PESD24VS2UT
Features
300 W peak pulse power (tp = 8/20μs)
Bidirectional and unidirectionalconfigurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 6A(8/20μs)
1
1
3
3
2
2
SOT-23 (Top View)
Applications
Mechanical Data
Dataline
Automatic Teller Machines
SOT-23 package
Molding compound flammability rating: UL 94V-0
Net works
Power line
Packaging: Tape and Reel
RoHS/WEEE Compliant
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
300
W
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
6
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
友台半导体有限公司
PESD24VS2UT
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
24
V
30.0
34.0
V
0.1
0.5
μA
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=24V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
6
A
Clamping Voltage
VC
IPP=6A,tp=8/20μs
44
V
Junction Capacitance
Cj
35
pF
Reverse Breakdown Voltage
26.7
VR = 0V, f = 1MHz
(Pin1、Pin2 to Pin 3)
30
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
VC VBR VRWM
Maximum Reverse Leakage Current @ V RWM
IR V F
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD24VS2UT
TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
300w 8/20 sµaveform
1
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
110
Waveform
Paramters
tr=8µs
td=20µs
90
80
Percent
100
e-1
50
40
td=Ipp/
2
35
30
25
Test
Waveform
Paramters
tr=8µs
td=20µs
15
10
10
15
150
40
5
45
Clamping Voltage–V C (V)
Ipp
100
60
75
Figure 4: Clamping Voltage vs.Ipp
Figure3: Pulse Waveform
70
50
Ambient Temperature - TA (℃)
Time (µs)
30
4
6
8
10
12
Peak Pulse Current–IPP (A)
Figure 5: Peak Pulse Power Vs Junction Temperature
1000
IRM(nA)
100
10
1
0.1
-75
-25
25
75
125
175
Tamb(℃)
www.umw-ic.com
3
友台半导体有限公司
PESD24VS2UT
Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
3
E1 E
θ
1
b
L
0.25
2
e
A1
INCHES
MIN
MAX
MIN
MAX
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A
A2
MILLIMETER
0.000
0.950 BSC
0.004
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
8○
Marking
Wu4
Ordering information
Order code
UMW PESD24VS2UT
www.umw-ic.com
Package
SOT-23
Base qty
3000
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD24VS2UT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.58520
- 200+0.19470
- 1500+0.12210
- 3000+0.09680
- 国内价格
- 20+0.21371
- 200+0.16167
- 600+0.13275
- 3000+0.11549
- 9000+0.10043
- 21000+0.09235
