PESD1LIN
Product profile
General description
PESD1LIN in a very small SOD323 (SC-76) Surface-Mounted Device (SMD) plastic
package designed to protect one automotive Local Interconnect Network (LIN) bus
line from the damage caused by ElectroStatic Discharge (ESD) and other transients.
Features and benefits
ESD protection of one automotive LIN-bus line
Asymmetrical diode configuration ensures an optimized protection against
ElectroMagnetic Interferences (EMI) of a LIN Electronic Control Unit (ECU)
Max. peak pulse power: PPP = 160 W at tp = 8/20 s
Low clamping voltage: VCL = 40 V at IPP = 1 A
Ultra low leakage current: IRM < 1 nA
ESD protection of up to 23 kV
IEC 61000-4-2, level 4 (ESD)
IEC 61000-4-5 (surge); IPP = 3 A at tp = 8/20 s
AEC-Q101 qualified
Applications
LIN-bus protection
Automotive applications
Quick reference data
Table 1.
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
VRWM
reverse standoff voltage
Cd
Min
Typ
Max
Unit
PESD1LIN (15 V)
15
V
PESD1LIN (24 V)
24
V
13
17
pF
diode capacitance
Conditions
VR = 0 V;
f = 1 MHz
Pinning information
Table 2.
Pinning
Pin
Description
1
cathode 1 (15 V)
2
cathode 2 (24 V)
Simplified outline
1
2
Graphic symbol
1
2
006aab041
www.umw-ic.com
1
友台半导体有限公司
PESD1LIN
Limiting values
Table 3.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
peak pulse power
tp = 8/20 s
[1]
IPP
peak pulse current
tp = 8/20 s
[1]
Tj
junction temperature
Tamb
ambient temperature
Tstg
storage temperature
PPP
[1]
Min
Max
Unit
160
W
3
A
150
C
65
+150
C
65
+150
C
Non-repetitive current pulse 8/20 s exponential decay waveform according to IEC 61000-4-5.
Table 4.
ESD maximum ratings
Symbol
Parameter
VESD
Conditions
IEC 61000-4-2
(contact discharge)
electrostatic discharge
voltage
MIL-STD-883
(human body model)
[1]
[1]
Min
Max
Unit
23
kV
10
kV
Device stressed with ten non-repetitive ESD pulses.
Table 5.
ESD standards compliance
Standard
Conditions
IEC 61000-4-2; level 4 (ESD)
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
001aaa631
IPP
001aaa630
120
100 %
90 %
100 % IPP; 8 μs
IPP
80
e−t
50 % IPP; 20 μs
40
10 %
30 ns
40
t (μs)
Fig 1.
t
tr = 0.7 ns to 1 ns
60 ns
8/20 s pulse waveform according to
IEC 61000-4-5
www.umw-ic.com
Fig 2.
2
ESD pulse waveform according to
IEC 61000-4-2
友台半导体有限公司
PESD1LIN
Characteristics
Table 6.
Characteristics
Symbol
Parameter
VRWM
IRM
Conditions
Min
Typ
Max
Unit
PESD1LIN (15 V)
15
V
PESD1LIN (24 V)
24
V
reverse leakage current
VBR
PESD1LIN (15 V)
VRWM = 15 V
很抱歉,暂时无法提供与“PESD1LIN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24072
- 200+0.15606
- 1500+0.13464
- 3000+0.12036
- 国内价格
- 20+0.24851
- 200+0.19106
- 600+0.15920
- 3000+0.12820
- 9000+0.11157
- 21000+0.10260
- 国内价格
- 10+0.26226
- 100+0.20407
- 600+0.17503
- 1200+0.17240
- 3000+0.13978
