PESD5V0L1BA
Features
550W peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 30A (8/20μs)
SOD-323
Mechanical Data
Applications
Microprocessor based equipment
SOD323 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
Absolute Maximum Rating
Rating
Symbol
Value
Units
PPP
550
W
Ipp
30
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
Peak Pulse Power ( tp =8/20μs)
Peak Pulse Current ( tp =8/20μs ) (note1)
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
友台半导体有限公司
PESD5V0L1BA
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
5.0
VRWM
Reverse Breakdown Voltage
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
Clamping Voltage
VC
IPP=30A,tp=8/20μs
Junction Capacitance
Cj
VR = 0V, f = 1MHz
V
6.0
V
1
uA
15
V
140
pF
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
VC V BR
Maximum Reverse Leakage Current @ V RWM
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD5V0L1BA
Typical Characteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
500w 8/20µs waveform
1
0.1
0.01
0.1
1
10
100
90
80
70
60
50
40
30
25
td – Pulse Duration - µs
Figure3: Pulse Waveform
110
125
150
Clamping Voltage–VC (V)
16
80
Ipp
100
18
Waveform
Paramters
tr=8µs
td=20µs
90
Percent
75
Figure 4: Clamping Voltage vs.Ipp
100
70
e-1
60
50
Ambient Temperature - TA (℃)
50
40
30
td=Ipp/2
12
10
8
Test
Waveform
Paramters
tr=8µs
td=20µs
6
4
2
10
10
15
Time (µs)
www.umw-ic.com
10
40
50
60
70
Peak Pulse Current–IPP (A)
3
友台半导体有限公司
PESD5V0L1BA
Outline Drawing – SOD323
C
A
DIMENSIONS
SYMBOL
E
B
1
2
MILLIMETER
A
MIN
1.600
MAX
1.800
MIN
0.063
MAX
0.071
B
0.250
0.350
0.010
0.014
C
2.500
2.700
0.098
0.106
D
D
H
L
L1
0.039
1.000
E
1.200
1.400
0.047
0.055
F
0.080
0.150
0.003
0.006
L
F
INCHES
0.475 REF
0.019REF
L1
0.250
0.400
0.010
0.016
H
0.000
0.100
0.000
0.004
Marking
1
AC
2
Ordering information
Order code
Package
Base qty
UMW PESD5V0L1BA
SOD323
3000
www.umw-ic.com
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD5V0L1BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11960
- 3000+0.09490
- 国内价格
- 20+0.17734
- 200+0.13533
- 600+0.11200
- 3000+0.09796
- 9000+0.08586
- 21000+0.07938
- 国内价格
- 5+0.25974
- 20+0.23696
- 100+0.21417
- 500+0.19139
- 1000+0.18076
- 2000+0.17316
- 国内价格
- 1+0.12530
- 3000+0.08980
