SCT2400TVBR
SCT2400TVBR
    SCT(芯洲科技)
    TSOT-23-6
    4.5V-40V Vin, 600mA同步降压DCDC变换器
SCT2400TVBR 数据手册
芯 洲 科 SCT2400 技 Silicon Content Technology Rev 1.2 4.5V-40V Vin, 600mA Synchronous Step-down DCDC Converter FEATURES DESCRIPTION      The SCT2400 is a high frequency, up to 600mA continuous output synchronous buck converter. It has wide input voltage rating from 4.5V to 40V, which integrates a 600mΩ high-side MOSFET and a 300mΩ low-side MOSFET. The SCT2400, adopts the peak current mode control with built-in loop compensation to make the chip easy to use.        Wide Input Range: 4.5V-40V Up to 600mA Continuous Output Current Less than 0.1% Output Ripple at 12V Output 0.81V ± 2.5% Feedback Reference Voltage Integrated 600mΩ High-Side and 300mΩ LowSide Power MOSFETs Fixed Frequency 2MHz Pulse Skipping Mode (PSM) at Light Load 90uA Quiescent Current in Sleep Mode 80ns Minimum On-time 1ms Internal Soft-start Time Over-Temperature Protection Available in an TSOT23-6 Package The SCT2400 features fixed 2MHz switching frequency, which minimizes the external off chip passive components size and reduces the output ripple to be lower than 0.1% of output when the output is 12V. With a minimum 80ns on-time of high-side MOSFET, the SCT2400 allows power conversion from high input voltage to low output voltage. The SCT2400 supports the Pulse Skipping Modulation (PSM) with typical 90uA low quiescent current. It achieves 85% power efficiency at 10mA light load condition. APPLICATIONS      Industrial 24V Distributed Power Bus Power meter Elevator, PLC, Servo Automatic Control Automotive The SCT2400 offers cycle-by-cycle current limit, thermal shutdown protection and input voltage undervoltage protection. The device is available in a 6-pin small profile TSOT23-6 package. TYPICAL APPLICATION 100 90 C2 80 VOUT SW BST VIN VIN GND FB EN ON C1 C3 OFF R1 Efficiency(%) L1 70 60 50 40 30 20 VIN=24V, VOUT=5V 10 VIN=24V, VOUT=12V 0 0.001 R2 0.01 0.1 1 IOUT(A) For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 1 SCT2400 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0: Production Revision 1.1: Correct EN pin function description in page 2 Revision 1.2: Update efficiency curve and application waveform DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION 2400 6-Lead Plastic TSOT23-6 SCT2400TVB 1)For Tape & Reel, Add Suffix R (e.g. SCT2400TVBR). ABSOLUTE MAXIMUM RATINGS Over operating free-air temperature unless otherwise PIN CONFIGURATION noted (1) DESCRIPTION MIN MAX UNIT VIN, SW, EN -0.3 42 V BST -0.3 49 V SW -1 42 V BST-SW -0.3 7 V FB -0.3 6 V Operating junction temperature (2) -40 150 C Storage temperature TSTG -65 150 C BST 1 6 SW GND 2 5 VIN FB 3 4 EN 6-Lead Plastic TSOT23-6 (1) (2) Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. BST 1 Power supply for the high-side power MOSFET gate driver. Must connect a 0.1uF or greater ceramic capacitor between BST pin and SW node. GND 2 GND FB 3 Buck converter output feedback sensing voltage. Connect a resistor divider from VOUT to FB to set up output voltage. The device regulates FB to the internal reference of 0.81V typically. 2 PIN FUNCTION EN 4 VIN 5 Enable logic input. This pin supports high voltage input up to VIN supply to be connected VIN directly to enable the device automatically. The device has precision enable thresholds 1.21V rising / 1.1V falling for programmable UVLO threshold and hysteresis. Power supply input. Must be locally bypassed. SW 6 Switching node of the buck converter. For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN TJ Input voltage range Operating junction temperature MIN MAX UNIT 4.5 -40 40 125 V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER DEFINITION Human Body Model (HBM), per ANSI-JEDEC-JS-0012014 specification, all pins(1) Charged Device Model (CDM), per ANSI-JEDEC-JS-0022014specification, all pins(1) VESD (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER RθJA THERMAL METRIC TSOT23-6 Junction to ambient thermal resistance(1) RθJC Junction to case thermal UNIT 89 resistance(1) °C/W 39 (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT2400 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT2400. