UMW
R
UMW IRLML5203
SOT-23 Plastic-Encapsulate MOSFETS
SOT–23
IRLML5203 P-Channel 30-V(D-S) MOSFET
V(BR)DSS
ID
RDS(on)MAX
\85mΩ@-10 V
-30V
-3.0A
145mΩ@-4.5V
1. BASE
2. EMITTER
3. COLLECTOR
General Description
The UMW IRLML5203 uses advanced trench technology to provide excellent
RDS(on) with low gate charge. This device is suitable for use as a load
switch or in PWM applications.
Equivalent Circuit
MARKING
1H MK
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
ID
-3.0
A
Drain Current-Pulsed
IDM
-24
A
Power Dissipation
PD
300
mW
RθJA
417
℃/W
Junction Temperature
TJ
150
Storage Temperature
TSTG
-55~ +150
Thermal Resistance from Junction to Ambient
www.umw-ic.com
1
Units
友台半导体有限公司
UMW
R
UMW IRLML5203
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
Static characteristics
Drain-source breakdown voltage
V(BR) DSS
VGS = 0V, ID =-250µA
Zero gate voltage drain current
IDSS
VDS =-24V,VGS = 0V
-1
µA
Gate -source leakage current
IGSS
VGS =±20V, VDS = 0V
±100
nA
VGS =-10V, ID =-4.1A
85
mΩ
VGS =-4.5V, ID =-3A
145
mΩ
Drain-source on-resistance (note 1)
RDS(on)
Forward tranconductance (note 1)
Gate threshold voltage
gFS
VGS(th)
Diode forward voltage (note 1)
VSD
-30
VDS =-5V, ID =-4A
5.5
VDS =VGS, ID =-250µA
-1
V
S
IS=-1A,VGS=0V
-3
V
-1
V
Dynamic characteristics (note 2)
Input capacitance
Ciss
700
pF
Output capacitance
Coss
120
pF
Reverse transfer capacitance
Crss
75
pF
td(on)
8.6
ns
VGS=-10V,VDS=-15V,
5.0
ns
RL=3.6Ω,RGEN=3Ω
28.2
ns
13.5
ns
VDS =-15V,VGS =0V,f =1MHz
Switching characteristics (note 2)
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
tr
td(off)
tf
Notes:
1. Pulse test: Pulse width ≤300µs, Duty cycle ≤2%.
2. These parameter have no way to verify.
www.umw-ic.com
2
友台半导体有限公司
UMW
100
R
UMW IRLML5203
100
VGS
-15V
-10V
-7.0V
-5.5V
-4.5V
-4.0V
-3.5V
BOTTOM -2.7V
10
VGS
-15V
-10V
-7.0V
-5.5V
-4.5V
-4.0V
-3.5V
BOTTOM -2.7V
TOP
-I D , Drain-to-Source Current (A)
TOP
1
-2.70V
0.1
20µs PULSE WIDTH
TJ = 25 °C
0.01
0.1
1
10
10
1
-2.70V
20µs PULSE WIDTH
TJ = 150 °C
0.1
0.1
100
1
Fig 1. Typical Output Characteristics
R DS(on) , Drain-to-Source On Resistance
(Normalized)
2.0
10
TJ = 150 ° C
1
TJ = 25 ° C
V DS = -15V
20µs PULSE WIDTH
3.0
4.0
5.0
6.0
7.0
ID = 3.0A
1.5
1.0
0.5
0.0
-60 -40 -20
VGS = -10V
60
80 100 120 140 160
TJ , Junction Temperature ( °C)
-VGS , Gate-to-Source Voltage (V)
Fig 3. Typical Transfer Characteristics
www.umw-ic.com
100
Fig 2. Typical Output Characteristics
100
0.1
2.0
10
-VDS , Drain-to-Source Voltage (V)
Fig 4. Normalized On-Resistance
Vs. Temperature
3
友台半导体有限公司
UMW
R
UMW IRLML5203
VGS = 0V,
f = 1MHz
Ciss = Cgs + Cgd , Cds SHORTED
Crss = Cgd
Coss = Cds + Cgd
C, Capacitance (pF)
800
600
Ciss
400
200
Coss
Crss
ID = -3.0A
VDS = -24V
VDS = -15V
16
12
8
4
10
4
8
12
16
QG , Total Gate Charge (nC)
Fig 6. Typical Gate Charge Vs.
