UMW
R
1.5SMC6.8A(CA) THRU 1.5SMC540A(CA)
6.8V-540V 1500W
FEATURES
• Low profile package with built-in strain relief for
surface mounted applications
• Glass passivated junction
• Low incremental surge resistance
• Low inductance
• Excellent clamping capability
• 1500W peak pulse power capability with a 10/1000µs
waveform, repetition rate (duty cycle): 0.01%
• Very fast response time
• Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
SMC(DO-214AB)
Cathode Band
0.155(3.94)
0.246(6.22)
0.130(3.30)
0.220(5.59)
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
MECHANICAL DATA
0.008(0.2)
0(0)
Case: JEDEC DO-214AB (SMC) molded plastic over
passivated junction
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026. High temperature soldering: 250°C/10
seconds at terminals.
Polarity: For uni-directional types the band denotes the
cathode, which is positive with respect to the anode
under normal TVS operation.
Standard Packaging: 16mm tape (EIA STD RS-481)
Weight: 0.007 oz., 0.21 g
Packaging Codes – Options (Antistatic):
51 – 1K per Bulk box, 10K/carton
57 – 850 per 7" plastic Reel (16mm tape), 8.5K/carton
9A – 3.5K per 13" plastic Reel (16mm tape), 35K/carton
0.320(8.13)
0.305(7.75)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Parameter
Symbol
Value
Unit
Peak power dissipation with a 10/1000µs waveform
PPPM
1500
W
Maximum Instantaneous Forward Voltage at
50.0A for Unidirectional Only
VF
3.5
Volts
Power dissipation on infinite heatsink, TA = 50°C
PM(AV)
6.5
W
Peak forward surge current 8.3ms single half sine-wave
uni-directional only (2)
IFSM
200
A
Thermal resistance junction to ambient air (3)
RθJA
75
°C/W
Thermal resistance junction to leads
RθJL
15
°C/W
TJ, TSTG
–65 to +150
°C
Operating junction and storage temperature range
Notes: (1) Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2
(2) Mounted on 0.31 x 0.31” (8.0 x 8.0mm) copper pads to each terminal
(3) Mounted on minimum recommended pad layout
www.umw-ic.com
1
友台半导体有限公司
UMW
R
6.8V-540V 1500W
Electrical Characteristics
UNI
BI
Breakdown Voltage
Test
Stand-off
Current Voltage
V(BR) at IT(1)
IT
VWM (V)
(V)
(mA)
MIN
MAX
1.5SMC6.8A(CA)
6V8A
6V8C
6.45
7.14
10
5.8
1000
143
10.5
0.057
1.5SMC7.5A(CA)
7V5A
7V5C
7.13
7.88
10
6.4
500
133
11.3
0.061
1.5SMC8.2A(CA)
8V2A
8V2C
7.79
8.61
10
7.02
200
124
12.1
0.065
1.5SMC9.1A(CA)
9V1A
9V1C
8.65
9.55
1
7.78
50
112
13.4
0.068
1.5SMC10A(CA)
10A
10C
9.5
10.5
1
8.55
10
103
14.5
0.073
1.5SMC11A(CA)
11A
11C
10.5
11.6
1
9.4
5
96.2
15.6
0.075
1.5SMC12A(CA)
12A
12C
11.4
12.6
1
10.2
5
89.8
16.7
0.078
1.5SMC13A(CA)
13A
13C
12.4
13.7
1
11.1
5
82.4
18.2
0.081
1.5SMC15A(CA)
15A
15C
14.3
15.8
1
12.8
1
70.8
21.2
0.084
1.5SMC16A(CA)
16A
16C
15.2
16.8
1
13.6
1
66.7
22.5
0.086
1.5SMC18A(CA)
18A
18C
17.1
18.9
1
15.3
1
59.5
25.2
0.089
1.5SMC20A(CA)
20A
20C
19
21
1
17.1
1
54.2
27.7
0.09
1.5SMC22A(CA)
22A
22C
20.9
23.1
1
18.8
1
49
30.6
0.092
1.5SMC24A(CA)
24A
24C
22.8
25.2
1
20.5
1
45.2
33.2
0.09
1.5SMC27A(CA)
27A
27C
25.7
28.4
1
23.1
1
40
37.5
0.096
1.5SMC30A(CA)
30A
30C
28.5
31.5
1
25.6
1
36.2
41.4
0.097
1.5SMC33A(CA)
33A
33C
31.4
34.7
1
28.2
1
32.8
45.7
0.098
1.5SMC36A(CA)
36A
36C
34.2
37.8
1
30.8
1
30.1
49.9
0.099
1.5SMC39A(CA)
39A
39C
37.1
41
1
33.3
1
27.8
53.9
0.1
1.5SMC43A(CA)
43A
43C
40.9
45.2
1
36.8
1
25.3
59.3
0.101
1.5SMC47A(CA)
47A
47C
44.7
49.4
1
40.2
1
23.1
64.8
0.101
1.5SMC51A(CA)
51A
51C
48.5
53.6
1
43.6
1
21.4
70.1
0.102
1.5SMC56A(CA)
56A
56C
