PRTR5V0U2X-N
ESD Protection Diode Array
»Features
40Watts peak pulse power (tp = 8/20μs)
Tiny SOT143 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.35pF typ I/O to I/O.)
Protection one data/power line
IEC 61000-4-2 ±15kV contact ±20kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3.5A (8/20μs)
»Mechanical Data
»Applications
USB2.0,
SOT143 package
Ethernet
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Video Line Protection
RoHS/WEEE Compliant
»Schematic & PIN Configuration
Pin 4
Pin 2
1
4
2
3
Pin 3
Pin 1
Revision 2018
www.born-tw.com
1/4
PRTR5V0U2X-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
40
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
3.5
A
VESD
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
50
Clamping Voltage
VC
IPP=3.5A,tp=8/20μs
10
VR = 0V, f = 1MHz
IO to IO
0.35
VR = 0V, f = 1MHz
IO to GND
0.65
Reverse Breakdown Voltage
Junction Capacitance
Cj
6.0
Max
Units
5.0
V
V
7.2
500
nA
V
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC VBR VRWM
Breakdown Voltage @ IT
IT
IR
IR
IT
VRWM VBR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PRTR5V0U2X-N
»Typical Characteristics
Figure 2: Power Derating Curve
10
110
1
40w 8/20 sµaveform
0.1
0.01
0.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
90
Percent
Ipp
80
e-1
50
40
td=Ipp/2
12
10
Test
Waveform
Paramters
tr=8µs
td=20µs
8
6
2
5
Revision 2018
10
15
150
16
4
10
18
Clamping Voltage–VC (V)
100
30
100
Waveform
Paramters
tr=8µs
td=20µs
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PRTR5V0U2X-N
»Outline Drawing – SOT143
DIMENSIONS
D
e
SYMBOL
A
E
E1
b×N
bbb
M
A2
A1
aaa M
C A B
MIN
MAX
MIN
MAX
1.150
0.035
0.045
A1
0.000
0.100
0.900
1.050
0.000
0.004
0.035
0.041
b
0.300
0.500
0.012
0.020
b1
0.750
0.900
0.030
0.035
D
2.800
3.000
0.110
0.118
e
1.800
2.000
0.071
0.079
0.200TYP
0.008TYP
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
θ
0°
8°
0°
8°
aaa
.006
0.15
bbb
.008
0.20
ccc
.004
0.10
C A B
θ
A
4×
ccc C
SEATING PLANE
b1
INCHES
0.900
A2
e1
e1
MILLIMETER
0.25
L
C
L1
»Marking
E5R
»Ordering information
Order code
PRTR5V0U2X-N
Revision 2018
Package
Base qty
Delivery mode
SOT143
3k
Tape and reel
www.born-tw.com
4/4
很抱歉,暂时无法提供与“PRTR5V0U2X-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.67030
- 50+0.53980
- 150+0.47570
- 500+0.42750
- 3000+0.30670
- 6000+0.28740
- 国内价格
- 20+0.36250
- 200+0.33750
- 600+0.31250
- 3000+0.28750
- 国内价格
- 1+0.57640
- 200+0.37290
- 1500+0.32450
- 3000+0.28710
