PESD3V3S1BA-N
ESD Protection Diode
»Features
100Watts peak pulse power (tp =8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±25kV contact ±25kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 10A(8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
SOD523 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
PESD3V3S1BA-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
100
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
25
25
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Conditions
Min
Typical
VRWM
Max
Units
3.3
V
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5.0V,T=25℃
500
uA
Clamping Voltage
VC
IPP=10A,tp=8/20μs
10
V
Junction Capacitance
Cj
VR = 0V, f =1MHz
15
pF
Reverse BreakdownVoltage
4.0
V
13
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD3V3S1BA-N
»Typical Characteristics
Figure 1: Peak Pulse Power vs. Pulse Time
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW )
100
1
100w 8/20μs waveform
0.1
0.01
0.1
1
10
td – Pulse Duration - µs
100
Ipp
80
Percent
50
40
30
50
75
100
125
Ambient Temperature - TA (℃)
150
9
Clamping Voltage–VC (V)
90
e
-1
50
40
td=Ipp/2
10
Waveform
Paramters
tr=8µs
td=20µs
100
30
70
Figure 4: Clamping Voltage vs.Ipp
110
60
80
1,000
Figure3: Pulse Waveform
70
90
Test
Waveform
Paramters
tr=8µs
td=20µs
8
7
6
5
4
3
2
10
10
15
30
6
8
10
Peak Pulse Current–IPP (A)
Time (µs)
Revision 2018
2
www.born-tw.com
3/4
PESD3V3S1BA-N
»Outline Drawing – SOD523
D
-X-YE
1
DIMENSIONS
2
SYMBOL
b 2x
0.08 (0.0032)
X
A
b
C
D
E
HE
L
Y
A
C
HE
L
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
0.50
0.25
0.07
1.10
0.70
1.50
0.15
0.70
0.35
0.20
1.30
0.90
1.70
0.25
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Marking
1
CT
2
»Ordering information
Order code
PESD3V3S1BA-N
Revision 2018
Package
Base qty
Delivery mode
SOD523
5000
Tape and reel
www.born-tw.com
4/4
很抱歉,暂时无法提供与“PESD3V3S1BA-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.24360
- 200+0.19120
- 600+0.16800
- 5000+0.12540
- 10000+0.11850
- 20000+0.11390
- 国内价格
- 1+0.12430
- 5000+0.11330
- 国内价格
- 20+0.24527
- 200+0.19278
- 600+0.16946
- 5000+0.12669
- 10000+0.11967
- 20000+0.11502
- 国内价格
- 20+0.22483
- 500+0.15533
- 2000+0.15300
- 5000+0.11613
- 25000+0.11497