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. ELECTRICAL CHARACTERISTICS VIN=12V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply and Output VIN Operating input voltage ISD Input UVLO Hysteresis Shutdown current IQ Quiescent current VIN_UVLO MIN 4.5 VIN rising 4.3 440 1 EN=0, No load, VIN=12V EN=floating, No load, No switching. VIN=12V. BSTSW=5V 1.21 Enable low threshold MAX 0.9 UNIT 40 V 5 V mV uA 90 Enable, Soft Start and Working Modes VEN_H Enable high threshold VEN_L TYP uA 1.4 V 1.1 V Power MOSFETs RDSON_H High side FET on-resistance 600 mΩ RDSON_L 300 mΩ Low side FET on-resistance Feedback and Error Amplifier VFB Feedback Voltage 0.79 0.81 0.83 V Current Limit For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 3 SCT2400 SYMBOL PARAMETER ILIM_HSD HSD peak current limit ILIM_LSD LSD valley current limit TEST CONDITION TYP MAX 0.7 0.9 1.1 0.8 Switching Frequency FSW Switching frequency tON_MIN MIN VIN=12V, VOUT=5V Minimum on-time 1600 2000 UNIT A A 2400 kHz 80 ns 1 ms Soft Start Time tSS Internal soft-start time Protection VOVP TSD* Feedback overvoltage with respect to VFB/VREF rising 110 % reference voltage VFB/VREF falling 105 % Thermal shutdown threshold Hysteresis TJ rising 170 25 °C *Derived from bench characterization 4 For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 100 100 90 90 80 80 70 70 Effieiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 60 50 40 30 20 60 50 40 30 20 VIN=12V 10 VIN=24V 0 0.001 0.01 VIN=24V 10 0.1 VIN=36V 0 0.001 1 0.01 IOUT(A) Figure 1. Efficiency vs Load Current, Vout=5V 1 Figure 2. Efficiency vs Load Current, Vout=12V 12.40 5.10 12.35 5.09 5.08 12.30 Output Voltage (V) Output Voltage (V) 0.1 IOUT(A) 12.25 12.20 12.15 12.10 5.07 5.06 5.05 5.04 5.03 5.02 12.05 5.01 12.00 0.001 0.01 0.1 5.00 0.001 1 0.01 IOUT (A) 0.1 1 IOUT (A) Figure 3. Load Regulation (Vout=12V), Vin=24V Figure 4. Load Regulation (Vout=5V), Vin=24V 0.95 0.815 0.814 0.813 0.90 HS OC Limit (A) VREF (V) 0.812 0.811 0.81 0.809 0.808 0.807 0.85 0.80 0.75 0.806 0.805 -50 -25 0 25 50 75 100 125 Temperature (°C) 0.70 -50 -25 0 25 50 75 100 125 Temperature (°C) Figure 5. Reference VS Temperature Figure 6. HS Current Limit VS Temperature For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 5 SCT2400 TYPICAL CHARACTERISTICS 0.95 110 105 100 0.85 Iq (uA) LS OC Limit (A) 0.90 0.80 95 90 85 80 0.75 75 0.70 70 -50 -25 0 25 50 75 100 125 -50 -25 0 25 Temperature (°C) 50 75 100 125 Temperature (°C) Figure 7. LS Current Limit VS Temperature Figure 8. Quiescent Current vs Temperature VIN=12V 1.30 5.0 4.5 1.25 1.20 3.5 EN (V) Isd (uA) 4.0 3.0 2.5 1.15 1.10 2.0 1.05 1.5 1.0 -50 -25 0 25 50 75 100 EN_RISING EN_FALLING 1.00 125 -50 -25 0 Temperature (°C) 25 50 75 100 Temperature (°C) Figure 9. Shutdown Current vs Temperature, Vin=24V Figure 10. EN Threshold vs Temperature 4.40 130 128 126 4.20 VOVP_R(%) UVLO (V) 4.30 4.10 UVLO_RISING UVLO_FALLING 4.00 124 122 120 118 116 OVP_RISING 114 3.90 OVP_FALLING 112 110 3.80 -50 -25 0 25 50 75 100 125 Figure 11. VIN UVLO VS Temperature 6 For more information www.silicontent.com -50 0 50 Temperature (°C) Temperature (°C) Figure 12. OVP VS Temperature © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 100 125 SCT2400 FUNCTIONAL BLOCK DIAGRAM VIN 5 UVLO EN 4 + VIN UVLO and LDO EN VCC 1.21V 480K VCC HS MOSFET Current Limit BOOT UVLO Ramp SS 0.81V FB + + GM COMP BOOT Strap PWM + 1 BST Q1 3 PWM and Dead Time Control Logic + 6 SW OVP 0.88V Q2 Oscillator with PLL CLK Thermal Protection LS MOSFET Current Limit 2 GND Figure 13. Functional Block Diagram For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 7 SCT2400 OPERATION Overview The SCT2400 device is 4.5V-40V input, 600mA output, fully integrated synchronous buck converters. The device employs fixed frequency peak current mode control. An internal clock with 2MHz frequency initiates turning on the integrated high-side power MOSFET Q1 in each cycle, then inductor current rises linearly and the converter charges output cap. When sensed voltage on high-side MOSFET peak current rising above the voltage of internal COMP (see functional block diagram), the device turns off high-side MOSFET Q1 and turns on low-side MOSFET Q2. The inductor current decreases when MOSFET Q2 is ON. In the next rising edge of clock cycle, the low-side MOSFET Q2 turns off. This repeats on cycle-by-cycle based. The peak current mode control with the internal loop compensation network