VBJ2102M
www.VBsemi.com
P-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 100
• Trench Power MOSFET
RDS(on) ()
ID (A)
0.200 at VGS = - 10 V
- 3.0
0.230 at VGS = - 6 V
- 2.4
Qg (Typ.)
• 100% Rg and UIS Tested
13.2 nC
APPLICATIONS
• Active Clamp in Intermediate DC/
Available
DC Power Supplies
• H-Bridge High Side Switch for
Lighting Application
S
SOT-223
G
D
G
D
S
D
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
Limit
- 100
± 20
- 3.0
-2.1
ID
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
TC = 25 °C
TA = 25 °C
IS
Avalanche Current
Single-Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
Maximum Power Dissipation
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
PD
V
- 2a, b
- 1.6a, b
- 12
- 4.9
A
- 2.5a, b
- 15
11.25
6.5
4.8
mJ
3.1a, b
2a, b
- 55 to 150
TJ, Tstg
Operating Junction and Storage Temperature Range
Unit
W
°C
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. t = 10 s.
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta, b
Maximum Junction-to-Foot (Drain)
t 10 s
Steady State
Symbol
RthJA
RthJF
Typical
33
17
Maximum
40
21
Unit
°C/W
Notes:
b. Maximum under steady state conditions is 80 °C/W.
服务热线:400-655-8788
1
VBJ2102M
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 250 µA
- 100
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS/TJ
VGS(th) Temperature Coefficient
VGS(th)/TJ
ID = - 250 µA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = - 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
RDS(on)
Forward Transconductancea
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
gfs
tr
Rise Time
Fall Time
Turn-On Delay Time
V
nA
VDS = - 100 V, VGS = 0 V
-1
- 10
VDS - 5 V, VGS = - 10 V
VGS = - 10 V, ID = - 3 A
-8
µA
A
0.200
VGS = - 6 V, ID = - 2 A
0.230
VDS = - 15 V, ID = 3 A
12
S
819
VDS = - 35 V, VGS = 0 V, f = 1 MHz
pF
51
32
VDS = - 50 V, VGS = - 10 V, ID = - 3 A
17.5
32
13.2
25
VDS = - 50 V, VGS = - 6 V, ID = - 3 A
3.4
f = 1 MHz
6.1
9.2
10
nC
6.4
VDD = - 50 V, RL = 25
ID - 3 A, VGEN = - 6 V, Rg = 1
95
40
tf
15
30
td(on)
11
18
td(off)
ID - 3 A, VGEN = - 10 V, Rg = 1
tf
Fall Time
-3
± 100
55
tr
Rise Time
Turn-Off DelayTime
-1
td(off)
Turn-Off DelayTime
mV/°C
- 6.6
VDS = - 100 V, VGS = 0 V, TJ = 55 °C
td(on)
Turn-On Delay Time
V
- 165
18
32
32
58
ns
Drain-Source Body Diode Characteristics
a
Pulse Diode Forward Current
Body Diode Voltage
IS
TC = 25 °C
- 13
ISM
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
- 15
IS = - 3 A
IF = - 3 A, dI/dt = 100 A/µs, TJ = 25 °C
A
- 0.8
- 1.2
V
65
90
ns
180
270
nC
45
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
服务热线:400-655-8788
VBJ2102M
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
VGS = 10 V thru 6 V
VGS = 5 V
1.6
ID - Drain Current (A)
16
12
8
4
1.2
0.8
TC = 125 °C
0.4
VGS = 4 V
TC = 25
TC = - 55 °C
2
6
8
10
VDS - Drain-to-Source Voltage (V)
4
3
5
6
Transfer Characteristics
0.6
1200
0.5
960
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
Output Characteristics
0.4
VGS = 6 V
0.3
2
VGS - Gate-to-Source Voltage (V)
VGS = 10 V
Ciss
720
480
0.2
240
Coss
0.1
Crss
8
16
12
ID - DrainCurrent (A)
80
100
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
2.2
10
RDS(on) - On-Resistance (Normalized)
VDS = 50 V
ID = 3 A
60
8
VDS = 75 V
6
VDS = 100 V
4
2
8
12
Qg - TotalGateCharge(nC)
Gate Charge
16
ID = 4 A
1.9
VGS = 10 V
1.6
1.3
VGS = 6 V
1.0
0.7
0.4
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
服务热线:400-655-8788
3
VBJ2102M
www.VBsemi.com
2.0
I S - Source Current (A)
100
10
TJ = 150 °C
TJ = 25 °C
1
1.6
1.2
0.8
TJ = 125 °C
0.4
TJ = 25 °C
0.0
0.1
0.3
0.6
0.9
1.2
1.5
2
8
6
10
VSD - Source-to-Drain Voltage (V)
VGS - Gate-to-SourceVoltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
1.0
200
0.7
160
ID = 250 µA
Power (W)
V GS(th) Variance (V)
0.0
0.4
ID = 5 mA
0.1
- 0.2
- 0.5
- 50
120
80
40
50
75
100
125
150
0 .0 0 1
0.01
TJ - Temperature (°C)
0.1
1
10
Time (s)
Threshold Voltage
Single Pulse Power, Junction-to-Ambient
I D - Drain Current (A)
100
10
Limited by RDS(on)*
1 ms
1
10 ms
100 ms
0.1
1s
10 s
TA = 25 °C
Single Pulse
0.01
0.01
DC
0.1
1
10
100
1000
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
4
服务热线:400-655-8788
VBJ210M
www.VBsemi.com
4
3
2
1
50
75
100
125
150
TC - Case Temperature (°C)
8.0
2.0
6.4
1.6
Power (W)
Power (W)
Current Derating*
4.8
3.2
1.6
1.2
0.8
0.4
0.0
0.0
50
75
100
Power, Junction-to-Foot
125
150
50
75
100
125
150
TA - Ambient Temperature (°C)
* The power dissipation PD is based on TJ(max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
VBJ210M
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 80 ° C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
10
100
1000
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
0.01
10-4
Single Pulse
10-3
10-2
10-1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
服务热线:400-655-8788
6
VBJ210M
www.VBsemi.com
SOT-223 (HIGH VOLTAGE)
B
D
A
3
0.08 (0.003)
B1
C
0.10 (0.004) M C B M
A
4
3
H
E
0.20 (0.008) M C A M
L1
1
2
3
4xL
3xB
e
θ
e1
4xC
MILLIMETERS
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
1.55
1.80
0.061
0.071
B
0.65
0.85
0.026
0.033
B1
2.95
3.15
0.116
0.124
C
0.25
0.35
0.010
0.014
D
6.30
6.70
0.248
0.264
E
3.30
3.70
0.130
e
2.30 BSC
e1
4.60 BSC
0.181 BSC
H
6.71
7.29
0.264
L
0.91
0.036
L1
θ
0.061 BSC
0.146
0.0905 BSC
0.287
0.0024 BSC
10'
10'
Notes
1. Dimensioning and tolerancing per ASME Y14.5M-1994.
2. Dimensions are shown in millimeters (inches).
3. Dimension do not include mold flash.
4. Outline conforms to JEDEC outline TO-261AA.
服务热线:400-655-8788
7
VBJ2102M
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
