ENVIRONMENTAL (环境)
1
Solder ability
(可焊性 )
Immerse the solder pin of the connector in
solder bath at 245±5℃ for
3±0.5sec.
After dipped the pin in the flux 5sec.
将端子脚浸入助焊剂中5秒,然后将端子脚浸
入245±5℃的锡炉中3±0.5秒
REQUIREMENT(要求)
Solder wetting: 95% of
immersed area must show
voids, Pin holes.
锡附着的面积应超过浸入表面
积的95%以上
The contact of terminal shall be tested
2
Resistance to Soldering
Heat
(焊锡耐热性)
resistance to soldering heat in the following
conditions. After Resistance to soldering
heat test Contact Resistance.
端子应在下列条件下做耐吃锡性试验,焊锡 scratch and crack.
耐热性后试接触阻抗
无任何裂痕、刮伤和破裂
In case of solder iron (2 time) 电烙铁(两次)
Temperature温度:350℃+/-5℃
Time 时间: 5s+/-1s
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
5/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
3
Humidity Test
(耐湿测试)
4
Heat Resistance Test
(耐热测试)
5
Cold Resistance Test
(耐寒测试)
The jack shall be stored at a temperature of
40±2℃ and a humidity of 90% to 96% for
96 Hr,Then the jack shall be maintained at
stand atmospheric condition for 1 Hr for
other procedures.
放置于40±2℃的相应湿度为90~96%
Hr环境中96小时后,再将样品放在正常环境
中1小时后进行测试
There shall be no damage on
appearance.
The jack shall be stored at a temperature of satisfied.
外观无异常,满足于机械和电
70±2℃ for 96 Hours,And then the jack
气性能
shall be maintained at stand atmospheric
condition for 1 Hr for other procedures.
放置于70±2℃
中96小时后,再将样品放在正常环境中1小时
后进行测试
temperature of -25±3℃ for 96 hours
and then it shall be subjected to the
controlled recovery conditions for 1
hour after which. 放置于-25±3℃
时后进行测试
The jack shall be subjected to 5 cycles of the
following conditions showed in the
figure,And shall returned allowed to
remain in room ambient condition for 30
minutes.
将插座以下列条件作10个循环,然后放回
室内环境60分钟
6
Temperature Cycling
Test (温度循环测试)
appearance.
characteristics
shall
be
satisfied.
外观无异常,满足于机械和电
气性能
There shall be no deformation
or cracks in molded part.
产品不能变形与破裂
Insertion&extraction force : 3
to 30N.
Contact resistance接触电阻:
30 mΩ Max.
绝缘电阻: 100 M min.
Dielectric strength voltage
耐电压:500V AC/MIN
(Between
terminals端子之间)
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
6/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
7
Salt Spray Test
(盐雾试验)
1. Testing bath 测试容器 : The temperature
shall 35±2℃ in the ambient of the specimen
during the test.
在测试过程中,产品周围环境温度35±2℃
2. Spray apparatus喷雾设备 : The
apparatus shall capable of producing fine
dense mist uniformly.盐雾均匀喷出
3. Salt water盐水 :The concentration of the
salt water shall adjusted at 5±1% weight
ratio at 35±2℃ .
盐水要在35±2℃温度条件下,调整在5±1%
比例范围内
4. Testing time测试时间 : 24±0.5 hours.
After washed in water . The sample shall
left alone for 1 or 2 hours in a room
ambient .
清洗后,样品在室内要单独放置1至2个小时
The jack shall be subjected to 6 cycles of the
following conditions showed in the figure.
And then shall returned and allowed to
remain in room ambient for 30 minutes.
将插座以下列条件作5个循环,然后放回室
内环境30分钟。
8
Heat Shock Test
(热冲击测试)
Appearance shall no
extremely rust. And
contacting portions should
such that they will work
without hindrance for
practical.
表面不能有严重的腐蚀,接触
部分要不防碍正常使用
产品不能变形与破裂
to 30N.
30 mΩ Max.
绝缘电阻: 100 M min.
耐电压:500V AC/MIN
(Between
terminals端子之间)
XKB Connectivity
Doc. No.
DC Socket-122
Page No.
7/8
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
122
Approved by
Mei Chen
Title:DC Socket
For the product of SMT , type solder
according to the following conditions
对于 SMT 产品,请按以下条件进行焊接
9
Caution: the condition mentioned
above is a temperature on the PWB
Automatic Flow
surface on which parts are mounted.
Soldering (自动焊接) There are cases where PWB
temperature greatly differs from
switch's surface temperature
depending on PWB material, size,
thickness, etc. The switch's surface
temperature shall not allowed to
exceed 260℃
注意:以上提及的条件是零部件上 PWB
表面的温度,由于 PWB
的材料、尺寸、厚度等不同,PWB
从开关表面获得的温度也会有很大产不同
,因此,千万小心不要让开关表面温度超
scratch and crack
无任何裂痕、刮伤和破裂
No visual damage to
insulator.
绝缘体不得有严重变形
过 260℃
Rev.
Description
Date revised
Created/
Revised by
01
New Release
2021/04/30
Josephine Lin
很抱歉,暂时无法提供与“DC-0330-1.3-SMT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.44537
- 50+1.14772
- 150+1.02017
- 700+0.83085
- 2800+0.76000
- 4900+0.71756
- 国内价格
- 1+0.33033
- 30+0.31878
- 100+0.29568
- 500+0.27258
- 1000+0.26103
- 国内价格
- 5+1.61930
- 50+1.28590
- 150+1.14300
