BDFN2C071V
ESD Protection Diode
»Features
100Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche t echnology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A ( 5/50ns)
IEC 61000-4-5 (Lightning) 8A (8/20μs)
»Applications
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Pagers Peripherals
»Mechanical Data
DFN1006 package
Molding compound flammability rating: UL 94V-0
Packaging: Tape and Reel
RoHS/WEEE Compliant
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
BDFN2C071V
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
100
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
8
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
7.2
Max
Units
7.0
V
7.5
VBR
IT=1mA
V
Reverse Leakage Current
IR
VRWM=7V,T=25℃
Clamping Voltage
VC
IPP=8A,tp=8/20μs
12
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
15
pF
1
uA
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
IT
I
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
V
Breakdown Voltage @ IT
Test Current
Note:. 8/20μs pulse waveform.
Revision 2018
www.born-tw.com
2/4
BDFN2C071V
»Typical Characteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
100w 8/20µs waveform
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ipp
80
70
Percent
-1
e
60
125
150
50
40
30
td=Ipp/2
Test
Wavefor m
Paramter s
tr=8µs
td=20µs
16
Clamping Voltage–VC (V)
90
100
Figure 4: Clamping Voltage vs.Ipp
Waveform
Paramters
tr=8µs
td=20µs
100
75
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
110
50
14
12
10
8
6
4
2
10
10
15
30
3
4
5
6
7
Peak Pulse Current–IPP (A)
Time (µs)
Revision 2018
1
www.born-tw.com
3/4
8
BDFN2C071V
»Outline Drawing – DFN1006
»Marking
C7
»Ordering information
Order code
BDFN2C071V
Revision 2018
Package
DFN1006
Base qty
10K
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“BDFN2C071V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.68370
- 500+0.22704
- 5000+0.15222
- 10000+0.12462
- 国内价格
- 20+0.23138
- 200+0.18904
- 国内价格
- 20+0.25499
- 200+0.20834
- 600+0.18242
- 2000+0.16686
- 10000+0.14667
- 20000+0.13932
