Application Notes: AN_SY8077
High Efficiency 1.5MHz, 1A
Synchronous Step Down Regulator
Preliminary Specification
General Description
Features
SY8077 is a high efficiency 1.5MHz synchronous step
down DC/DC regulator IC capable of delivering up to
1A output current. It can operate over a wide input
voltage range from 2.5V to 6.5V and integrate main
switch and synchronous switch with very low RDS (ON)
to minimize the conduction loss.
• Low RDS(ON) for internal switches (top/bottom)
260mΩ/170mΩ
rth
wo
• High light load efficiency
ky
• Internal soft-start limits the inrush current
rs
SY8077 □(□□)□
Temperature Code
Package Code
Optional Spec Code
• 100% dropout operation
fo
• RoHS Compliant and Halogen Free
Note
1A
ar
ed
• Compact package: SOT23-5
Applications
tia
l-P
re
p
Package Type
SOT23-5
• 40µA typical quiescent current
• High switching frequency 1.5MHz minimizes the
external components
Ordering Information
Ordering Number
SY8077AAC
• 2.5~6.5V input voltage range
Portable Navigation Device
Set Top Box
USB Dongle
Media Player
Smart phone
Efficiency vs. Load Current
93
88
er
gy
Efficiency (%)
Co
rp
.C
on
Typical Application
fid
en
83
78
Vin=6.5V Vout=1.8V
Vin=5.0V Vout=1.8V
73
Vin=4.2V Vout=1.8V
Sil
Vin=3.3V Vout=1.8V
68
1
10
100
1000
Load Current (mA)
Figure1. Schematic Diagram
AN_SY8077 Rev. 0.1
Figure2. Efficiency
Silergy Corp. Confidential- Prepared for Customer Use Only
1
AN_SY8077
rth
Pinout (Top View)
wo
(SOT23-5)
5
rs
FB
Pin Description
Enable control. Pull high to turn on. Do not float.
Ground pin.
Inductor pin. Connect this pin to the switching node of the inductor.
Input pin. Decouple this pin to the GND pin with at least 10uF ceramic
capacitor.
Output Feedback Pin. Connect this pin to the center point of the output resistor
divider (as shown in Figure 1) to program the output voltage:
VOUT=0.6*(1+R1/R2).Add optional C1 (10pF~47pF) to speed up the transient
response.
fo
Pin Number
1
2
3
4
tia
l-P
re
p
ar
ed
Pin Name
EN
GND
LX
IN
ky
Top Mark: TRxyz (device code: TR, x=year code, y=week code, z= lot number code)
Absolute Maximum Ratings (Note 1)
Co
rp
.C
on
fid
en
Supply Input Voltage -------------------------------------------------------------------------------------------------------- 7.0V
Enable, FB Voltage---------------------------------------------------------------------------------------------------- VIN + 0.6V
Power Dissipation, PD @ TA = 25°C, SOT23-5--------------------------------------------------------------------------- 0.6W
Package Thermal Resistance (Note 2)
θ JA -------------------------------------------------------------------------------------------------------------- 170°C/W
θ JC ---------------------------------------------------------------------------------------------------------- ----130°C/W
Junction Temperature Range ----------------------------------------------------------------------------------------------125°C
Lead Temperature (Soldering, 10 sec.) ---------------------------------------------------------------------------------- 260°C
Storage Temperature Range ----------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
Sil
er
gy
Supply Input Voltage ----------------------------------------------------------------------------------------------- 2.5V to 6.5V
Junction Temperature Range ----------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------------ -40°C to 85°C
AN_SY8077 Rev. 0.1
2
AN_SY8077
Electrical Characteristics
(VIN = 5V, VOUT = 2.5V, L = 2.2uH, COUT = 10uF, TA = 25°C, unless otherwise specified)
1
0.612
wo
170
1.3
1.5
Max
6.5
rth
40
0.1
0.6
260
0.588
tia
l-P
re
p
TSS
TSD
THYS
Typ
ky
RDS(ON),N
ILIM
VENH
VENL
VUVLO
VHYS
FOSC
IOUT=0, VFB=VREF ⋅ 105%
EN=0
Min
2.5
rs
NFET RON
PFET Current Limit
EN rising threshold
EN falling threshold
Input UVLO threshold
UVLO hysteresis
Oscillator Frequency
Min ON Time
Max Duty Cycle
Soft Start Time
Thermal Shutdown Temperature
Thermal Shutdown Hysteresis
Test Conditions
fo
Symbol
VIN
IQ
ISHDN
VREF
RDS(ON),P
ar
ed
Parameter
Input Voltage Range
Quiescent Current
Shutdown Current
Feedback Reference Voltage
PFET RON
0.1
1.5
80
100
1
150
15
0.4
2.5
Unit
V
µA
µA
V
mΩ
mΩ
A
V
V
V
V
MHz
ns
ms
°C
°C
fid
en
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are
for stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for
extended periods may remain possibility to affect device reliability.
