HSU0139
P-Ch 100V Fast Switching MOSFETs
Description
Product Summary
The HSU0139 uses advanced trench MOSFET
technology to provide excellent RDS(ON) and gate
charge for use in a wide variety of other
applications.
The HSU0139 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
-100 V
RDS(ON),typ
42
mΩ
ID
-30
A
TO252 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-100
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1
-30
A
ID@TC=100℃
-19
A
IDM
Pulsed Drain Current2
-100
A
EAS
Single Pulse Avalanche Energy3
185
mJ
IAS
Avalanche Current
-28
A
PD@TC=25℃
Total Power Dissipation4
102
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient 1
RθJC
Thermal Resistance Junction-Case1
www.hs-smei.cn
Ver 2.0
Typ.
Max.
Unit
62
℃/W
1.2
℃/W
1
HSU0139
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-100
V
VGS=-10V , ID=-10A
42
50
VGS=-4.5V , ID=-8A
46
55
m
Gate Threshold Voltage
VGS=VDS , ID =-250uA
-1.2
-1.8
-2.5
V
IDSS
Drain-Source Leakage Current
VDS=-100V , VGS=0V , TJ=25℃
-50
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-10A
32
S
Qg
Total Gate Charge
92
Qgs
Gate-Source Charge
17.5
Qgd
Gate-Drain Charge
14
Turn-On Delay Time
20.5
Td(on)
Tr
Td(off)
Tf
VDS=-80V , VGS=-10V , ID=-14A
Rise Time
VDD=-50V , VGS=-10V , RG=3.3,
32.2
Turn-Off Delay Time
ID=-14A
123
nC
ns
Fall Time
63.7
Ciss
Input Capacitance
6516
Coss
Output Capacitance
223
Crss
Reverse Transfer Capacitance
125
Min.
Typ.
Max.
Unit
VDS=-25V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
Continuous Source Current1,5
VG=VD=0V , Force Current
-30
A
VSD
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
1.2
V
trr
Reverse Recovery Time
IF=-14A , di/dt=-100A/µs ,
31.2
nS
Qrr
Reverse Recovery Charge
TJ=25℃
31.97
nC
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=-25V,VGS=-10V,L=0.88mH,IAS=-28A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-smei.cn
Ver 2.0
2
HSU0139
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
Fig.3 Typical S-D Diode Forward Voltage
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized VGS(th) vs. TJ
www.hs-smei.cn
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSU0139
Fig.7 Capacitance
Fig.8 Safe Operating Area
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-smei.cn
Fig.11 Unclamped Inductive Waveform
Ver 2.0
4
HSU0139
Ordering Information
Part Number
HSU0139
www.hs-smei.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU0139”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.43099
- 30+2.34599
- 100+2.17599
- 500+2.00599
- 1000+1.92099
- 国内价格
- 1+3.88800
- 10+3.13200
- 30+2.75400
- 100+2.37600
- 500+1.89000
- 1000+1.77120
- 国内价格
- 1+3.25420
- 10+2.90630
- 50+2.64340
- 100+2.35640
- 500+1.90650
- 1000+1.78550
