PESD15VL1BA
Features
320W peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
SOD-323
Mechanical Data
Applications
Microprocessor based equipment
SOD323 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
Absolute Maximum Rating
Rating
Symbol
Value
Units
PPP
320
W
Ipp
10
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
Peak Pulse Power ( tp =8/20μs)
Peak Pulse Current ( tp =8/20μs ) (note1)
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
友台半导体有限公司
PESD15VL1BA
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=15V,T=25℃
Clamping Voltage
VC
Junction Capacitance
Cj
Max
Units
15.0
V
16.7
V
IPP=10A,tp=8/20μs
VR = 0V, f = 1MHz
0.5
uA
32
V
pF
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
VC VBR VRWM
Maximum Reverse Leakage Current @ V RWM
Breakdown Voltage @ IT
IT
IR
IR
IT
VRWM VBR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD15VL1BA
Typical Characteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
320w8/20 μs waveform
1
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Percent
Ipp
80
80
Clamping Voltage–VC (V)
90
e-1
50
40
td=Ipp/
2
100
125
150
90
Waveform
Paramters
tr=8µs
td=20µs
100
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
Test
Waveform
Paramters
tr=8µs
td=20µs
70
60
50
40
30
10
15
Time (µs)
4
6
8
10
12
Peak Pulse Current–IPP (A)
www.umw-ic.com
3
友台半导体有限公司
PESD15VL1BA
Outline Drawing – SOD323
C
A
DIMENSIONS
SYMBOL
E
B
1
2
MILLIMETER
A
MAX
1.800
MIN
0.063
MAX
0.071
B
0.250
0.350
0.010
0.014
C
2.500
2.700
0.098
0.106
E
1.200
1.400
0.047
0.055
F
0.080
0.150
0.003
0.006
D
D
L
F
H
L
L1
INCHES
MIN
1.600
0.039
1.000
0.475 REF
0.019REF
L1
0.250
0.400
0.010
0.016
H
0.000
0.100
0.000
0.004
Marking
1
AE
2
Ordering information
Order code
UMW PESD15VL1BA
www.umw-ic.com
Package
SOD323
Base qty
3000
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD15VL1BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.57360
- 200+0.19080
- 1500+0.11952
- 3000+0.09480
- 国内价格
- 20+0.19386
- 200+0.14786
- 600+0.12237
- 3000+0.10703
- 9000+0.09386
- 21000+0.08662
- 国内价格
- 20+0.17770
- 300+0.13553
- 1200+0.11217
- 3000+0.09811
