Doc. No.
DM-A0162-11
Page No.
1/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
XKB Connectivity
Product Specification
Title:MICRO SWITCH 微动开关
1. SCOPE(适用范围)
This specification covers the performance, tests and quality requirements for the micro switch.
本规范涵盖了盖微动开关的性能、测试和质量要求。XKB Connectivity)
2. PRODUCT DESCRIPTION( 产品描述)
DESCRIPTION(描述)
W12.7xD5.7xH6.6小型微动开关 0.5A 125V
带滚轮,柄长11.5MM,直脚
Part Number(料号)
DM1-115GP-1
3. APPLICABLE DOCUMENT (适用文件)
The following documents form a part of this specification to the extent specified herein. In the event of
conflict between the requirements of this specification and the product drawing, the product drawing
shall take precedence. In the event of conflict between the requirements of this specification and the
referenced documents, this specification shall take
precedence.(下列文件构成本规范的一部分,在此规定的范围内。本规范要求与产品图纸有冲突
时,以产品图纸为准。如果本规范的要求与参考文件发生冲突,应以本规范为准。)
4. REQUIREMENTS (要求)
4.1. Design and Structure (XKB CONNECTIVITY设计和结构)
Product shall be of the design, structure and physical dimensions specified on the applicable product
drawing.(产品的设计、结构和物理尺寸参考所适用的产品图纸)
4.2. Materials/ Finish (XKB CONNECTIVITY材料/表面处理)
Materials used in the structure of product shall be as specified on the applicable product drawing.
(产品结构中使用的材料参考所适用的产品图纸)
4.3. Ratings (额定功率)
XKB Connectivity
Doc. No.
DM-A0162-11
Page No.
2/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
Item(项目)
Standard(标准)
Rated Voltage (Maximum)额定电压
30V DC
Rated Current (Maximum)额定电流
1A/3A
Operating temperature range工作温度范围
Storage Temperature Range储存温度范围
-40℃ to +85℃
From-40℃ to +85℃ degree centigrade
-40℃~+85℃
From -40 to +85 degree centigrade
5. TEST STANDARD (测试条件)
5.1 Unless otherwise specified, the standard range of atmospheric conditions for making
measurements and tests are as follows (除另有说明外,用以进行测量和测试的标准
环境条件范围如下)
Ambient temperature(环境温度): 5℃ to 35℃
Normal humidity (正常湿度): 45% to 85%
Air pressure (气压): 86Kpa to 106Kpa
5.2 However if doubt arises on the decision based on the measured Values under the
above-mentioned Conditions.The following conditions shall be employed:
(但是在对判定产生疑问时,按下述状态实施)
Temperature (温度):20±2℃
Relative humidity (相对湿度):65±5%
8. PERFORMANCE AND TEST DESCRIPTION (性能和测试类型)
8.1 APPEARANCE (外观)
ITEM
DESCRIPTION(类型)
TEST CONDITION(测试条件)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
DM-A0162-11
Page No.
3/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
1
Appearance
(外观)
Visual.(目视)
Should not have any flaw
Scratch discoloration and
crushed(无任何裂痕、刮伤
、污染和变形)
8.2 ELECTRICAL (电气)
ITEM DESCRIPTION(类型)
2
3
4
TEST CONDITION (测试条件)
To be measure with AC 1KHz±200Hz
Low level contact
(Max 20mv,Max 50mA)or 0.1mA,12V
resistance. (接触电阻) DC (在1千赫兹±200赫兹AC
mV,或0.1mA,12V DC电流下测试)
REQUIREMENT(要求)
100 mΩ Max.
Insulation
Resistance.
(绝缘电阻)
Measurements shall be made following
application of DC100V potential between
terminals and between individual
terminals and frame for one minute.
(在端子与端子之间,端子与外壳之间施加
DC100V,一分钟,测量相邻两端的绝缘电阻)
100 M min.
Dielectric strength.
(耐电压)
AC 250 V (50Hz or60Hz) shall be
applied between terminals and between
individual terminals and frame for one
minute.(在端子与端子之间,端子与外壳之
间施加 AC250V(50HZ-60HZ))
There shall be no
breakdown.
(无击穿、闪烁现象)
8.3 MECHANICAL (机械)
5
6
Place the switch such that the direction
of switch operation is vertical and then
gradually increase the load applied to
the center of the stem, the maximum
XKB Connectivity
Actuating
Force load required for the stem to come to a
stop shall be measured.
(动作力)
(开关的动作方向为垂直放置开关向推柄中心
逐渐地增加负荷直到推柄停止时所测量的最大
负荷)
Terminal strength
端子强度
A static load of 400gf shall be applied
To the terminal for 1 minute in any
direction.(在排脚前端任意一个方向加
400gf 力度测试,时间为1分钟)
REQUIREMENT(要求)
30±30g
Electrical characteristics
shall be satisfied without
damage or excessive
looseness of terminals.
(在排脚中没有裂开.松动等
异常,
满足于机械、电器性能)
XKB Connectivity
Doc. No.
DM-A0162-11
Page No.
