ST2045
ST2045
    MDD(辰达半导体)
    TO227
    肖特基二极管 VR=45V IF=20A VF=0.5V IR=300uA
ST2045 数据手册
ST2045 Reverse Voltage - 45 Volts Forward Current -20.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features TO-277  Trench MOS Schottky barrier diodes  Low forward voltage drop  low profile - typical body height 1.1 mm  Moisture sensitivity: level 1, per J-STD-020  High temperature soldering guaranteed: 260℃/10 seconds - RoHS Compliant  Halogen-free according to IEC 61249-2-21 definition Mechanical Data Case : JEDEC TO-277 Molded plastic body Case Material: Molding compound meets UL 94V-0 flammability rating Terminals :Plated Leads Solderable per MIL-STD-202,Method 208 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.092 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. ST2045 Parameter SYMBOL MDD ST2045 Marking Code Maximum repetitive peak reverse voltage VRRM Maximum DC blocking voltage VDC RMS Reverse voltage UNIT 45 V VRMS 32 V Average Rectified Output Current I(O) 20 A Non-Repetitive Peak Forward Surge8.3ms Single Half Sine-Wave Superimposed on rated load(JEDEC Method) IFSM 400 A Electrical Characteristics Ta=25℃ unless otherwise noted Test Symbol Conditions Parameter Value Unit Typ 0.47 0.42 Max 0.50 0.45 35 60 uA 40 70 mA TA=25℃ TA=125℃ vF Peak reverse curent at rated DC TA=25℃ blocking voltage TA=125℃ IR Operating junction storage temperature range TJ -55 to +150 ℃ Storage temperaturerange TSTG -55 to +150 ℃ Typical thermal resistance Junctionto Ambient RθJC 1 ℃/W Forward Voltage Drop at 20A V Note:1.The typical data above is for referenceonly. http://www.microdiode.com Rev:2024A1 Page :1 ST2045 Reverse Voltage - 45 Volts Forward Current -20.0 Ampere Ratings And Characteristic Curves The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2 ST2045 Reverse Voltage - 45 Volts Forward Current -20.0 Ampere Packing information P0 P1 unit:mm d E Item Symbol Tolerance TO-277 Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 4.45 7.0 1.60 1.55 330.00 50.0 13.00 1.75 7.50 8.00 4.00 2.00 F B A W P D2 D1 T C W1 D 0.25 12.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) TO-277 13" 5,000 4.0 10,000 210*208*203 330 430*430*235 80,000 13.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 0.142 B 3.60 5.35 C 1.50 0.059 D 1.85 0.073 E 4.30 0.169 Rev:2024A1 0.211 Page :3
ST2045
物料型号:ST2045 器件简介:ST2045 是一款表面贴装肖特基势垒整流器,具有低正向电压降、低轮廓、典型体高1.1毫米等特点。
引脚分配:ST2045 有四个引脚,分别为右引脚、左引脚、散热片底面。
参数特性:ST2045 的最大重复峰值反向电压为45V,最大直流阻断电压未明确给出,但RMS反向电压为32V,平均整流输出电流为20A,非重复峰值正向浪涌电流为400A。
功能详解:ST2045 用于整流应用,具有低正向电压降和高效率,适用于高功率应用。
应用信息:ST2045 适用于高功率整流应用,如电源转换器、变频器等。
封装信息:ST2045 采用TO-277封装,符合JEDEC标准,封装材料符合UL 94V-0可燃性等级,引脚可焊性符合MIL-STD-202标准。
请注意,以上信息是基于PDF文档内容的分析,具体应用时还需参考最新的产品规格书和设计指南。
ST2045 价格&库存
很抱歉,暂时无法提供与“ST2045”相匹配的价格&库存,您可以联系我们找货
ST2045
  • 1+3.19770
  • 10+2.69280
  • 1000+1.52460
  • 2000+1.50935
  • 5000+1.47916
ST2045
  • 10+2.90340
  • 30+2.64600
  • 100+2.39540
  • 500+1.68940
  • 1000+1.64660
库存:24840
