PSM712-LF-T7
Asymmetrical TVS Diode
Features
150W peak pulse power(8/20µs)
Ultra low leakage:nA level
Operating voltage:7V or 12V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 7A (8/20µs)
RoHS Compliant
Applications
Mechanical Characteristics
Wireless System
Networks
Portable Instrumentation
RS485 Ports
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(8/20µs)
Ppk
150
W
Peak Pulse Current(8/20µs)
IPP
7
A
ESD per IEC 61000−4−2 (Air)
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
www.umw-ic.com
1
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
友台半导体有限公司
PSM712-LF-T7
Electrical Characteristics (TA=25°C unless otherwise specified)
Pin 1 to 3 and 2
to 3(12V TVS)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol Min
Typ
Max
VRWM
VBR
Reverse Leakage Current
IR
Clamping Voltage
VC
Clamping Voltage
Pin 3to 1 and 3
to 2(7V TVS)
Min
Typ
12
13.3
Max
7
Test Condition
V
V
7.5
I T = 1mA
0.5
µA
19
11
V
IPP = 1A (8 x 20µs pulse)
VC
25
15
V
IPP = 7A (8 x 20µs pulse)
Junction Capacitance
CJ
75
75
pF
VR=0, f=1MHz
CJ
pF
VR=VRWM, f=1MHz
www.umw-ic.com
0.5
Unit
0.01
45
0.01
45
2
VR = VRWM
友台半导体有限公司
PSM712-LF-T7
Typical Characteristics
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
10
15
30
10%
Time (ns)
tr = 0.7~1ns
30ns
60ns
t - Time ( s)
Fig3.
90%
Power Derating Curve
% of Rated Power
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature –TA (ºC)
www.umw-ic.com
3
友台半导体有限公司
PSM712-LF-T7
Outline Drawing - SOT23
X
Y
DIM
Z
C
G
Y
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
Marking
712
Ordering information
Order code
UMW PSM712-LF-T7
www.umw-ic.com
Package
Base qty
Delivery mode
SOT-23
3000
Tape and reel
4
友台半导体有限公司
很抱歉,暂时无法提供与“PSM712-LF-T7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24090
- 200+0.15510
- 1500+0.13530
- 3000+0.11990
- 国内价格
- 20+0.28977
- 200+0.22076
- 600+0.18242
- 3000+0.15304
- 9000+0.13317
- 21000+0.12237
- 国内价格 香港价格
- 3000+3.467203000+0.43437
- 6000+3.383436000+0.42387
- 9000+3.341489000+0.41862
- 15000+3.2950215000+0.41280
- 21000+3.2678421000+0.40939
- 国内价格 香港价格
- 1+7.451391+0.93350
- 10+5.3378610+0.66872
- 25+4.8104425+0.60265
- 100+4.22482100+0.52928
- 250+3.94536250+0.49427
- 500+3.77689500+0.47317
- 1000+3.638411000+0.45582
- 国内价格
- 5+0.17069
- 20+0.15554
- 100+0.14039
- 500+0.12524
- 1000+0.11817
- 2000+0.11312
- 国内价格
- 20+0.17980
- 200+0.16590
- 600+0.15220
- 3000+0.13830
