BSD5C051U
ESD Protection Diode
»Features
60Watts peak pulse power (tp = 8/20μs)
SOD523 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.5pF typ.)
Protection one data/power line
IEC 61000-4-2 ±15kV contact ±20kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3A(8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets and Accessories
SOD523 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
BSD5C051U
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
60
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3
A
VESD
kV
Lead SolderingTemperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Conditions
Reverse Stand-Off Voltage
VRWM
Reverse BreakdownVoltage
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage
VC
IPP=3A,tp=8/20μs
Junction Capacitance
Cj
VR = 0V, f = 1MHz
Min
6.0
Typical
Max
Units
5.0
V
8.5
V
0.1
0.5
0.5
μA
3
A
V
0.9
pF
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
V C V BR
V RW M
IT
IR
I
IT R
V RW M
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
BSD5C051U
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
60w 8/20µswaveform
0.1
0.01
1
0.1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
90
Percent
Ipp
80
e-1
50
40
td=Ipp/2
150
18
Clamping Voltage–VC (V)
100
30
100
Waveform
Paramters
tr=8µs
td=20µs
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
16
14
Test
Waveform
Paramters
tr=8µs
td=20µs
12
10
8
6
4
10
2
Revision 2018
5
10
15
Time (µs)
30
www.born-tw.com
1
2
3
4
5
6
Peak Pulse Current–IPP (A)
3/4
BSD5C051U
»Outline Drawing – SOD523
D
-X-YE
DIMENSIONS
2
1
SYMBOL
b 2x
0.08 (0.0032)
X
A
b
C
D
E
HE
L
Y
A
C
HE
L
MILLIMETER
MIN
0.50
0.25
0.07
1.10
0.70
1.50
0.15
MAX
0.70
0.35
0.20
1.30
0.90
1.70
0.25
INCHES
MIN
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
MAX
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Marking
1
5S
2
»Ordering information
Order code
BSD5C051U
Revision 2018
Package
SOD523
Base qty
5000
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“BSD5C051U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31155
- 100+0.30688
- 1000+0.23463
- 2000+0.23111
- 5000+0.17751
- 国内价格
- 1+0.31350
- 500+0.20900
- 2500+0.18150
- 5000+0.16500
- 国内价格
- 20+0.33250
- 200+0.27740
- 600+0.24960
- 5000+0.18810
- 10000+0.17180
- 20000+0.16340
- 国内价格
- 20+0.33988
- 200+0.28394
- 600+0.25596
- 5000+0.19365
- 10000+0.17680
- 20000+0.16848