and the built-in 1ms soft-start simplify the SCT2400 footprints and minimize the off-chip component counts. Meanwhile, it reduces the external passive components size as well. The quiescent current of SCT2400 is 90uA typical under no-load and without switching condition. When disabling the device, the supply shut down current is only 1μA. The SCT2400 works at Pulse Skipping Mode PSM to further increase the power efficiency in light load condition. Peak Current Mode Control and Pulse Skipping Mode The SCT2400 employs fixed frequency peak current mode control. An internal clock initiates turning on the integrated high-side power MOSFET Q1 in each cycle, then inductor current rises linearly. When the current through high-side MOSFET reaches the threshold level set by the COMP voltage of the internal error amplifier, the highside MOSFET turns off. The synchronous low-side MOSFET Q2 turns on till the next clock cycle begins or the inductor current falls to zero. The error amplifier serves the COMP node by comparing the voltage of the FB pin with an internal 0.81V reference voltage. When the load current increases, a reduction in the feedback voltage relative to the reference raises COMP voltage till the average inductor current matches the increased load current. This feedback loop well regulates the output voltage to the reference. The device also integrates an internal slope compensation circuitry to prevent subharmonic oscillation when duty cycle is greater than 50% for a fixed frequency peak current mode control. The SCT2400 operates in Pulse Skipping Mode (PSM) with light load current to improve efficiency. When the load current decreases, an increment in the feedback voltage leads COMP voltage drop. When COMP falls to a low clamp threshold (400mV typically), device enters PSM. The output voltage decays due to output capacitor discharging during skipping period. Once FB voltage drops lower than the reference voltage, and the COMP voltage rises above low clamp threshold. Then high-side power MOSFET turns on in next clock pulse. After several switching cycles with typical 50mA peak inductor current, COMP voltage drops and is clamped again and pulse skipping mode repeats if the output continues light loaded. This control scheme helps achieving higher efficiency by skipping cycles to reduce switching power loss and gate drive charging loss. VIN Power The SCT2400 is designed to operate from an input voltage supply range between 4.5V to 40V, at least 0.1uF decoupling ceramic cap is recommended to bypass the supply noise. If the input supply locates more than a few inches from the converter, an additional electrolytic or tantalum bulk capacitor or with recommended 10uF may be required in addition to the local ceramic bypass capacitors. 8 For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 Enable and Under Voltage Lockout UVLO The SCT2400 Under Voltage Lock Out (UVLO) default startup threshold is typical 4.3V with VIN rising and shutdown threshold is 3.8V with VIN falling. The more accurate UVLO threshold can be programmed through the precision enable threshold of EN pin. When applying a voltage higher than the EN high threshold (typical 1.21V/rising), the SCT2400 enables all functions and the device starts soft-start phase. The SCT2400 has the built in 1ms soft-start time to prevent the output overshoot and inrush current. When EN pin is pulled low, the internal SS net will be discharged to ground. Buck operation is disabled when EN voltage falls below its lower threshold (typically 1.1V/falling). An internal 480k pull down resistor make EN pin floating shut down the SCT2400. For the application requiring higher VIN UVLO voltage than the default setup, connecting an external R3 to VIN to program the new VIN UVLO. The resistor divider R3 is calculated by equation (1). If there is no requirement for the VIN UVLO program, connect the EN to VIN to simplify the external circuitry. EN pin is a high voltage pin and can be directly connected to VIN to automatically start up the device with VIN rising to its internal UVLO threshold. VIN R3 EN 4 + EN 1.21V 480K Figure 14. Adjustable VIN UVLO 𝑅3 = (𝑉𝑟𝑖𝑠𝑒 − 1.21) ∗ 480𝑘 1.21 (1) Where: Vrise: Vin rise threshold to enable the device Output Voltage The SCT2400 regulates the internal reference