PESD15VS2UT
Features
350 W peak pulse power (tp = 8/20μs)
Bidirectional and unidirectionalconfigurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 10A(8/20μs)
1
1
3
3
2
2
SOT-23 (Top View)
Applications
Mechanical Data
Dataline
SOT-23 package
Automatic Teller Machines
Molding compound flammability rating: UL 94V-0
Net works
Packaging: Tape and Reel
Power line
RoHS/WEEE Compliant
Absolute Maximum Rating
Rating
Symbol
Value
Peak Pulse Power ( tp =8/20μs )
PPP
350
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
Units
友台半导体有限公司
PESD15VS2UT
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
15
V
17.6
20.0
V
0.1
0.5
μA
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=15V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
10
A
Clamping Voltage
VC
IPP=10A,tp=8/20μs
35
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
(Pin1、Pin2 to Pin 3)
55
pF
Reverse Breakdown Voltage
16.7
50
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
VC VBR VRWM
Maximum Reverse Leakage Current @ V RWM
IR V F
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD15VS2UT
TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
350w 8/20 sµaveform
1
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Waveform
Paramters
tr=8µs
td=20µs
Ipp
90
Percent
100
125
150
80
45
40
Clamping Voltage–VC (V)
100
e-1
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
50
40
td=Ipp/
2
35
30
25
Test
Waveform
Paramters
tr=8µs
td=20µs
15
10
5
www.umw-ic.com
10
15
Time (µs)
30
4
6
8
10
12
Peak Pulse Current–IPP (A)
3
友台半导体有限公司
PESD15VS2UT
Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
3
E1 E
θ
1
b
0.25
L
2
e
A1
INCHES
MAX
MIN
MAX
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.000
0.035
0.004
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A
A2
MILLIMETER
MIN
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
8○
Marking
Wu3
Ordering information
Order code
UMW PESD15VS2UT
www.umw-ic.com
Package
SOT-23
Base qty
3000
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD15VS2UT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.49490
- 200+0.16564
- 1500+0.10302
- 3000+0.08181
- 国内价格
- 20+0.23814
- 200+0.18296
- 600+0.15228
- 3000+0.12032
- 9000+0.10433
- 21000+0.09569
- 国内价格
- 10+0.18745
- 100+0.18464
- 600+0.12049
