RCLAMP0522P.TCT
RCLAMP0522P.TCT
    UMW(友台)
    SLP1610P4
    TVS二极管 VRWM=5V VBR(Min)=6V VC=25V IPP=5A Ppk=150W SLP1610P4
RCLAMP0522P.TCT 数据手册
RCLAMP0522P.TCT Low Capacitance TVS Diode Array Features ■ Ultra Low Capacitance 0.5pF typical ■ Low operating Voltage: 5.0 V Low clamping voltage ■ Internal Structure Pin 1 IEC61000−4−4 (EFT) 40A (5/50ns) ■ IEC61000-4-5(Lightning)5A(5/50ns) Pin 2 ■ 3, 4 Applications ■ USB 2.0 ■ HDMI 1.3 ■ SATA and eSATA ■ DVI ■ IEEE 1394 ■ PCI Express ■ Portable Electronics ■ Notebooks 6 5 4 1 2 3 Pin Identification 1-2 Input Lines Mechanical Characteristics 5-6 Output Lines (No Internal Connection) JEDEC SLP1610P4 package ■  Molding compound flammability rating: UL 94V-0 3-4 Ground ■ Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 150 W Peak Pulse Current (8/20µs) IPP 5 A ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range www.umw-ic.com 1 ±25 kV ±20 TJ −55 to +125 °C Tstg −55 to +150 °C 友台半导体有限公司 RCLAMP0522P.TCT Low Capacitance TVS Diode Array Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Symbol Min Typ Max Unit 5.0 V Test Condition DP, DM, USB ID TVS Reverse Working Voltage Breakdown Voltage VRWM VBR 6.0 V IT = 1mA VRWM = 5.0V Reverse Leakage Current IR 0.5 µA Clamping Voltage VC 15 V Clamping Voltage VC 25 V Junction Capacitance CJ 1.0 pF www.umw-ic.com 0.5 2 IPP = 1A (8 x 20µs pulse), any I/O pin to ground IPP = 5A (8 x 20µs pulse), any I/O pin to ground VR = 0V, f = 1MHz, any I/O pin to ground 友台半导体有限公司 RCLAMP0522P.TCT Low Capacitance TVS Diode Array Typical Characteristics Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 30 10% Time (ns) tr = 0.7~1ns 30ns 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) www.umw-ic.com 3 友台半导体有限公司 RCLAMP0522P.TCT Low Capacitance TVS Diode Array Outline Drawing - SLP1610P4 A D B DIM E PIN 1 INDICATOR (LASER MARK) A SEATING PLANE aaa C A2 bbb b1xN bbb 1 .020 .023 .026 0.00 .001 .002 (.005) .006 .008 .010 .014 .016 .018 .059 .063 .067 .035 .039 .043 .020 BSC .039 BSC .012 .015 .017 4 .003 .004 0.50 0.58 0.65 0.00 0.03 0.05 (0.13) 0.15 0.20 0.25 0.35 0.40 0.45 1.50 1.60 1.70 0.90 1.00 1.10 0.50 BSC 1.00 BSC 0.30 0.38 0.43 4 0.08 0.10 C A1 bxN C A B A A1 A2 b b1 D E e e1 L N aaa bbb DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX 2 C A B R0.125 E/2 LxN 2X R0.075 3 PLACES N e e1 D/2 NOTES: Marking 0522P Ordering information Order code Package Base qty Delivery mode UMW RCLAMP0522P SLP1610P4 3000 Tape and reel www.umw-ic.com 4 友台半导体有限公司
RCLAMP0522P.TCT 价格&库存
很抱歉,暂时无法提供与“RCLAMP0522P.TCT”相匹配的价格&库存,您可以联系我们找货
RCLAMP0522P.TCT
  • 5+0.24047
  • 20+0.21887
  • 100+0.19727
  • 500+0.17568
  • 1000+0.16560
  • 2000+0.15840
库存:2801
