Shenzhen Orient Technology Co ., Ltd
OR-357
1. Features
Current transfer ratio(CTR : MIN. 50% at IF = 5mA, VCE = 5V, Ta=25 ℃)
High input -output isolation voltage (VISO=3,750Vrms)
High collector-emitter voltage (VCEO = 35V)
SOP-4 package
-55 ℃ to 115 ℃
RoHS Compliance
4
3
1
2
2. Instructions
The OR-357 series device consists of an infrared led, phototransistor detector.
They are encapsulated in a 4 pin SOP encapsulation.
Pin pitch of OR-357 is 2.54mm
3. Application Range
1 Anode 2 Cathode
3 Emitter 4 Collector
Hybrid substrates that require high density mounting.
Programmable controllers
System appliance, measuring instruments
4. Max Absolute rated Value (Normal Temperature=25℃)
Parameter
Input
Output
Symbol
Rated Value
Unit
Forward Current
IF
50
mA
Junction Temperature
TJ
125
Reverse Voltage
VR
6
V
Consume Power
P
100
mW
Collector and emitter Voltage
VCEO
35
Emitter and collector Voltage
VECO
6
Collector Current
IC
50
mA
Consume Power
PC
150
mW
Total Consume Power
Ptot
170
mW
*1 Insulation Voltage
Viso
3750
Vrms
Working Temperature
Topr
-55 to + 115
Deposit Temperature
Tstg
-55 to + 150
*2 Soldering Temperature
Tsol
260
Copyright© 2019 Orient Tech Corporation.All rights Reserved
2
V
A0
OR-357
*1. AC Test, 1 minute, humidity = 40~60%
Insulation test method as below:
(1) Short circuit both terminals of photocoupler.
(2) No Current when testing insulation voltage.
(3) Adding sine wave voltage when testing.
*2. soldering time is 10 seconds.
5. Opto-electronic Characteristics
Parameter
Input
Output
Transforming
Characteristics
Symbol
Condition
Min
Typ.*
Max
Unit
Forward Current
VF
IF=20mA
1.2
1.4
V
Reverse Voltage
IR
VR=4V
10
μA
Collector capacitance
Ct
V=0, f=1KHz
30
250
pF
Collector to emitter Current
ICEO
100
nA
Collector and Emitter
attenuation Voltage
BVCEO
VCE=20V,
IF=0mA
IC=0.1mA
IF=0mA
35
V
Emitter and Collector
attenuation Voltage
BVECO
6
V
*1.Current conversion ratio
CTR
50
600
Collector Current
IC
2.5
30
mA
Saturation Voltage
VCE(sat)
0.2
V
Insulation Impedance
Riso
DC500V
5×1010 1×1011
40~60%R.H.
Ω
Floating Capacitance
Cf
V=0, f=1MHz
0.6
1
pF
Response Time
tr
4
18
μs
Descend Time
tf
VCC=2V,
IC=2mA
RL=100Ω
3
18
μs
IE=0.01mA
IF=0mA
IF=5mA
VCE=5V
IF=20mA
IC= 1mA
Current Conversion Ratio = IC / IF × 100%
3
A0
OR-357
6. Rank table of current transfer ratio CTR(tolerance:±3%)
CTR Rank
Min.
Max.
A
80
160
B
130
260
C
200
400
D
300
600
E
50
150
No mark
50
600
Condition
IF=5mA, VCE=5V, Ta=25℃
7. Naming Rule
2.YEAR CODE
1.ORIENT
3.WEEK CODE
2.RANK
OR
357
5.Halogen free
3.YEAR CODE
4.WEEK CODE
4.RANK
1. ORIENT
2. Rank shall be or shall not be marked.
3. Year Code, Example : 2010 = 10
4. Work Week Ranging from ‘01’ to ‘53’
5. “●” indicates halogen free option.
4
A0
OR-357
8. Outer Dimension
pin No. and Internal
connection diagram
4
3
2.54±0.25
OR
357
1
2
3
4
Anode
Cathode
Emitter
Collector
4.4±0.25
2
1
3.85±0.3
0.10±0.1
2.00±0.2
5.30±0.3
+0.2
7.00- 0.7
0.4±0.1
9. Recommended Foot Print Patterns (Mount Pad)
unit:mm
5
A0
OR-357
10. Taping Dimensions
(1) OR-357-TP
(2) OR-357-TP1
Description
Symbol
Dimension in mm(inch)
Tape wide
W
12±0.3(0.472)
Pitch of sprocket holes
P0
4±0.1(0.157)
F
5.5±0.1(0.217)
P2
2±0.1(0.079)
P1
8±0.1(0.315)
Distance of compartment
to compartment
Package Type
OR-357 series
Quantities(pcs)
3000
6
A0
OR-357
11. Temperature Profile Of Soldering
(1)IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown
below. Do not solder more than three times.
Profile item
Conditions
Preheat
- Temperature Min (T Smin )
150˚C
- Temperature Max (T Smax )
200˚C
- Time (min to max) (ts)
90±30 sec
Soldering zone
- Temperature (TL )
217˚C
- Time (t L )
60 sec
Peak Temperature
260˚C
Ramp-up rate
3˚C / sec max.
3˚C / sec max.
3~6˚C / sec
7
A0
OR-357
(2)Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature
260+0/-5˚C
Time
10 sec
Preheat temperature
5 to 140˚C
Preheat time
30 to 80 sec
(3)Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature
380+0/-5˚C
Time
3 sec max
8
A0
OR-357
12. Characteristics Curve
9
A0
10
OR-357
A0
很抱歉,暂时无法提供与“OR-357C”相匹配的价格&库存,您可以联系我们找货