voltage at 0.81V with  2.5% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 2 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (2) where  RFB_TOP is the resistor connecting the output to the FB pin. For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 9 SCT2400  RFB_BOT is the resistor connecting the FB pin to the ground. Peak Current Limit The SCT2400 has cycle-by-cycle peak current limit with sensing the internal high side MOSFET Q1 current during overcurrent condition. While the Q1 turns on, its conduction current is monitored by the internal sensing circuitry. Once the high-side MOSFET Q1 current exceeds the limit, it turns off immediately. The maximum current passing through the power MOSFET is limited cycle-by-cycle. The switching frequency folds back to prevent an inductor current run-away during start-up or short circuit. Bootstrap Voltage Regulator An external bootstrap capacitor between BST and SW pin powers floating high-side power MOSFET gate driver. The bootstrap capacitor voltage is charged from an integrated voltage regulator when high-side power MOSFET is off and low-side power MOSFET is on. The floating supply (BST to SW) UVLO threshold is 2.7V rising and hysteresis of 350mV. When the converter operates with high duty cycle or prolongs in sleep mode for certain long time, the required time interval to recharging bootstrap capacitor is too long to keep the voltage at bootstrap capacitor sufficient. When the voltage across bootstrap capacitor drops below 2.35V, BST UVLO occurs. The SCT2400 intervenes to turn on low side MOSFET periodically to refresh the voltage of bootstrap capacitor to guarantee operation over a wide duty range. Internal Soft-Start The SCT2400 integrates an internal soft-start circuit that ramps the reference voltage from zero volts to 0.81V reference voltage in 1ms. If the EN pin is pulled below 1.1V, switching stops and the internal soft-start resets. The soft-start also resets during shutdown due to thermal overloading. Over Current Protection The SCT2400 implements over current protection with cycle-by-cycle limiting high-side MOSFET peak current and low-side MOSFET valley current to avoid inductor current running away during unexpected overload or output hard short condition. The inductor current IL is monitored during high-side MOSFET Q1 and low-side MOSFET Q2 on. As shown in Figure 15, when overload or hard short happens, once the high-side MOSFET Q1 current exceeds the HS limit, Q1 is turned off immediately and Q2 is turned on. If the low-side MOSFET Q2 current is higher than the LS current limit during Q2 ON time and next switching cycle will be skipped until Q2 current is lower than LS current limit. Then, Q1 is turned on and Q2 is turned off in another Over protection cycle until the overload or hard short is released. Q1 HS limit LS limit IL Overload/ Hard short Happens VOUT Figure 15 Over Current Protection 10 For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 Over voltage Protection The SCT2400 implements the Over-voltage Protection OVP circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When FB voltage exceeds 110% of internal 0.81V reference voltage, the high-side MOSFET turns off to avoid output voltage continue to increase. When the FB pin voltage falls below 105% of the 0.81V reference voltage, the high-side MOSFET can turn on again. Thermal Shutdown Once the junction temperature in the SCT2400 exceeds 170°C, the thermal sensing circuit stops converter switching and restarts with the junction temperature falling below 145°C. Thermal shutdown prevents the damage on device during excessive heat and power dissipation condition. . For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 11 SCT2400 APPLICATION INFORMATION Typical Application C4 0.1uF L1 15uH 1 2 BST SW GND VIN FB EN 3 6 VOUT=5V 5 4 VIN=24V C5 22uF R3 100K C1 0.1uF C2 4.7uF C6 100uF (Optional) C3 47uF R1 105K C7 100pF (Optional) (Optional) R2 20K Figure 16. 24V Input, 5V/0.6A Output C4 0.1uF L1 22uH 1 2 BST SW GND VIN FB EN 3 6 VOUT=12V 5 4 VIN=24V C5 22uF R3 100K C1 0.1uF C2 4.7uF C6 100uF (Optional) C3 47uF R1 280K C7 100pF (Optional) (Optional) R2 20K Figure 17. 