HSP80P10
P-Ch 100V Fast Switching MOSFETs
Description
Product Summary
The HSP80P10 uses advanced trench MOSFET
technology to provide excellent RDS(ON) and gate
charge for use in a wide variety of other
applications.
The HSP80P10 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
-100 V
RDS(ON),typ
mΩ
ID
-80
A
TO220 Pin Configuration
100% EAS Guaranteed
Green Device Available
Portable equipment and battery
powered systems
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-100
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1
-80
A
ID@TC=100℃
-57
A
IDM
Pulsed Drain Current2
-225
A
EAS
Single Pulse Avalanche Energy3
310
mJ
PD@TC=25℃
Total Power Dissipation4
210
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient 1
RθJC
Thermal Resistance Junction-Case1
www.hs-smei.cn
Ver 2.0
Typ.
Max.
Unit
62
℃/W
0.7
℃/W
1
HSP80P10
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-100
V
VGS=-10V , ID=-40A
VGS=-4.5V , ID=-40A
24
32
m
Gate Threshold Voltage
VGS=VDS , ID =-250uA
-1.0
-1.8
-3
V
IDSS
Drain-Source Leakage Current
VDS=-100V , VGS=0V , TJ=25℃
-50
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VGS=0V , VDS=0V,F=1MHz
4.7
gfs
Forward Transconductance
VDS=-10V , ID=-10A
32
S
Qg
Total Gate Charge
180
Qgs
Gate-Source Charge
44
Qgd
Gate-Drain Charge
29
Td(on)
VDS=-50V , VGS=-10V , ID=-20A
16
Rise Time
VDD=-50V , VGS=-10V , RG=4,
91
Turn-Off Delay Time
ID=-20A
208
Fall Time
110
Ciss
Input Capacitance
11660
Coss
Output Capacitance
289
Crss
Reverse Transfer Capacitance
99
Min.
Typ.
Max.
Unit
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=-50V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
Continuous Source Current1,5
VG=VD=0V , Force Current
-80
A
VSD
Diode Forward Voltage2
VGS=0V , IS=-40A , TJ=25℃
-1.3
V
trr
Reverse Recovery Time
IF=-40A , di/dt=-100A/µs ,
31.2
nS
Qrr
Reverse Recovery Charge
TJ=25℃
45
nC
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=-80V,VGS=-10V,L=0.3mH
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-smei.cn
Ver 2.0
2
HSP80P10
Typical Characteristics
www.hs-smei.cn
Ver 2.0
3
HSP80P10
Fig.12 Unclamped Inductive Waveform
Fig.11 Switching Time Waveform
www.hs-smei.cn
Ver 2.0
4
HSP80P10
www.hs-smei.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSP80P10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.38920
- 10+6.17400
- 50+5.33120
- 100+4.56680
- 国内价格
- 1+8.14320
- 10+6.80400
- 50+5.87520
- 100+5.03280
- 500+4.66560
- 1000+4.49280