Fig 5. Typical Capacitance Vs.
100
100
-II D , Drain Current (A)
-ISD , Reverse Drain Current (A)
OPERATION IN THIS AREA LIMITED
BY RDS(on)
10
TJ = 150 ° C
1
10us
10
100us
1ms
1
TJ = 25 ° C
0.1
0.4
10ms
TA = 25 ° C
TJ = 150 ° C
Single Pulse
V GS = 0 V
0.6
0.8
1.0
1.2
1.4
1.6
0.1
0.1
1.8
10
100
Fig 8. Maximum Safe Operating Area
Fig 7. Typical Source-Drain Diode
Forward Voltage
www.umw-ic.com
1
-VSD ,Source-to-Drain Voltage (V)
4
友台半导体有限公司
UMW
R
UMW IRLML5203
3.0
VDS
-ID , Drain Current (A)
VGS
RD
D.U.T.
RG
2.0
VDD
VGS
Pulse Width ≤ 1 µs
Duty Factor ≤ 0.1 %
1.0
Fig 10a. Switching Time Test Circuit
td(on)
tr
t d(off)
tf
VGS
0.0
25
50
75
100
125
10%
150
TC , Case Temperature ( ° C)
90%
Fig 9. Maximum Drain Current Vs.
Case Temperature
VDS
Fig 10b. Switching Time Waveforms
Thermal Response (Z thJA )
1000
100
D = 0.50
0.20
0.10
10
0.05
P DM
0.02
0.01
1
t1
t2
SINGLE PULSE
(THERMAL RESPONSE)
0.1
0.00001
Notes:
1. Duty factor D = t 1 / t 2
2. Peak T J = P DM x Z thJA + TA
0.0001
0.001
0.01
0.1
1
10
t1 , Rectangular Pulse Duration (sec)
Fig 11. Maximum Effective Transient Thermal Impedance, Junction-to-Ambient
www.umw-ic.com
5
友台半导体有限公司
UMW IRLML5203
0.14
R DS (on) , Drain-to-Source On Resistance ( Ω)
R DS(on) , Drain-to -Source On Resistance ( Ω )
UMW
R
0.13
0.12
0.11
0.10
ID = -3.0A
0.09
0.08
0.07
4.0
6.0
8.0
10.0
12.0
14.0
16.0
0.40
0.30
VGS = -4.5V
0.20
VGS = -10V
0.10
0.00
-V GS, Gate -to -Source Voltage (V)
8
12
16
-I D , Drain Current (A)
Fig 12. Typical On-Resistance Vs. Drain
Current
Fig 11. Typical On-Resistance Vs. Gate
Voltage
Current Regulator
Same Type as D.U.T.
50KΩ
QG
QGS
12V
.3µF
QGD
D.U.T.
+VDS
VGS
VG
-3mA
IG
Charge
ID
Current Sampling Resistors
Fig 13a. Basic Gate Charge Waveform
www.umw-ic.com
.2µF
Fig 13b. Gate Charge Test Circuit
6
友台半导体有限公司
UMW
R
UMW IRLML5203
30
ID = -250µA
Power (W)
-V GS(th) , Variace ( V )
2.5
2.0
10
-75
-50
-25
50
75
100
125
0.001
150
0.100
1.000
10.000
100.000
Time (sec)
T J , Temperature ( °C )
Fig 15. Typical Power Vs. Time
Fig 14. Threshold Voltage Vs. Temperature
www.umw-ic.com
0.010
7
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW IRLML5203
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
8
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“IRLML5203”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28566
- 100+0.22173
- 300+0.18976
- 3000+0.16546
- 6000+0.14624
- 9000+0.13662
- 国内价格
- 10+0.26186
- 100+0.20325
- 600+0.17394
- 1200+0.17133
- 国内价格
- 100+0.10416
- 500+0.09944
