HSM4113
P-Ch 40V Fast Switching MOSFETs
Description
Product Summary
The HSM4113 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSM4113 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
VDS
-40
V
RDS(ON),max
40
mΩ
ID
-7.5
A
SOP8 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-40
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
IDM
EAS
IAS
PD@TC=25℃
±20
V
Continuous Drain Current, -VGS @
-10V1
-7.5
A
-10V1
-5.7
A
-15
A
36
mJ
-27.2
A
Pulsed Drain
Current2
Single Pulse Avalanche
Energy3
Avalanche Current
Total Power
Dissipation4
3.1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.1
Typ.
1
Max.
Unit
85
℃/W
40
℃/W
1
HSM4113
P-Channel Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-40
V
Reference to 25℃ , ID=-1mA
-0.012
V/℃
VGS=-10V , ID=-6A
40
VGS=-4.5V , ID=-3A
70
-1.0
-2.5
V
4.32
mV/℃
VDS=-32V , VGS=0V , TJ=25℃
1
VDS=-32V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-6A
12
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
13
Qg
Total Gate Charge (-4.5V)
9
2.54
VDS=-20V , VGS=-4.5V , ID=-6A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
3.1
Td(on)
Turn-On Delay Time
19.2
nC
Rise Time
VDD=-15V , VGS=-10V , RG=3.3,
12.8
Turn-Off Delay Time
ID=-1A
48.6
Fall Time
4.6
Ciss
Input Capacitance
1004
Coss
Output Capacitance
108
Crss
Reverse Transfer Capacitance
80
Min.
Typ.
Max.
Unit
-7.5
A
-15
A
-1
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source
Current1,5
Pulsed Source
Current2,5
Diode Forward
Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-27.2A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.1
2
HSM4113
P-Channel Typical Characteristics
60
12
ID=-6A
VGS=-10V
10
55
RDSON (mΩ)
-ID Drain Current (A)
VGS=-7V
VGS=-5V
8
6
50
45
VGS=-4.5V
40
4
VGS=-3V
2
35
1
1.5
-VDS Drain-to-Source Voltage (V)
2
2
4
Fig.1 Typical Output Characteristics
6
8
-VGS (V)
10
Fig.2 On-Resistance v.s Gate-Source
Voltage
10
12
VDS=-20V
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
ID=-6A
8
6
4
2
Fig.3 Forward Characteristics of Reverse
12
18
Fig.4 Gate-Charge Characteristics
diode
2.0
Normalized On Resistance
1.5
Normalized -VGS(th)
6
QG , Total Gate Charge (nC)
-VSD , Source-to-Drain Voltage (V)
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature ( ℃)
-50
150
Fig.5 Normalized VGS(th) v.s TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON v.s TJ
Ver 2.1
3
HSM4113
10000
100.00
Capacitance (pF)
F=1.0MHz
10.00
Ciss
-ID (A)
1000
100us
1.00
Coss
100
1ms
10ms
100ms
DC
0.10
Crss
Tc=25o C
Single Pulse
10
0.01
1
5
9
13
17
-VDS Drain to Source Voltage(V)
21
25
0.1
Fig.7 Capacitance
1
-VDS (V)
10
100
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.3
0.1
0.1
0.05
PDM
T
0.02
0.01
0.01
0.00001
TON
D = TON/T
TJpeak = TC + PDM x RθJC
SINGLE PULSE
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Waveform
Ver 2.1
4
HSM4113
Ordering Information
Part Number
HSM4113
www.hs-semi.cn
Package code
SOP-8
Ver 2.1
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSM4113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.20618
- 50+0.99284
- 150+0.90140
- 国内价格
- 5+1.32927
- 50+1.09415
- 150+0.99339
- 500+0.86757
- 2500+0.76378
- 5000+0.73008