24V Input, 12V/0.6A Output Design Parameters 12 Design Parameters Example Value Input Voltage 24V Output Current 0.6A Switching Frequency 2MHz Start Input Voltage (rising VIN) 20V Stop Input Voltage (falling VIN) 16V For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 Output Voltage The output voltage is set by an external resistor divider R1 and R2 in typical application schematic. Recommended R2 resistance is 20KΩ. Use equation 3 to calculate R1. 𝑉𝑂𝑈𝑇 𝑅1 = ( − 1) ∗ 𝑅2 𝑉𝑅𝐸𝐹 where: (3)  VREF is the feedback reference voltage, typical 0.81V Table 1. R1, R2Value for Common Output Voltage (Room Temperature) VOUT R1 R2 1.8 V 24.9 KΩ 20 KΩ 2.5 V 42.2 KΩ 20 KΩ 3.3 V 62 KΩ 20 KΩ 5 V 105 KΩ 20 KΩ 12 V 280 KΩ 20 KΩ Under Voltage Lock-Out An external resistor R3 from the input to EN pin can set the input voltage’s Under Voltage Lock-Out (UVLO) threshold higher than the default 4.3V, like shown in Figure 14. The UVLO has two thresholds, one for power up when the input voltage is rising and the other for power down or brown outs when the input voltage is falling. Use Equation 4 to calculate the values of R3. The power off voltage of UVLO can be derived by Equation 5. Vrise = 1.21 ∗ (1 + Vfall = 1.1 ∗ (1 + 𝑅3 ) 480k (4) 𝑅3 ) 480k (5) Inductor Selection There are several factors should be considered in selecting inductor such as inductance, saturation current, the RMS current and DC resistance (DCR). Larger inductance results in less inductor current ripple and therefore leads to lower output voltage ripple. However, the larger value inductor always corresponds to a bigger physical size, higher series resistance, and lower saturation current. A good rule for determining the inductance to use is to allow the inductor peak-to-peak ripple current to be approximately 20%~30% of the maximum output current. The peak-to-peak ripple current in the inductor ILPP can be calculated as in Equation 6. 𝐼𝐿𝑃𝑃 = Where      𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 ∗ 𝐿 ∗ 𝑓𝑆𝑊 (6) ILPP is the inductor peak-to-peak current L is the inductance of inductor fSW is the switching frequency VOUT is the output voltage VIN is the input voltage Since the inductor-current ripple increases with the input voltage, so the maximum input voltage in application is always used to calculate the minimum inductance required. Use Equation 7 to calculate the inductance value. 𝐿𝑀𝐼𝑁 = 𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 ∗ (1 − ) 𝑓𝑆𝑊 ∗ 𝐿𝐼𝑅 ∗ 𝐼𝑂𝑈𝑇(𝑚𝑎𝑥) 𝑉𝐼𝑁(𝑚𝑎𝑥) (7) For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 13 SCT2400 Where       LMIN is the minimum inductance required fsw is the switching frequency VOUT is the output voltage VIN(max) is the maximum input voltage IOUT(max) is the maximum DC load current LIR is coefficient of ILPP to IOUT The total current flowing through the inductor is the inductor ripple current plus the output current. When selecting an inductor, choose its rated current especially the saturation current larger than its peak operation current and RMS current also not be exceeded. Therefore, the peak switching current of inductor, ILPEAK and ILRMS can be calculated as in equation 8 and equation 9. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐼𝐿𝑃𝑃 2 𝐼𝐿𝑅𝑀𝑆 = √(𝐼𝑂𝑈𝑇 )2 + Where     (8) 1 ∗ (𝐼𝐿𝑃𝑃 )2 12 (9) ILPEAK is the inductor peak current IOUT is the DC load current ILPP is the inductor peak-to-peak current ILRMS is the inductor RMS current In overloading or load transient conditions, the inductor peak current can increase up to the switch current limit of the device which is typically 0.8A. The most conservative approach is to choose an inductor with a saturation current rating greater than 0.8A. Because of the maximum ILPEAK limited by device, the maximum output current that the SCT2400 can deliver also depends on the inductor current ripple. Thus, the maximum desired output current also affects the selection of inductance. The smaller inductor results in larger inductor current ripple leading to a higher maximum output current. 