PESD24VL1BA
PESD24VL1BA
    UMW(友台)
    SOD-323
    VRWM=24V VBR(Min)=26.7V VC=50V IPP=6A Ppp=300W SOD323
PESD24VL1BA 数据手册
PESD24VL1BA Features ■ 300W peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 6A (8/20μs) SOD-323 Mechanical Data Applications ■ Microprocessor based equipment ■ SOD323 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 300 W Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 6 A VESD 30 30 kV Lead Soldering Temperature TL 260 ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) www.umw-ic.com 1 友台半导体有限公司 PESD24VL1BA Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=24V,T=25℃ Clamping Voltage VC IPP=6A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz Max Units 24.0 V 26.7 V 15 0.5 uA 50 V pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage VC VBR VRWM Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT IR IR IT VRWM VBR VC V Test Current IPP Note:. 8/20μs pulsewaveform. www.umw-ic.com 2 友台半导体有限公司 PESD24VL1BA Typical Characteristics Figure 2: Power Derating Curve 300w 8/20μs waveform 1 0.1 1 10 100 60 50 50 40 40 30 30 20 20 10 10 0 e-1 50 40 30 td=Ipp/ 2 20 0 0 25 2550 50 75 75 100 10 5 www.umw-ic.com 10 15 125 150 150 90 70 60 50 40 Test Test Waveform Waveform Paramters Paramters tr=8µs tr=8µs td=20µstd=20µs 30 20 10 0 0 100 125 Ambient Temperature - TA (℃) 80 Clamping Voltage–VC (V) 80 Ipp 70 60 90 Waveform Paramters tr=8µs td=20µs 90 Percent 80 70 Figure 4: Clamping Voltage vs.Ipp 100 60 90 80 aveform 110 70 90 0 1,000 td – Pulse Duration - µs Figure3:Pulse 110 100 Clamping Voltage–VC (V) 0.01 0.1 110 100 Percent of Rated Power for Ipp 10 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time Time (µs) 20 25 0 30 0 1 2 3 4 5 6 Peak Pulse Current–IPP (A) 3 友台半导体有限公司 PESD24VL1BA Outline Drawing – SOD323 DIMENSIONS SYMBOL MILLIMETER MIN MAX MIN MAX A 1.600 1.800 0.063 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D AF 1.000 0.106 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L 1 INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 2 Ordering information Order code UMW PESD24VL1BA www.umw-ic.com Package Base qty Delivery mode SOD323 3000 Tape and reel 4 友台半导体有限公司
PESD24VL1BA 价格&库存
很抱歉,暂时无法提供与“PESD24VL1BA”相匹配的价格&库存,您可以联系我们找货
PESD24VL1BA
    • 1+0.20290
    库存:910
    PESD24VL1BA
    • 1+0.41051
    • 200+0.13721
    • 1500+0.08567
    • 3000+0.06805
    库存:2687
    PESD24VL1BA
    • 1+0.11218
    • 100+0.10428
    • 300+0.09638
    • 500+0.08848
    • 2000+0.08453
    • 5000+0.08216
    库存:3000
    PESD24VL1BA
    • 1+0.14470
    • 100+0.13440
    • 300+0.12400
    • 500+0.11370
    • 3000+0.10330
    库存:3000
