SS52C THRU SS5200C
Reverse Voltage - 20 to 200 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Built-in strain relief,ideal for automated placement
0.280(7.11)
0.260(6.60)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.320(8.13)
0.305(7.75)
Case: JEDEC DO-214AB/SMC molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0077ounce, 0.22 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
Maximum average forward rectified current
I(AV)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 5.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
MDD
SS53C
MDD
SS54C
MDD
SS55C
MDD
SS56C
MDD
SS58C
MDD
SS510C
MDD
SS5150C
MDD
SS5200C
UNITS
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
CJ
RJA
Operating junction temperature range
TJ
TSTG
A
5.0
175
0.55
0.70
150
A
0.85
V
1.0
50
IR
Typical thermal resistance (NOTE 2)
Storage temperature range
MDD
SS52C
600
35
mA
400
-55 to +150
-55 to +125
pF
℃/W
-55 to +150
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS52C THRU SS5200C
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μA)
5.0
Average Forward Current (A)
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52C-SS55C
1.0
SS56C-SS5200C
50
75
100
125
150
175
10
4
10
3
10
2
TJ=100°C
TJ=75°C
101
TJ=25°C
60
100
80
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
TJ=25°C
500
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1
SS52C/SS54C
SS56C
SS58C/SS5200C
0.1
0.5
1.5
100
SS52C/SS54C
SS56C/SS5200C
2.0
0.1
W) °C /
SS52C~SS56C
SS58C~SS5200C
150
125
100
75
50
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(
Peak Forward Surage Current (A)
200
00
100
Fig.6- Typical Transient Thermal Impedance
Fig.5 Maximum Non-Repetitive Peak
25
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
175
1
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS52C THRU SS5200C
Packing information
unit:mm
P0
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
P1
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS5150C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.38533
- 1000+0.35425
- 国内价格
- 5+0.73116
- 50+0.58860
- 150+0.51732
- 500+0.46386
- 3000+0.33632
- 6000+0.31482