22uH inductor value is recommended for 12V output voltage and 15uH inductor is recommended for 5V output voltage. Input Capacitor Selection The input current to the step-down DCDC converter is discontinuous, therefore it requires a capacitor to supply the AC current to the step-down DCDC converter while maintaining the DC input voltage. Use capacitors with low ESR for better performance. Ceramic capacitors with X5R or X7R dielectrics are usually suggested because of their low ESR and small temperature coefficients, and it is strongly recommended to use another lower value capacitor (e.g. 0.1uF) with small package size (0603) to filter high frequency switching noise. Place the small size capacitor as close to VIN and GND pins as possible. The voltage rating of the input capacitor must be greater than the maximum input voltage. And the capacitor must also have a ripple current rating greater than the maximum input current ripple. The RMS current in the input capacitor can be calculated using Equation 10. ICINRMS = IOUT ∗ √ VOUT VOUT ∗ (1 − ) VIN VIN (10) The worst case condition occurs at VIN=2*VOUT, where: ICINRMS = 0.5 ∗ IOUT 14 (11) For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 For simplification, choose an input capacitor with an RMS current rating greater than half of the maximum load current. When selecting ceramic capacitors, it needs to consider the effective value of a capacitor decreasing as the DC bias voltage across a capacitor increases. The input capacitance value determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 12 and the maximum input voltage ripple occurs at 50% duty cycle. ∆VIN = IOUT VOUT VOUT ∗ ∗ (1 − ) fSW ∗ CIN VIN VIN (12) For this example, a 4.7μF, X7R ceramic capacitors rated of 50 V in parallel are used. And a 0.1 μF for high-frequency filtering capacitor is placed as close as possible to the device pins. Bootstrap Capacitor Selection A 0.1μF ceramic capacitor must be connected between BOOT pin and SW pin for proper operation. A ceramic capacitor with X5R or better grade dielectric is recommended. The capacitor should have a 10V or higher voltage rating. Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 13 desired. ∆VOUT = Where       𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (13) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 ΔVOUT is the output voltage ripple fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VIN is the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, one 22μF ceramic output capacitors work for most applications. For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 15 SCT2400 Application Waveforms Unless otherwise noted the following conditions apply: Vin=24V, VOUT=12V, FSW=2000kHz. 16 Figure 17. Power up Figure 19. Power down Figure 20.Load Transient (0.06A-0.54A, 250mA/us) Figure 21. SW and Vout Ripple (Iout=0.6A) Figure 22. SW and Vout Ripple (Iout=0A) Figure 23. Thermal, 24VIN, 12Vout, 0.6A For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 Layout Guideline The regulator could suffer from instability and noise problems without carefully layout of PCB. Radiation of highfrequency noise induces EMI, so proper layout of the high-frequency switching path is essential. 1. Minimize the length and area of all traces connected to the SW pin, and always use a ground plane under the switching regulator to minimize coupling. 2. The input capacitor needs to be very close to the VIN pin and GND pin to reduce the input supply ripple. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 3. Output inductor should be placed close to the SW pin. The area of the PCB conductor minimized to prevent excessive capacitive coupling. 4. The layout needs be done with well consideration of the thermal. A large top layer ground plate using multiple thermal vias is used to improve the thermal dissipation. The bottom layer is a large ground plane connected to the top layer ground by vias. VOUT Inductor Output capacitors BST SW GND VIN FB EN VIN VIN Input Capacitor Feedback Resistors GND Figure 24. PCB Layout Example For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 17 SCT2400 PACKAGE INFORMATION TOP VIEW BOTTOM VIEW SYMBOL SIDE VIEW NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. 18 For more information www.silicontent.com A A1 A2 D E E1 b c e L ɵ Unit: Millimeter MIN TYP MAX ------1.10 0.000 0.10 0.70 1.00 2.85 2.95 2.65 2.95 1.55 1.65 0.30 0.50 0.08 0.20 0.95(BSC) 0.30 0.60 0º 8º © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 SCT2400 TAPE AND REEL INFORMATION Feeding Direction For more information www.silicontent.com © 2020 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2400 19
SCT2400TVBR 价格&库存
很抱歉,暂时无法提供与“SCT2400TVBR”相匹配的价格&库存,您可以联系我们找货