4/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
7
Displacement of
actuator (knob)
推柄强度
Fixed switch so that the switch is
perpendicular to the direction of
operation and exerts 2 Kgf force in the
opposite direction of the push handle
for 1
minute.(固定开关,使开关与操作方向垂直
,以推柄动作方向反方向施加2Kgf力持续 1
分钟)
The handle is not
seriously deformed and
can work
normally.(柄部无严重变形,
可以正常工作)
(1) Contact Resistance
( 接触电阻):
100mΩMAX.
(2) Insulation resistance (
绝缘电阻):100M Ω MIN.
Endurance without loading: A switch
shall be subjected to 50,000 cycles at
8
LIFE TEST
寿命试验
a speed of 15 to 18 cycles per minute
without loading.
(在负荷的条件下以每分钟 15~18
回的速度进行 50,000 次的测试)
(3) Dielectric strength(
耐电压): AC 250V,1
minute.
(4) Operating
force(作动力): 30±30g
(5) Without damage to
parts arcing or
breakdown etc. (
测试后外表无损伤,并且满足
机械性能)
8.4 ENVIRONMENTAL (环境)
ITEM
9
DESCRIPTION(类型)
Solder ability
(可焊性 )
Test temperature:245±5℃ Test
time :5sec During test,the stick
detect temperature in the
oven.Then switch terminal soak in
the oven.It put 2 minute under
normal temperature after testing.
试验温度:245±5℃
试验时间:5s;试验时以测温棒侦测锡炉
温度;开关端子浸入与焊锡接触,在时间
内f
取出;测试后再常温下测试后再常温下静
止 2 分钟
REQUIREMENT(要求)
The area must be reach
90% on the surface of
switch terminal
开关端子上锡面积应达
到 90%以上
XKB Connectivity
Doc. No.
DM-A0162-11
Page No.
5/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
10
Moisture Resistance
(耐潮湿)
Following the test set forth below the
sample shall be left in normal
temperature and humidity conditions
for 30 minute before measurements
are
made:
样品按下列条件进行耐潮湿试验,试验后
在正常温度和湿度条件下放置
30分钟后测定
(1)Temperature温度: 40±2℃
(2)Relative humidity相对湿度: 90 to
95%
(3)Time时间: 48 hours
Water drops shall be removed.擦除水珠
11
TLow Temperature
Resistance 耐低温
are made:
样品按下列条件进行耐低温试验,试验后在
正常温度和湿度条件下放置 30
分钟后测定
(1)Temperature温度:-20±2℃
(2)Time时间: 96 hours
12
Heat Resistance 耐热
are made:
样品按下列条件进行耐热试验,试验后在正
常温度和湿度条件下放置30 分钟后测定
(1)Temperature温度: 80±2℃
(2) Time时间:
96 hours
XKB Connectivity
13
Salt Spray Test
盐雾试验
The salt spray test shall be
conducted at the following
conditions :
样品按下列条件进行盐雾试验
(1) Density(浓度): 溶液(5±1)% Nacl
(质量百分比)
(2)Temperature温度: 35±2℃
Time时间:
48 hours
Contact
resistance接触电阻: 100
mΩ Max. Insulation
resistance绝缘电阻 : 100
MΩ Min.
There shall be no
defects in appearance or
in the mechanical
functions
.(无论是在外观上还是在机
械功能上,都不得有任何缺
陷)
Contact
resistance接触电阻: 100
mΩ Max. Insulation
MΩ Min.
There shall be no defects
in appearance or in the
mechanical functions
.(无论是在外观上还是在机
械功能上,都不得有任何缺
陷)
Contact
resistance接触电阻: 100
mΩ Max. Insulation
MΩ Min.
.(无论是在外观上还是在机械
功能上,都不得有任何缺陷)
Appearance shall no rust,
oxidation, corrosion and
other undesirable
phenomena.(外观须无生锈
、氧化、腐蚀等不良现象)
XKB Connectivity
Doc. No.
DM-A0162-11
Page No.
6/7
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
9. SOLDERING AND CLEANING PROCESSES XKB CONNECTIVITY焊接和清洗:
9.1. Keep all switch contacts in their "OFF" position for all operations.
在所有操作过程中,请确保开关在OFF位置
9.2. Wave soldering(波峰焊): DIP Suggestions solder temperature at 260℃(500°F)
max.5 seconds . DIP型推荐焊接焊锡温度为260℃(500°F) 最多5秒
9.3. Hand soldering(手焊): Use a soldering iron of 30 watts controlled at 350℃
approximately 5 seconds. while applying solder.
使用30W烙铁控制温度在350℃,焊接时长约5秒
9.4. Reflow soldering profile(回炉焊):When the maximum temperature of the reflow
furnace is 260 °C and the temperature is 260 °c. 10 seconds MAX. (reference)
SMT型回焊炉最高温度为260℃,温度为260℃时,最长时间不超过10秒(如图)
10. PACKAGING 包装
Please refer to the packing drawing. 请参考产品包装图纸
Rev.
Description
Date revised
Created/
Revised by
01
New Release
2021/04/30
Josephine Lin
很抱歉,暂时无法提供与“DM1-115GP-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.35000
- 10+1.30000
- 100+1.15000
- 500+1.12000
- 国内价格
- 1+1.96992
- 10+1.91862
- 30+1.88784
- 100+1.85706
