P6SMB6.8CA
P6SMB6.8CA
    UMW(友台)
    SMB(DO-214AA)
    SMB SMT 5.6V
P6SMB6.8CA 数据手册
UMW R UMW P6SMB Series FEATURES • • • • • • • • • • SMB(DO-214AA) Low profile package Ideal for automated placement Glass passivated chip junction Available in uni-directional and bi-directional 600 W peak pulse power capability with a 10/1000 μs waveform, repetitive rate (duty cycle): 0.01 % Excellent clamping capability Very fast response time Low incremental surge resistance Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C AEC-Q101 qualified available - Automotive ordering code: base P/NHE3 or P/NHM3 Cathode Band 0.086(2.20) 0.155(3.94) 0.077(1.95) 0.130(3.30) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.2) 0(0) MECHANICAL DATA 0.220(5.59) 0.205(5.21) Case: SMB (DO-214AA) Molding compound meets UL 94 V-0 flammability rating Base P/N-E3 - RoHS-compliant, commercial grade Base P/N-M3 - halogen-free, RoHS-compliant, commercial grade Base P/NHE3_X - RoHS-compliant and AEC-Q101 qualified Base P/NHM3_X - halogen-free, RoHS-compliant, and AEC-Q101 qualified (“_X” denotes revision code e.g. A, B, ..... and only available for 250 V to 540 V type) Terminals: matte tin plated leads, solderable per J-STD-002 and JESD 22-B102 E3, M3, HE3, and HM3 suffix meets JESD 201 class 2 whisker test Polarity: for uni-directional types the band denotes cathode end, no marking on bi-directional types Dimensions in inches and (millimeters) MAXIMUM RATINGS (TA = 25 °C unless otherwise noted) PARAMETER Peak power dissipation with a 10/1000 μs waveform (1)(2) (fig. 1) Maximum Instantaneous Forward Voltage at 50.0A for Unidirectional Only (Note 4) Power dissipation on infinite heatsink at TA = 50 °C Peak forward surge current 8.3 ms single half sine-wave uni-directional only (2) Operating junction and storage temperature range SYMBOL VALUE UNIT PPPM 600 W VF 3.5 Volts W PD 5.0 IFSM 100 A TJ, TSTG -65 to +150 °C Notes (1) Non-repetitive current pulse, per fig. 3 and derated above T = 25 °C per fig. 2 A (2) Mounted on 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pads to each terminal www.umw-ic.com 1 友台半导体有限公司 UMW R UMW P6SMB Series ELECTRICAL CHARACTERISTICS (TA = 25 °C unless otherwise noted) PART NUMBER P6SMB6.8A(CA) P6SMB7.5A(CA) P6SMB8.2A(CA) P6SMB9.1A(CA) P6SMB10A(CA) P6SMB11A(CA) P6SMB12A(CA) P6SMB13A(CA) P6SMB15A(CA) P6SMB16A(CA) P6SMB18A(CA) P6SMB20A(CA) P6SMB22A(CA) P6SMB24A(CA) P6SMB27A(CA) P6SMB30A(CA) P6SMB33A(CA) P6SMB36A(CA) P6SMB39A(CA) P6SMB43A(CA) P6SMB47A(CA) P6SMB51A(CA) P6SMB56A(CA) P6SMB62A(CA) P6SMB68A(CA) P6SMB75A(CA) P6SMB82A(CA) P6SMB91A(CA) P6SMB100A(CA) P6SMB110A(CA) P6SMB120A(CA) P6SMB130A(CA) P6SMB150A(CA) P6SMB160A(CA) P6SMB170A(CA) P6SMB180A(CA) P6SMB200A(CA) P6SMB220A(CA) P6SMB250A(CA) P6SMB300A(CA) P6SMB350A(CA) P6SMB400A(CA) P6SMB440A(CA) P6SMB480A(CA) P6SMB510A(CA) P6SMB540A(CA) DEVICE MARKING CODE UNI 6V8A 7V5A 8V2A 9V1A 10A 11A 12A 13A 15A 16A 18A 20A 22A 24A 27A 30A 33A 36A 39A 43A 47A 51A 56A 62A 68A 75A 82A 91A 100A 110A 120A 130A 150A 160A 170A 180A 200A 220A 250A 300A 350A 400A 440A 480A 510A 540A BI 6V8C 7V5C 8V2C 9V1C 10C 11C 12C 13C 15C 16C 18C 20C 22C 24C 27C 30C 33C 36C 39C 43C 47C 51C 56C 62C 68C 75C 82C 91C 100C 110C 120C 130C 150C 160C 170C 180C 200C 220C - BREAKDOWN VOLTAGE VBR AT IT (1) MIN. 6.45 7.13 7.79 8.65 9.5 10.5 11.4 12.4 14.3 15.2 17.1 19 20.9 22.8 25.7 28.5 31.4 34.2 37.1 40.9 44.7 48.5 53.2 58.9 64.6 