53.2
58.8
1
47.8
1
19.5
77
0.103
1.5SMC62A(CA)
62A
62C
58.9
65.1
1
53
1
17.6
85
0.104
1.5SMC68A(CA)
68A
68C
64.6
71.4
1
58.1
1
16.3
92
0.104
1.5SMC75A(CA)
75A
75C
71.3
78.8
1
64.1
1
14.6
104
0.105
1.5SMC82A(CA)
82A
82C
77.9
86.1
1
70.1
1
13.3
113
0.105
1.5SMC91A(CA)
91A
91C
86.5
95.5
1
77.8
1
12
125
0.106
1.5SMC100A(CA)
100A
100C
95
105
1
85.5
1
10.9
137
0.106
1.5SMC110A(CA)
110A
110C
105
116
1
94
1
9.9
152
0.107
1.5SMC120A(CA)
120A
120C
114
126
1
102
1
9.1
165
0.107
1.5SMC130A(CA)
130A
130C
124
137
1
111
1
8.4
179
0.107
1.5SMC150A(CA)
150A
150C
143
158
1
128
1
7.2
207
0.106
1.5SMC160A(CA)
160A
160C
152
168
1
136
1
6.8
219
0.108
1.5SMC170A(CA)
170A
170C
162
179
1
145
1
6.4
234
0.108
1.5SMC180A(CA)
180A
180C
171
189
1
154
1
6.1
246
0.108
1.5SMC200A(CA)
200A
200C
190
210
1
171
1
5.5
274
0.108
1.5SMC220A(CA)
220A
220C
209
231
1
185
1
4.6
328
0.108
1.5SMC250A(CA)
250A
237
263
1
214
1
4.4
344
0.11
1.5SMC300A(CA)
300A
285
315
1
256
1
3.6
414
0.11
1.5SMC350A(CA)
350A
333
368
1
300
1
3.1
482
0.11
1.5SMC400A(CA)
400A
380
420
1
342
1
2.7
548
0.11
1.5SMC440A(CA)
440A
418
462
1
376
1
2.5
602
0.11
1.5SMC480A(CA)
480A
456
504
1
408
1
2.28
658
0.11
1.5SMC510A(CA)
510A
485
535
1
434
1
2.15
698
0.11
1.5SMC540A(CA)
540A
513
567
1
459
1
2.03
740
0.11
General
Semiconductor
Part Number
Device Marking
Code
Maximum
Reverse
Leakage at
(4)
VWM ID (µA)
Maximum Peak
Maximum
Maximum
Pulse Current
Clamping
Temp.
(2)
Voltage at IPPM Coefficient of
IPPM
(A)
VC (V)
V(BR) (% / °C)
Notes: (1) Pulse test: tp ≤ 50ms
(2) Surge current waveform per Fig. 3 and derate per Fig. 2
(3) All terms and symbols are consistent with ANSI/IEEE CA62.35
(4) For bidirectional types with VR 10 volts and less, the ID limit is doubled
www.umw-ic.com
2
友台半导体有限公司
UMW
R
6.8V-540V 1500W
Fig. 2 – Pulse Derating Curve
Fig. 1 – Peak Pulse Power Rating Curve
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage, %
PPPM — Peak Pulse Power (kW)
100
10
50
25
0.1µs
1.0µs
10µs
100µs
1.0ms
10ms
75
100
150
175
Fig. 3 – Pulse Waveform
Fig. 4 – Typical Junction Capacitance
Uni-Directional
20,000
TJ = 25°C
Pulse Width (td)
is defined as the point
where the peak current
decays to 50% of IPPM
Half Value — IPP
2
IPPM
50
10/1000µsec. Waveform
as defined by R.E.A.
1,000
VR, Measured at
Stand-Off
Voltage, VWM
100
Uni-Directional
Bi-Directional
TJ = 25°C
f = 1.0MHz
Vsig = 50mVp-p
td
1.0
2.0
200
Measured at
Zero Bias
10,000
CJ — Junction Capacitance (pF)
Peak Value
IPPM
100
125
TA — Ambient Temperature (°C)
tr = 10µsec.
4.0
1
10
100
400
VWM — Reverse Stand-Off Voltage (V)
t — Time (ms)
Fig. 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Use Only
Fig. 5 – Typical Transient Thermal
Impedance
100
200
Peak Forward Surge Current,
Amperes
Transient Thermal Impedance (°C/W)
25
td — Pulse Width (sec.)
150
IPPM — Peak Pulse Current, % IRSM
75
100
10
1.0
0.1
0.001
8.3ms Single Half Sine-Wave
(JEDEC Method)
TJ = TJ max.
10
0.01
0.1
1
10
100
1000
1
www.umw-ic.com
10
100
Number of Cycles at 60Hz
tp — Pulse Duration (sec)
3
友台半导体有限公司
UMW
R
6.8V-540V 1500W
ORDERING INFORMATION
Order Code
Package
Baseqty
Deliverymode
UMW 1.5SMCxxA
SMC
850
Tape and reel
UMW 1.5SMCxxCA
SMC
850
Tape and reel
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“1.5SMC6.8A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.64080
- 50+0.37800
- 850+0.34080
- 国内价格
- 5+0.67230
- 50+0.51419
- 150+0.43514
- 850+0.38686
- 2550+0.33945
- 5100+0.31569
