HSM4435
P-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSM4435 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSM4435 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
-30
V
RDS(ON),typ
18
mΩ
ID
-9.5
A
SOP8 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ -10V1
-9.5
A
ID@TA=70℃
-7.6
A
IDM
Pulsed Drain Current2
-50
A
EAS
Single Pulse Avalanche Energy3
72.2
mJ
IAS
Avalanche Current
-38
A
PD@TA=25℃
Total Power Dissipation4
3.1
W
PD@TA=70℃
2
1.5
W
TSTG
Storage Temperature Range
-550.94
to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
Max.
Unit
Thermal Resistance Junction-Ambient 1
75
℃/W
Thermal Resistance Junction-Ambient 1(t≦10s)
40
℃/W
Thermal Resistance Junction-Case1
24
℃/W
RθJA
RθJC
www.hs-semi.cn
Ver 2.0
1
HSM4435
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.022
V/℃
VGS=-10V , ID=-6A
18
VGS=-4.5V , ID=-4A
27
32
-1.0
-2.5
V
4.6
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-6A
17
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
13
Qg
Total Gate Charge (-4.5V)
12.6
4.8
VDS=-15V , VGS=-4.5V , ID=-6A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
4.8
Turn-On Delay Time
4.6
Td(on)
nC
Rise Time
VDD=-15V , VGS=-10V , RG=3.3,
14.8
Turn-Off Delay Time
ID=-6A
41
Fall Time
19.6
Ciss
Input Capacitance
1345
Coss
Output Capacitance
194
Crss
Reverse Transfer Capacitance
158
Min.
Typ.
Max.
Unit
-9.5
A
-50
A
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
IS
Continuous Source Current1,5
ISM
Pulsed Source Current2,5
VSD
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
trr
Reverse Recovery Time
IF=-6A , dI/dt=100A/µs ,
16.3
nS
Qrr
Reverse Recovery Charge
TJ=25℃
5.9
nC
VG=VD=0V , Force Current
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-38A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSM4435
Typical Characteristics
50
-ID Drain Current (A)
40
VGS=-10V
30
VGS=-7V
VGS=-5V
VGS=-4.5V
VGS=-3V
10
1
1.5
2
2.5
-VDS , Drain-to-Source Voltage (V)
3
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance v.s Gate-Source
Voltage
12
-IS Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
1
-VSD , Source-to-Drain Voltage (V)
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-Charge Characteristics
diode
2.0
Normalized On Resistance
Normalized VGS(th)
1.5
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature ( ℃)
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSM4435
100.00
10000
F=1.0MHz
100us
10.00
Capacitance (pF)
Ciss
1ms
-ID (A)
1000
10ms
1.00
Coss
100ms
Crss
100
0.10
DC
TA=25o C
Single Pulse
0.01
0.01
10
1
5
9
13
17
-VDS Drain to Source Voltage(V)
21
25
Fig.7 Capacitance
0.1
1
10
-VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.01
P DM
0.01
T ON
T
D = TON/T
SINGLE
TJpeak = TA+P DMXRθJA
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform
www.hs-semi.cn
Ver 2.0
4
HSM4435
Ordering Information
Part Number
HSM4435
www.hs-semi.cn
Package code
SOP-8
Ver 2.0
Packaging
4000/Tape&Reel
5
很抱歉,暂时无法提供与“HSM4435”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.05916
- 50+0.84143
- 150+0.74812
- 国内价格
- 5+0.78851
- 50+0.63267
- 150+0.55480
- 500+0.49637
- 国内价格
- 5+0.47960
- 20+0.47080
- 100+0.45320