71.3 77.9 86.5 95 105 114 124 143 152 162 171 190 209 237 285 333 380 418 456 485 513 MAX. 7.14 7.88 8.61 9.55 10.5 11.6 12.6 13.7 15.8 16.8 18.9 21 23.1 25.2 28.4 31.5 34.7 37.8 41 45.2 49.4 53.6 58.8 65.1 71.4 78.8 86.1 95.5 105 116 126 137 158 168 179 189 210 231 263 315 368 420 462 504 535 567 TEST CURRENT IT (mA) 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 MAXIMUM REVERSE STAND-OFF LEAKAGE VOLTAGE AT VWM VWM (V) ID (3) (μA) 5.8 1000 6.4 500 7.02 200 7.78 50 8.55 10 9.4 5 10.2 5 11.1 5 12.8 1 13.6 1 15.3 1 17.1 1 18.8 1 20.5 1 23.1 1 25.6 1 28.2 1 30.8 1 33.3 1 36.8 1 40.2 1 43.6 1 47.8 1 53 1 58.1 1 64.1 1 70.1 1 77.8 1 85.5 1 94 1 102 1 111 1 128 1 136 1 145 1 154 1 171 1 185 1 214 1 256 1 300 1 342 1 376 1 408 1 434 1 459 1 MAXIMUM PEAK PULSE CURRENT IPPM (2) (A) 57.1 53.1 49.6 44.8 41.4 38.5 35.9 33 28.3 26.7 23.8 21.7 19.6 18.1 16 14.5 13.1 12 11.1 10.1 9.3 8.6 7.8 7.1 6.5 5.8 5.3 4.8 4.4 3.9 3.6 3.4 2.9 2.7 2.6 2.4 2.2 1.8 1.74 1.45 1.24 1.1 1 0.91 0.86 0.81 MAXIMUM MAXIMUM CLAMPING TEMPERAT VOLTAGE URE AT IPPM OF VBR VC (V) (%/°C) 10.5 11.3 12.1 13.4 14.5 15.6 16.7 18.2 21.2 22.5 25.2 27.7 30.6 33.2 37.5 41.4 45.7 49.9 53.9 59.3 64.8 70.1 77 85 92 103 113 125 137 152 165 179 207 219 234 246 274 328 344 414 482 548 602 658 698 740 0.057 0.061 0.065 0.068 0.073 0.075 0.078 0.081 0.084 0.086 0.088 0.09 0.092 0.094 0.096 0.097 0.098 0.099 0.1 0.101 0.101 0.102 0.103 0.104 0.104 0.105 0.105 0.106 0.106 0.107 0.107 0.107 0.108 0.108 0.108 0.108 0.108 0.108 0.11 0.11 0.11 0.11 0.11 0.11 0.11 0.11 Notes (1) Pulse test: t ≤ 50 ms p (2) Surge current waveform per fig. 3 and derate per fig. 2 (3) For bi-directional types with V WM of 10 V and less, the ID limit is doubled (4) All terms and symbols are consistent with ANSI/IEEE CA62.35 (5) V = 3.5 V at I = 50 A (uni-directional only) F F www.umw-ic.com 2 友台半导体有限公司 R UMW UMW P6SMB Series RATINGS AND CHARACTERISTICS CURVES (TA = 25 °C unless otherwise noted) Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage, % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.1 µs 1.0 µs 10 µs 100 µs 1.0 ms 10 ms 50 25 0 0 25 50 75 100 125 150 175 200 TJ - Initial Temperature (°C) Fig. 1 - Peak Pulse Power Rating Curve Fig. 2 - Pulse Power or Current vs. Initial Junction Temperature 100 TJ = 25 °C Pulse Width (td) is defined as the Point where the Peak Current decays to 50 % of IPPM tr = 10 µs Peak Value IPPM 100 Transient Thermal Impedance (°C/W) IPPM - Peak Pulse Current, % IRSM 75 td - Pulse Width (s) 150 Half Value - IPP IPPM 2 50 10/1000 µs Waveform as defined by R.E.A. td 0 1.0 2.0 3.0 10 1.0 0.1 0.001 0 4.0 0.01 0.1 1 10 100 1000 t - Time (ms) tp - Pulse Duration (s) Fig. 3 - Pulse Waveform Fig. 5 - Typical Transient Thermal Impedance 200 6000 Measured at Zero Bias Peak Forward Surge Current (A) CJ - Junction Capacitance (pF) 100 1000 VR, Measured at Stand-Off Voltage VWM 100 Uni-Directional Bi-Directional TJ = 25 °C f = 1.0 MHz Vsig = 50 mVp-p 8.3 ms Single Half Sine-Wave Uni-Directional Only 100 10 10 1 10 100 200 1 100 10 VWM - Reverse Stand-Off Voltage (V) Number of Cycles at 60 Hz Fig. 4 - Typical Junction Capacitance Fig. 6 - Maximum Non-Repetitive Peak Forward Surge Current www.umw-ic.com 3 友台半导体有限公司 UMW R UMW P6SMB Series ORDERING INFORMATION Order Code Package Baseqty Deliverymode UMW P6SMBxxA SMB 750 Tape and reel UMW P6SMBxxCA SMB 750 Tape and reel www.umw-ic.com 4 友台半导体有限公司
