PESD5V0L5UY
PESD5V0L5UY
    UMW(友台)
    SOT363
    ESD保护 VRWM=5V VBR(Min)=6V VC=15V IPP=8A Ppp=60W SOT363
PESD5V0L5UY 数据手册
UMW PESD5V0L5UY Ultra Low Capacitance ESD Protection Array DESCRIPTION PESD5V0L5U is an ultra-low capacitance Transient Voltage Suppressor (TVS) designed to protection for high-speed data interfaces. With typical capacitance of 0.20pF (I/O to I/O) only, PESD5V0L5U is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4(±15KV air, ±8KV contact discharge), IEC61000-4-4 (electrical fast transient-EFT) (40A, 5/50ns),very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. PESD5V0L5U uses small SOT-363 package. Each PESD5V0L5U device can protect four highspeed data lines one Vcc line. The combined features of ultra-low capacitance, small size and high ESD robustness make PESD5V0L5U ideal for high-speed data ports and high-frequency lines (e.g., HDMI & DVI) applications. The low clamping voltage of the PESD5V0L5U guarantees a minimum stress on the protected IC. MACHANICAL DATA ■ ■ ■ ■ ■ ■ FEATURES ■ ■ ■ ■ ■ ■ ■ ■ APPLICATIONS Transient protection for high-speed data lines IEC 61000-4-2(ESD) ±25KV(Air) ±20KV(Contact) IEC 61000-4-4(EFT)40A(5/50ns) Cable Discharge Event(CDE) Package optimized for high-speed lines Small package(2.1mm*2.3mm*1.0mm) Protects four data lines and one Vcc line Low capacitance: 0.20pF (I/O to I/O) Low leakage current Low clamping voltage Each I/O pin can withstand over 1000 ESD strikes for ±8KV contact discharge www.umw-ic.com SOT-363 package Flammability Rating: UL 94V-0 Terminal: Matte tin plated. Packaging: Tape and Reel High temperature soldering guaranted:260℃/10s Reel size: 7 inch 1 ■ ■ ■ ■ ■ ■ Serial ATA MDDI Ports USB 2.0/3.0 Power and Data Line Protection Display Ports High Definition Multi-Media Interface (HDMI) Digital Visual Interface (DVI) 友台半导体有限公司 UMW PESD5V0L5UY Ultra Low Capacitance ESD Protection Array ABSOLUTE MAXIMUM RATING Symbol Parameter Value Units PPP Peak Pulse Power (8/20μs) 60 W VESD ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ±25 ±20 kV TOPT Operating Temperature -55/+125 C TSTG Storage Temperature -55/+150 C ELECTRICAL CHARACTERISTICS (Tamb=25C) Symbol Parameter Test Condition VRWM Reverse Working Voltage Any I/O pin to GND Reverse Breakdown Voltage IT = 1mA Any I/O pin to GND VRWM = 5V IR Reverse Leakage Current Any I/O pin to GND IPP = 1A, tp = 8/20μs Any I/O pin to GND IPP = 4A, tp = 8/20μs VC Clamping Voltage Any I/O pin to GND IPP = 8A, tp = 8/20μs Vcc pin to GND VR = 0V, f = 1MHz Between I/O and I/O VR = 0V, f = 1MHz CESD Parasitic Capacitance Between I/O and GND VR = 0V, f = 1MHz Between Vcc and GND Note: I/O Pins are pin 1,3,4,6. Pin 5 is Vcc. Pin 2 is GND. VBR www.umw-ic.com 2 Min Typ Max Units 5.0 V 9.0 V 1.0 μA 10 V 15 V 15 V 0.20 0.30 pF 0.45 0.50 pF 6.0 0.80 pF 友台半导体有限公司 UMW PESD5V0L5UY Ultra Low Capacitance ESD Protection Array ELECTRICAL CHARACTERISTICS CURVE www.umw-ic.com 3 友台半导体有限公司 UMW PESD5V0L5UY Ultra Low Capacitance ESD Protection Array SOT-363 PACKAGE OUTLINE DIMENSIONS Marking K4W Orderinginformat ion Order code UMW PESD5V0L5UY www.umw-ic.com Package Base qty SOT-363 3000 4 Delivery mode Tape and reel 友台半导体有限公司
PESD5V0L5UY 价格&库存
很抱歉,暂时无法提供与“PESD5V0L5UY”相匹配的价格&库存,您可以联系我们找货
PESD5V0L5UY
  • 1+0.11880
  • 100+0.11340
  • 300+0.10800
  • 1500+0.09720
库存:794
PESD5V0L5UY
  • 1+0.38808
  • 200+0.25074
  • 1500+0.21798
  • 3000+0.19278
库存:2643
PESD5V0L5UY
    • 1+0.39450
    库存:254
    PESD5V0L5UY
    • 10+0.34690
    • 100+0.27987
    • 600+0.24631
    • 1200+0.24262
    • 3000+0.20097
    库存:3088
