TPESD9X3.3ST5G
1-Lin Uni-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
100W peak pulse power (8/20μs)
Protects one data or power line
Operating voltage: 3.3V
Ultra low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (SURGE) 10A (8/20us)
Ultra low leakage: nA level
UL Flammability Classification Rating 94V-0
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Mobile Phones and Accessories
Battery Protection
USB VBus
Power Line Protection
Hand Held Portable Applications
舟
7”
电
8000
Reel Size
台
TPESD9X3.3ST5G
Qty per Reel
Package:SOD-923(0402)
Applications
Ordering Information
Part Number
子
Dimensions and Pin Configuration
1
TPESD9X3.3ST5G
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
100
W
Peak Pulse Current (8/20µs)
IPP
10
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Breakdown Voltage
Test Condition
Min
VRWM
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
Junction Capacitance
CJ
Max Unit
3.3
IT = 1mA(Pin1-Pin2)
VRWM = 3.3V(Pin2 -Pin1)
IPP = 1A (8 x 20us pulse)
(Pin1-Pin2)
IPP = 10A (8 x 20us pulse)
(Pin1-Pin2)
VR = 0V, f = 1MHz
舟
电
子
Reverse Leakage Current
Typ
2
5
V
V
0.1
µA
8
V
11
V
90
pF
TPESD9X3.3ST5G
www.sot23.com.tw
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
10
15
t - Time ( s)
Power Derating Curve
110
100
90
80
70
60
50
40
30
台
% of Rated Power
30
舟
Fig3.
25
电
50
75
100
125
10%
子
90%
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPESD9X3.3ST5G
www.sot23.com.tw
Outline Drawing - SOD-9 23(0402)
A
B
DIM
C
电
D
台
舟
F
子
E
Land Pattern - SOD-9 23(0402)
0.90 mm
0.40mm
0.30mm
4
A
B
C
D
E
F
DIMENSIONS
INCHES
MM
MAX
MIN
MAX
MIN
.037
.041
0.95
1.05
.030
.033
0.75
0.85
.022
.026
0.55
0.65
.014
.017
0.36
0.43
.006
.010
0.15
0.25
.003
.007
0.07
0.17
NOTE
很抱歉,暂时无法提供与“TPESD9X3.3ST5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26690
- 100+0.21285
- 1600+0.16553
- 3200+0.14929
- 8000+0.11939
- 国内价格
- 10+0.29117
- 100+0.23220
- 300+0.20261
- 1000+0.18058
- 5000+0.16287
- 8000+0.13025
