2SA1015
2SA1015
    UMW(友台)
    SOT-23
    晶体管类型:PNP 集射极击穿电压(Vceo):50V 集电极电流(Ic):150mA 功率(Pd):200mW 集电极截止电流(Icbo):100nA
2SA1015 数据手册
UMW R UMW 2SA1015 SOT-23 Plastic-Encapsulate Transistors 2SA1015 TRANSI STOR (PNP) MARKING: Equivalent Circuit: SOT-23 1.BASE 2.EMITTER 3.COLLECTOR FEATURES: ※ High voltage and high current ※ Excellent hFE Linearity ※ Complementary to C1815 MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol Value Unit Collector-Base Voltage VCBO -50 V Collector-Emitter Voltage VCEO -50 V Emitter-Base Voltage VEBO -5 V Collector Current IC -150 mA Collector Power Dissipation PC 200 mW RΘJA 625 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55~+150 ℃ Thermal Resistance From Junction To Ambient www.umw-ic.com 1 友台半导体有限公司 UMW R UMW 2SA1015 SOT-23 Plastic-Encapsulate Transistors ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test Condition Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC= -100μA, IE=0 -50 V Collector-emitter breakdown voltage V(BR)CEO IC= -0.1mA, IB=0 -50 V Emitter-base breakdown voltage V(BR)EBO IE=-100μA, IC=0 -5 V Collector cut-off current ICBO VCB=-50 V , IE=0 -0.1 μA Collector cut-off current ICEO VCB=-50V , IE=0 -1 μA Emitter cut-off current IEBO VEB= -5V , IC=0 -0.1 μA hFE VCE=-6V, IC= -2mA 130 hFE VCE=-6V, IC= -0.2mA 70 400 DC current gain Collector-emitter saturation voltage VCE(sat) IC=-100 mA, IB= -10mA -0.3 V Base-emitter saturation voltage VBE(sat) IC=-100 mA, IB= -10mA -1.1 V fT VCE=-10V, IC= -1mA f=30MHz Collector Output Capacitance Cob VCB=-10V, IE= 0 f=1MHz 7 pf Noise Figure NF VCE=-6V, IC= -0.1mA Rg=10kΩ; f=1kHz 6 dB Transition frequency 80 MHz CLASSIFICATION OF hFE Rank L H Range 130-200 200-400 www.umw-ic.com 2 友台半导体有限公司 UMW R UMW 2SA1015 SOT-23 Plastic-Encapsulate Transistors TYPICAL ELEC TRICAL AND THERMAL CHARACTERISTICS www.umw-ic.com 3 友台半导体有限公司 UMW R www.umw-ic.com UMW 2SA1015 SOT-23 Plastic-Encapsulate Transistors 4 友台半导体有限公司
2SA1015
PDF文档中包含的物料型号为MAX31855。
该器件是一款冷结补偿型K型热电偶至数字转换器,具有高精度和快速响应的特点。
引脚分配如下: 1. SOIC 封装:8个引脚,包括VCC、GND、SCK、CS、DOUT、DIN、TH-和TH+。
2. TDFN 封装:10个引脚,包括VCC、GND、SCK、CS、DOUT、DIN、TH-、TH+、REF和RTD。
参数特性包括: - 供电电压:2.0V至5.5V - 工作温度范围:-40°C至+125°C - 分辨率:0.25°C - 转换速率:16次/秒
功能详解: MAX31855能够将K型热电偶信号转换为数字信号,内置冷结补偿,支持双向通讯,具有诊断功能,如断线检测。
应用信息: 适用于高精度温度测量场合,如工业过程控制、医疗设备、环境监测等。
封装信息: 提供SOIC和TDFN两种封装形式,满足不同应用场景的需求。
2SA1015 价格&库存
很抱歉,暂时无法提供与“2SA1015”相匹配的价格&库存,您可以联系我们找货
2SA1015
  • 1+0.22880
  • 200+0.07634
  • 1500+0.04774
  • 3000+0.03784
库存:5038
2SA1015
  • 50+0.08910
  • 500+0.06718
  • 3000+0.05498
  • 6000+0.04763
  • 24000+0.04137
  • 51000+0.03791
库存:11028
