RY6050-ADJM5R
RY6050-ADJM5R
    RYCHIP(蕊源)
    SOT23-5
    500mA可调高速低功率LDO
RY6050-ADJM5R 数据手册
RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Features • • • • • • Programmable Output: Minimum can go to 0.8V Low Power Consumption: 28μA (Typ.) Low Voltage Drops: 0.15V@50mA Standby Mode: less than 0.1uA Low Temperature Coefficient Active Discharge Function • • • • • High Ripple Rejection: 70dB@1KHz (Typ.) High Input Voltage (up to 8V) Output Voltage Accuracy: Tolerance ±2% Build-in Enable / Output Current Limit SOT23-5 Package Applications • • • • Cellular Handsets Battery‐Powered Equipment Wi-Fi Router • • Hand‐Held Instruments Portable Information Application Adjustable power supply General Description The RY6050-ADJM5R is highly precise, low noise, positive voltage LDO regulators manufactured using CMOS processes. The RY6050-ADJM5R achieves high ripple rejection and low dropout and consists of a standard voltage source, an error correction, current limit, and a phase compensation circuit plus a driver transistor. External output feedback, customers can easily get the required voltage. In order to make the load current does not exceed the current capacity of the output transistor, built-in over-current protection, over temperature protection and short circuit protection. The internal op amp with advanced structure, the output capacitor can be omitted. The RY6050ADJM5R is available in SOT23-5 package. Typical Application Circuit VIN IN VOUT OUT R1 CIN 1μF~10μF ON/ OFF EN COUT FB GND CFF 10μF R2 Typical Application Circuit with FB VOUT=0.8×(1+R1/R2) Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 1 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Pin Description Pin Configuration TOP VIEW VIN 1 GND 2 EN 3 5 OUT 4 FB SOT23-5 Top Marking: 4bLL (device code: 4b, LL= lot number code) Pin Description Pin No. Pin Name Function 1 VIN Input voltage pin for the regulator. 2 GND Ground pin. 3 EN Enable Control (Active high), Driving EN over 0.9 V turns on the regulator. Driving EN below 0.4 V puts the regulator into shutdown mode. 4 FB FB pin for adjustable output option. 5 OUT Output voltage pin for the regulator. Mark Rule Mark Part No. Mode Description Package T/R Qty 4bLL 70605021 RY6050-ADJM5R RY6050-ADJM5R LDO, ADJ, 500mA, SOT23-5 SOT23-5 3000PCS Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 2 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Functional Block Diagram IN LSP OUT OTP Enable EN FB OCP GND Functional Block Diagram Specifications Absolute Maximum Ratings (1) (2) Item Min Max Unit VIN voltage 2.0 8.0 V 1.0 3.3 V VOUT voltage Output Current (3) Power dissipation 600 (4) Operating Ambient Temperature Internally Limited -40 Maximum junction temperature Storage temperature, Tstg Lead Temperature (Soldering, 10sec.) mA –50 85 °C 150 °C 85 °C 260 °C Note (1): Exceeding these ratings may damage the device. Note (2): The device is not guaranteed to function outside of its operating conditions. Note (3): IOUT=PD/(VIN-VOUT) Note (4): The maximum allowable power dissipation is a function of the maximum junction temperature, TJ(MAX), the junction-to-ambient thermal resistance, RθJA, and the ambient temperature, TA. The maximum allowable power dissipation at any ambient temperature is calculated using: PD (MAX) = (TJ(MAX) − TA)/RθJA. Exceeding the maximum allowable power dissipation causes excessive die temperature, and the regulator goes into thermal shutdown. Internal thermal shutdown circuitry protects the device from permanent damage. Thermal shutdown engages at TJ=155°C (typical) and disengages at TJ= 140°C (typical). Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 3 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Recommended Operating Conditions Item Min Max Unit –40 125 °C Operating temperature range -40 85 °C Input voltage VIN 2 6.5 V Output current 0 500 mA Operating junction temperature (1) Note (1): All limits specified at room temperature (TA = 25°C) unless otherwise specified. All room temperature limits are 100% production tested. All limits at temperature extremes are ensured through correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). Thermal Information Item Description (1)(2) Value Unit 230 °C/W RθJA Junction-to-ambient thermal resistance RθJC(top) Junction-to-case (top) thermal resistance 152 °C/W RθJB Junction-to-board thermal resistance 56 °C/W ψJT Junction-to-top characterization parameter 31 °C/W ψJB Junction-to-board characterization parameter 55 °C/W Note (1): The package thermal impedance is calculated in accordance to JESD 51-7. Note (2): Thermal Resistances were simulated on a 4-layer, JEDEC board Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 4 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Electrical Characteristics TA = 25°C, unless otherwise noted. Parameter Symbol Test Conditions Min Input Voltage VIN 2 Feedback Voltage VFB 784 Output Current IOUT VIN≥VOUT(S)+1.0V Vdrop Load Regulation 300mA 230 100mA -40°C ≤ TJ 2.5V ≤125°C 300mA 70 250 100mA 430 300mA 700 ∆𝑉𝑂𝑈𝑇 VOUT(S)+0.5 V≤VIN≤7V ∆𝑉𝐼𝑁 × 𝑉𝑂𝑈𝑇 IOUT=300mA ∆𝑉𝑂𝑈𝑇 VIN=VOUT(S)+1.0 V 𝑉𝑂𝑈𝑇 Supply Current ISS1 VIN=VOUT(S)+1.0 V Shutdown Current Ishut VIN=5V, VEN=0 Power Supply Rejection Ratio PSRR VOUT=2.5V, IOUT=20mA f = 1KHz Units 6.5 V 816 mV VIN=VOUT(S)+1.0V, ON/OFF Terminal is ON, VOUT=0V Ishort EN “High Voltage VENH EN “Low” Voltage VENL EN “High Current IENH VIN=VEN=VOUT(T)+1V EN “Low” Current IENL VIN=VOUT(T)+1V, VEN=VSS Thermal Shutdown Temperature TSD Thermal Shutdown Hysteresis ΔTSD mA mV - 0.20 0.60 %/V - 0.50 2 % - 28 - f = 10kHz Short-circuit Current Email: support@rychip.com ©RYCHIP Semiconductor Inc. Max 500 60 1.2V Line Regulations 800 100mA 3.3V Dropout Voltage VOUT=0.98VOUT (NOM) Typ. - μA 0.1 μA 70 - dB 50 - dB 500 - mA 1 V 0.5 V -0.1 0.1 μA -0.1 0.1 μA 155 °C 15 °C ILOAD =10mA http://www.rychip.com Page 5 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Typical Performance Characteristics (1) Note (1): Typical performance characteristics below based on TA = 25°C, unless otherwise noted. Load Regulation Load Regulation Load Regulation VOUT=3.3V VOUT= 2.5V VOUT=1.2V Line Regulation Line Regulation Line Regulation VOUT=3.3V VOUT=2.5V VOUT=1.2V Power Supply Rejection Ration Power Supply Rejection Ration Power Supply Rejection Ration VIN=3.3V, VOUT=1.2V, IOUT=20mA VIN=3.3V, VOUT=2.5V, IOUT=20mA VIN=5V, VOUT=3.3V, IOUT=20mA Vin Start Up EN Start Up VIN=3.3V, VOUT=2.5V, IOUT=1mA VIN=3.3V, VOUT=2.5V, IOUT=1mA Steady State VIN=3.3V, VOUT=2.5V, IOUT=350mA Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 6 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Applications Information Setting the Output Voltage RY6050-ADJM5R require an input capacitor and an output capacitor. These components are critical to the performance of the device. The output voltage can be programmed by resistor divider. 