HSH15810
N-Ch 100V Fast Switching MOSFETs
General Description
Product Summary
100% EAS Guaranteed
Green Device Available
Super Low RDS(ON)
Advanced high cell density Trench
technology
100
V
RDS(ON),typ
3.7
mΩ
ID
120
A
TO263 Pin Configuration
Applications
VDS
MOTOR Driver.
BMS.
High frequency switching and
synchronous rectification.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1,6
120
A
ID@TC=100℃
100
A
IDM
Pulsed Drain Current2
480
A
EAS
Single Pulse Avalanche Energy3
196
mJ
IAS
Avalanche Current
28
A
PD@TC=25℃
Total Power Dissipation4
227
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient 1
62
℃/W
RθJC
Thermal Resistance Junction-Case1
0.5
℃/W
www.hs-semi.cn
Ver 2.0
Typ.
1
HSH15810
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
Conditions
Min.
Typ.
Max.
Unit
BVDSS
Drain-Source Breakdown Voltage
VGS=0V , ID=250uA
100
V
RDS(ON)
Static Drain-Source On-Resistance2
VGS=10V , ID=30A
3.7
4.5
m
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =250uA
2.0
3.0
4.0
V
VDS=100V , VGS=0V , TJ=25℃
1
VDS=100V , VGS=0V , TJ=125℃
10
IDSS
Drain-Source Leakage Current
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=30A
50
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1
72
28
15
Qg
Total Gate Charge (10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
Td(on)
Turn-On Delay Time
Tr
Rise Time
VDS=50V , VGS=10V , ID=20A
35
VDD=50V , VGS=10V , RG=3.0,
18
ID=20A
45
nC
ns
Td(off)
Turn-Off Delay Time
Tf
Fall Time
55
Ciss
Input Capacitance
4725
Coss
Output Capacitance
609
Crss
Reverse Transfer Capacitance
14
Min.
Typ.
Max.
Unit
VDS=50V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
Continuous Source Current1,5
VG=VD=0V , Force Current
120
A
VSD
Diode Forward Voltage2
VGS=0V , IS=50A , TJ=25℃
1.3
V
trr
Reverse Recovery Time
IF=30A , dI/dt=100A/µs ,
70
nS
Qrr
Reverse Recovery Charge
TJ=25℃
170
nC
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.5mH,IAS=28A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
6.Package limitation current.
www.hs-semi.cn
Ver 2.0
2
HSH15810
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs G-S Voltage
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized VTH vs TJ
Fig.6 Normalized RDSON vs TJ
www.hs-semi.cn
Ver 2.0
3
HSH15810
Fig.8 Safe Operating Area
Fig.7 Capacitance
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Switching Waveform
Ver 2.0
4
HSH15810
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSH15810”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.05440
- 10+4.11480
- 30+3.65040
- 100+3.18600
- 500+2.91600
- 800+2.76480
- 国内价格
- 1+4.58640
- 10+3.73380
- 30+3.31240
- 100+2.89100
