PESD12VL1BA
Features
260W peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
SOD-323
Mechanical Data
Applications
Microprocessor based equipment
SOD323 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
260
W
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
友台半导体有限公司
PESD12VL1BA
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
Max
Units
12.0
V
VBR
IT=1mA
13.3
V
Reverse Leakage Current
IR
VRWM=12V,T=25℃
1
uA
Clamping Voltage
VC
IPP10A,tp=8/20μs
26
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
30
pF
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
Parameter
Working Peak Reverse Voltage
V
Maximum Reverse Leakage Current @ V RWM
Breakdown Voltage @ IT
Test Current
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD12VL1BA
Typical Characteristics
Figure 2: Power Derating Curve
10k
110
1000
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(W)
Figure 1: Peak Pulse Power vs. Pulse Time
260w 8/20μs waveform
100
10
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
90
Percent
Ipp
80
e-1
50
40
td=Ipp/2
150
Test
Waveform
Paramters
tr=8µs
td=20µs
40
Clamping Voltage–VC (V)
100
30
100
45
Waveform
Paramters
tr=8µs
td=20µs
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
35
30
25
10
5
10
www.umw-ic.com
10
15
Time (µs)
2
4
6
8
10
Peak Pulse Current–IPP (A)
3
友台半导体有限公司
PESD12VL1BA
Outline Drawing – SOD323
C
A
DIMENSIONS
SYMBOL
E
B
1
2
MILLIMETER
A
MIN
1.600
MAX
1.800
MIN
0.063
MAX
0.071
B
0.250
0.350
0.010
0.014
C
2.500
2.700
0.098
0.106
D
D
H
L
L1
0.039
1.000
E
1.200
1.400
0.047
0.055
F
0.080
0.150
0.003
0.006
L
F
INCHES
0.475 REF
0.019REF
L1
0.250
0.400
0.010
0.016
H
0.000
0.100
0.000
0.004
Marking
1
AD
2
Ordering information
Order code
UMW PESD12VL1BA
www.umw-ic.com
Package
SOD323
Base qty
3000
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD12VL1BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19484
- 200+0.14915
- 600+0.12377
- 3000+0.10854
- 9000+0.09537
- 21000+0.08824
- 国内价格
- 1+0.55990
- 200+0.18700
- 1500+0.11660
- 3000+0.09240
- 国内价格
- 20+0.11880
- 200+0.09720
- 600+0.07560
- 2000+0.05400
- 国内价格
- 5+0.25930
- 20+0.23760
- 100+0.21610
- 国内价格
- 20+0.17679
- 200+0.13534
