ESD5451N
ESD5451N
    KUU(永裕泰)
    DFN1006-2
    5V
ESD5451N 数据手册
ESD5451N TVS/ESD Protection Diode DESCRIPTION ESD5451N is a low-capacitance Transient Voltage Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection for data, control or power lines. With typical capacitance of 8pF only, ESD5451N is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. FEATURES — Transient protection for high-speed data lines IEC 61000-4-2 (ESD) ±15kV (Air) ±8kV (Contact) IEC 61000-4-4 (EFT) 40A (5/50 ns) Cable Discharge Event (CDE) — Package optimized for high-speed lines — Ultra-small package (1.0mm×0.6mm×0.4mm) — Protects one data, control or power line — Low capacitance — Low leakage current — Low clamping voltage — Each I/O pin can withstand over 1000 ESD strikes for ±8kV contact discharge MACHANICAL DATA — DFN1006 package — Flammability Rating: UL 94V-0 — Packaging: Tape and Reel — High temperature soldering guaranted:260℃/10s — Reel size: 7 inch ORDERING INFORMATION APPLICATIONS — Package: DFN1006 — Material: RoHS compliant, Halogen free — Packing: Tape & Reel — Quantity per reel: 10,000pcs — Portable Electronics — Desktops, Servers and Notebooks — Cellular Phones — MP3 Ports — Digital Ports — Subscriber Identity Module (SIM) card CIRCUIT DIAGRAM PIN CONFIGURATION 1/4 ESD5451N TVS/ESD Protection Diode ABSOLUTE MAXIMUM RATING Symbol PPP Tj TSTG Parameter Value Units 100 W Operating Temperature -55/+125 °C Storage Temperature -55/+150 °C Peak Pulse Power (8/20μs) ELECTRICAL CHARACTERISTICS (Tamb=25°C) Symbol Parameter Test Condition VRWM Reverse Stand-Off Voltage VBR Reverse Breakdown voltage IT=1mA IR Reverse leakage current. VRWM=5V 1 µA IPP Peak Pulse Current tP=8/20us 5 A VC Clamping Voltage IPP=1A, tP=8/20us IPP=5A, tP=8/20us 13 9.5 15 V CJ Junction Capacitance VR=0V,f=1MHz 8 15 pF 2/4 Min Typ Max Units 5.0 V 6.0 V ESD5451N TVS/ESD Protection Diode ELECTRICAL CHARACTERISTICS CURVE 3/4 ESD5451N TVS/ESD Protection Diode DFN1006 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions In Millimeters Minimum Maximum A 0.450 0.550 A1 0.000 0.050 b 0.45 0.55 C 0.12 0.18 D 0.950 1.050 e 0.65BSC E 0.550 0.650 L 0.200 0.300 L1 h 0.05REF 0.07 4/4 0.17
ESD5451N
物料型号为ESD5451N,是一款由KUU SEMICONDUCTOR生产的TVS/ESD保护二极管。
器件简介为设计用于为数据线、控制线或电源线提供静电放电(ESD)保护的电压抑制器。
引脚分配为单向保护二极管,具有一个阳极和一个阴极。
参数特性包括低电容(8pF)、低漏电流、低钳位电压,并且每个I/O引脚能够承受超过1000次±8kV接触放电的ESD冲击。
功能详解为提供高速数据线的瞬态保护,符合IEC 61000-4-2(ESD)、IEC 61000-4-4(EFT)等标准。
应用信息包括便携电子设备、桌面电脑、服务器、笔记本电脑、手机、MP3端口、数字端口、SIM卡等。
封装信息为DFN1006,材料符合RoHS且无卤素,包装为卷带,每卷10000片。
绝对最大额定值为峰值脉冲功率100W(8/20μs),工作温度范围为-55℃至+125℃,存储温度范围为-55℃至+150℃。
电气特性包括反向工作电压、反向击穿电压、反向漏电流、峰值脉冲电流、钳位电压和结电容等。
封装尺寸为DFN1006,具体尺寸数据以毫米为单位给出。
ESD5451N 价格&库存
很抱歉,暂时无法提供与“ESD5451N”相匹配的价格&库存,您可以联系我们找货
