Specifications:
Voltage rating:500VAC/DC
500V AC/DC
Current rating:5A AC/DC
5A AC/DC
Withstanding voltage:500V AC/minute
C
Temperature range:-25
-40 -+105
B
Materiai
3.7 [0.128]
8.2[0.294]
2.84 [0.110]
A
-+85
D
1.385 [0.055]
2.77 [0.110]
Rubber core:PBT+30
G.F(UL94V-0)-WH
PBT+30 G F(UL94V-0)-WH
Car PIN:C3604(BRASS)AU 1U
PIN:C3604(BRASS)
1u
The iron shell:SPCC Nivkel Plating/Tin Plating
SPCC,
The matters needing attention
A Salt spray test for 24H cannot have
A
24H
B The finished product cannot have curved curved needle as well as the R
Angle is.
B
R
X01 XX W X X X X
1
2
3
4
5
6
7
1 Series N0.
2 Row No.Pin No.XX-09;15;25;37
3 Welding Board Angle :W-male
4 T
TYPE-3
6.2 [0.242]
TYPE-2
C
Car-pin
4.00 [0.157]
7 1:TYPE-1; 2:TYPE-2; 3:TYPE-3; 4:TYPE-4; 5:TYPE-5
NO of
C0ntact
9
15
25
37
units: mm
tolerance:
X
X
16.92
25.25
38.96
55.42
24.99
33.32
47.04
63.05
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
UNSPECIFIED TOLERANCES
www.helloxkb.cn
30.81
39.14
53.04
69.32
19.28
27.51
41.28
57.71
DSND
DATE
SCALE: N/A MODEL TYPE:
DWN
DATE
VIEW:
CHKD
DATE
UNIT: mm/in
APPD
DATE
X
MARK
AuSn
6 B:BLACK W:White BL:Blue Y:Yellow G:Green R:Red
5.80 [0.227]
0.8 [0.039]
Tradutional
5 Planting Categotry: 1:1U 2:2U 3:3U 4:5U 5:15U 6:30U 7
XKB INDUSTRIAL PRECISION CO.,LIMITED
PART NO.:
DWG NO.:
X01XXWXXXX
WEIGHT
1.0g
SHEET
1/1
REVISION
A0
很抱歉,暂时无法提供与“X0109WT7B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.46440
- 10+0.44720
- 100+0.39560
- 500+0.38528
- 国内价格
- 1+2.97000
- 10+2.38680
- 50+1.94400
- 100+1.54926
- 500+1.41588
- 1000+1.33380