.C
on
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard. Exposed Paddle of DFN package is the case position for
θ JC measurement.
Sil
er
gy
Co
rp
Note 3: The device is not guaranteed to function outside its operating conditions.
AN_SY8077 Rev. 0.1
3
AN_SY8077
Typical Performance Characteristics
90
93
85
88
80
rth
83
75
78
Vin=6.5V Vout=1.2V
70
wo
Vin=6.5V Vout=1.8V
Vin=5.0V Vout=1.2V
Vin=5.0V Vout=1.8V
Vin=4.2V Vout=1.2V
73
Vin=4.2V Vout=1.8V
ky
65
Vin=3.3V Vout=1.2V
Vin=3.3V Vout=1.8V
60
1
10
100
1000
rs
68
1
10
100
1000
Load Current (mA)
fo
Load Current (mA)
ar
ed
98
tia
l-P
re
p
95
92
89
86
83
Vin=6.5V Vout=3.3V
77
Vin=5.0V Vout=3.3V
en
80
Output Ripple
(VIN=5.0V, VOUT=1.8V, ILOAD=0A)
∆Vout
10mV/div
LX
2.0V/div
IL
0.2A/div
74
1
10
100
.C
on
71
fid
Vin=4.2V Vout=3.3V
1000
Time (400ns/div)
Load Current (mA)
Output Ripple
∆Vout
10mV/div
2.0V/div
Sil
er
gy
LX
Co
rp
(VIN=5.0V, VOUT=1.8V, ILOAD=1.0A)
IL
1A/div
Time (400ns/div)
AN_SY8077 Rev. 0.1
4
AN_SY8077
Startup from Enable
Shutdown from Enable
5.0V/div
EN
5.0V/div
VOUT
1.0V/div
VOUT
1.0V/div
LX
5.0V/div
LX
5.0V/div
IL
1.0A/div
rth
EN
1.0A/div
ky
wo
IL
Time (40µs/div)
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
rs
Time (400µs/div)
AN_SY8077 Rev. 0.1
5
AN_SY8077
R1 =
rth
wo
Short Circuit Protection:
SY8077 integrates hic-cup mode hard short protection
function. If output voltage is below 40% of the
regulation voltage, the internal soft-start node and the
error amplifier output will be reset immediately. IC
works in hic-cup protection mode. The hiccup
frequency is about 250Hz, and the hic-cup duty is 50%.
If the hard short condition is removed, IC will go back
to normal operation.
tia
l-P
re
p
Feedback resistor dividers R1 and R2:
Choose R1 and R2 to program the proper output
voltage. To minimize the power consumption under
light loads, it is desirable to choose large resistance
values for both R1 and R2. A value of between 100kΩ
and 1MΩ is highly recommended for both resistors. If
R2=120kΩ is chosen, then R1 can be calculated to be:
ky
Because of the high integration in the SY8077 IC, the
application circuit based on this regulator IC is rather
simple. Only input capacitor CIN, output capacitor COUT,
output inductor L and feedback resistors (R1 and R2)
need to be selected for the targeted applications
specifications.
rs
Applications Information
fo
The SY8077 is a high-efficiency 1.5MHz synchronous
step-down DC-DC converters capable of delivering up
to 1A output current. It operates over a wide input
voltage range from 2.5V to 6.5V and integrates main
switch and synchronous switch with very low RDS(ON)
where Fsw is the switching frequency and Iout,max is
the maximum load current.
The SY8077 regulator IC is quite tolerant of different
ripple current amplitude. Consequently, the final choice
of inductance can be slightly off the calculation value
without significantly impacting the performance.
2) The saturation current rating of the inductor must
be selected to be greater than the peak inductor
current under full load conditions.
VOUT(1-VOUT/VIN,MAX)
ISAT, MIN > IOUT, MAX +
2 ⋅ FSW ⋅ L
3) The DCR of the inductor and the core loss at the
switching frequency must be low enough to achieve the
desired efficiency requirement. It is desirable to choose
an inductor with DCR
很抱歉,暂时无法提供与“SY8077AAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.35426
- 50+1.05095
- 150+0.92100
- 国内价格
- 5+1.53717
- 50+1.19286
- 150+1.04534
- 500+0.86130
- 3000+0.77933
- 6000+0.73008
- 国内价格
- 1+0.97240
- 200+0.74800
- 1500+0.65010
- 3000+0.60500
