ESD0524P
ESD0524P
    UMW(友台)
    DFN2510-10
    ESD保护 VRWM=5V VBR(Min)=6V VC=15V IPP=4A Ppp=60W DFN2510
ESD0524P 数据手册
ESD0524P Ultra Low Capacitance ESD Protection Array DESCRIPTION ESD0524P is an ultra-low capacitance Transient Voltage Suppressor (TVS) designed to protection for high-speed data interfaces. With typical capacitance of 0.2pF (I/O to I/O) only, ESD0524P is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4(±15KV air, ±8KV contact discharge), IEC61000-4-4 (electrical fast transient-EFT) (40A, 5/50ns),very fast charged device model (CDM) ESD and cable discharge event(CDE), etc. ESD0524P uses ultra-small DFN2510 FEATURES ■ package. Each ESD0524P device can protect four high-speed data lines. The combined features of ultra-low capacitance, ultra-small size and high ESD robustness make ESD0524P ideal for high-speed data ports and high-frequency lines (e.g., HDMI &DVI) applications. The low clamping voltage of the ESD0524P guarantees a minimum stress on the protected IC. ■ ■ ■ ■ ■ ■ ■ ■ MACHANICAL DATA APPLICATIONS ■ ■ ■ ■ ■ ■ ■ ■ Serial ATA PCI Express Desktops, Servers and Notebooks MDDI Ports USB 2.0/3.0 Power and Data Line Protection Display Ports High Definition Multi-Media Interface (HDMI) Digital Visual Interface (DVI) www.umw-ic.com Transient protection for high-speed data lines IEC 61000-4-2(ESD) ±25KV(Air) ±20KV(Contact) IEC 61000-4-4(EFT)40A(5/50ns) Cable Discharge Event(CDE) Package optimized for high-speed lines Ultra-small package(2.5mm*1.0mm*0.5mm) Protects four data lines Low capacitance: 0.2pF (I/O to I/O) Low leakage current Low clamping voltage Each I/O pin can withstand over 1000 ESD strikes for ±8KV contact discharge ■ ■ ■ ■ ■ ■ 1 DFN2510 package Flammability Rating: UL 94V-0 Terminal: Matte tin plated. Packaging: Tape and Reel High temperature soldering guaranted:260℃/10s Reel size: 7 inch 友台半导体有限公司 ESD0524P Ultra Low Capacitance ESD Protection Array ABSOLUTE MAXIMUM RATING Symbol Parameter Value Units PPP Peak Pulse Power (8/20μs) 60 W VESD ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ±25 ±20 kV TOPT Operating Temperature -55/+125 C TSTG Storage Temperature -55/+150 C ELECTRICAL CHARACTERISTICS (Tamb=25C) Symbol Parameter Test Condition VRWM Reverse Working Voltage Any I/O pin to GND IT = 1mA Any I/O pin to GND VRWM = 5V IR Reverse Leakage Current Any I/O pin to GND IPP = 1A, tp = 8/20μs Clamping Voltage VC Any I/O pin to GND IPP = 4A, tp = 8/20μs VC Clamping Voltage Any I/O pin to GND VR = 0V, f = 1MHz Parasitic Capacitance CESD Between I/O and GND VR = 0V, f = 1MHz CESD Parasitic Capacitance Between I/O and I/O Note: I/O pins are pin 1,2,4,5, GND pins are pin 3,8. VBR Reverse Breakdown Voltage www.umw-ic.com 2 Min Typ Max Units 5.0 V 9.0 V 1.0 μA 10 V 15 V 0.4 0.5 pF 0.2 0.3 pF 6.0 友台半导体有限公司 ESD0524P Ultra Low Capacitance ESD Protection Array ELECTRICAL CHARACTERISTICS CURVE www.umw-ic.com 3 友台半导体有限公司 ESD0524P Ultra Low Capacitance ESD Protection Array DFN2510 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions (mm) Min. Nom. Max. D 2.45 2.50 2.55 E 0.95 1.00 1.05 b1 0.35 0.40 0.45 b2 0.20REF b 0.15 L 0.33 0.20 0.25 0.38 0.43 Nd 2.00BSC e 0.50BSC R 0.10 0.125 0.15 A 0.45 0.50 0.55 c A1 0.15REF 0.00 - 0.05 Marking Ordering information Order code UMW ESD0524P www.umw-ic.com Package Base qty Delivery mode DFN2510 3000 Tape and reel 4 友台半导体有限公司
ESD0524P 价格&库存
很抱歉,暂时无法提供与“ESD0524P”相匹配的价格&库存,您可以联系我们找货
ESD0524P
  • 10+0.26363
  • 100+0.21413
库存:44
ESD0524P
  • 5+0.39260
  • 20+0.36640
  • 100+0.34030
  • 500+0.31410
  • 1000+0.28790
  • 2000+0.26170
库存:44
ESD0524P
  • 1+0.62920
  • 200+0.21010
  • 1500+0.13090
  • 3000+0.10406
库存:6323