𝑉𝑂𝑈𝑇 = 𝑉𝐹𝐵 × 𝑅1 + 𝑅2 𝑅2 VOUT(V) R1(KΩ) R2(KΩ) CIN(μF) COUT(μF) CFF 1 25.00 100 1~10 10 Opt. 1.05 31.25 100 1~10 10 Opt. 1.2 50.00 100 1~10 10 Opt. 1.5 87.50 100 1~10 10 Opt. 1.8 125.00 100 1~10 10 Opt. 2.5 212.50 100 1~10 10 Opt. 2.8 250.00 100 1~10 10 Opt. 3.3 312.50 100 1~10 10 Opt. Low ESR Capacitors With the RY6050-ADJM5R, a stable output voltage is achievable even if used with low ESR capacitors as a phase compensation circuit is built-in. In order to ensure the effectiveness of the phase compensation, we suggest that an output capacitor (COUT) is connected as close as possible to the output pin (VOUT) and the GND pin. Please use an output capacitor with a capacitance value of 10uF. Also, please connect an input capacitor (CIN) of 10uF between the VIN pin and the GND pin in order to ensure a stable power input. Stable phase compensation may not be ensured if the capacitor runs out capacitance when depending on bias and temperature. In case the capacitor depends on the bias and temperature, please make sure the capacitor can ensure the actual capacitance. Current Limiter, Short-Circuit Protection The RY6050-ADJM5R includes a combination of a fixed current limiter circuit & a feedback circuit, which aid the operations of the current limiter and circuit protection. When the load current reaches the current limit level, the fixed current limiter circuit operates and output voltage drops. As a result of this drop-in output voltage, the feedback circuit operates, output voltage drops further and output current decreases. EN pin The IC's internal circuitry can be shutdown via the signal from the EN pin with the RY6050-ADJM5R. Driving EN over 1 V turns on the regulator. Driving EN below 0.5 V puts the regulator into shutdown mode. The operational logic of the IC's EN pin is selectable. Note that as the standard RY6050-ADJM5R type's regulator is 'High Active/No Pull-Down', operations will become unstable with the EN pin open. Although the EN pin is equal to an inverter input with CMOS hysteresis, with either the pull-up or pull-down options, the EN pin input current will increase when the IC is in operation. We suggest that you use this IC with either a VIN voltage or a GND voltage input at the EN pin. If this IC is used with the correct specifications for the EN pin, the operational logic is fixed and the IC will Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 7 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO operate normally. However, supply current may increase as a result of through current in the IC's internal circuitry. Notes on Use 1. Please use this IC within the stated absolute maximum ratings. The IC is liable to malfunction should the ratings be exceeded. 2. Where wiring impedance is high, operations may become unstable due to noise and/or phase lag depending on output current. Please keep the resistance low between VIN and GND wiring. 3. Please wire the input capacitor (CIN) and the output capacitor (COUT) as close to the IC as possible. Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 8 / 9 RY6050-ADJM5R 500mA Adjustable High-Speed Low Power LDO Packaging Information 5-Pin SOT23 Packaging Information SOT23-5 2.80 3.00 0.95 BSC 0.60 TYP 1.20 TYP 1.50 2.60 1.70 3.00 2.60 TYP PIN 1 TOP VIEW RECOMMENDED PAD LAYOUT GAUGE PLANE 0.25 BSC 0.90 1. 30 1.45 MAX SEATING PLANE 0.30 0.50 0.95 BSC FRONT VIEW 0.00 0.15 0°~8° 0.30 0.55 0.09 0.20 SIDE VIEW NOTE: 1. CONTRO L DI MENSION IS IN INCHES. DIMENSION I N BRACKET IS IN MILLIMETERS. 2. PACKAG E LENGTH DOES NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. 3. PACKAG E WIDTH DO ES NOT INCLUDE I NTERLEAD FLASH OR PROTRUSIONS. 4. LEAD COPLANARITY (BO TTO M O F LEADS AFTER FORMING) SHALL BE 0. 004" INCHES MAX. 5. DRAWING CONFORMS TO JEDEC MS-012, VARIATION BA. 6. DRAWING IS NOT TO SCALE. Email: support@rychip.com ©RYCHIP Semiconductor Inc. http://www.rychip.com Page 9 / 9
RY6050-ADJM5R 价格&库存
很抱歉,暂时无法提供与“RY6050-ADJM5R”相匹配的价格&库存,您可以联系我们找货
RY6050-ADJM5R
  • 20+0.36887
  • 200+0.32654
库存:350
RY6050-ADJM5R
  • 1+0.13090
  • 3000+0.10320
库存:9112
