SD05.TCT
SD05.TCT
    UMW(友台)
    SOD-323
    TVS二极管 VRWM=5V VBR(Min)=6V VC=19V IPP=20A Ppp=360W SOD323
SD05.TCT 数据手册
SD05.TCT BI-directional TVS Diode Features ■ 360W peak pulse power (tp = 8/20μs) ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 20A (8/20μs) SOD-323 Mechanical Data Applications ■ USB Vbus, ■ SOD323 package ■ Power Line ■ Molding compound flammability rating: UL 94V-0 ■ Power management ■ Packaging: Tape and Reel ■ RoHS/WEEE Compliant Absolute Maximum Rating Rating Symbol Value Units 360 W Ipp 20 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ Peak Pulse Power ( tp =8/20μs) PPP Peak Pulse Current ( tp =8/20μs ) (note1) ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) www.umw-ic.com 1 友台半导体有限公司 SD05.TCT BI-directional TVS Diode Electrical Characteristics Parameter Reverse Stand-Off Voltage Symbol Conditions IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Clamping Voltage VC IPP=20A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz www.umw-ic.com Typical VRWM VBR Reverse Breakdown Voltage Min 2 Max Units 5.0 V 6.0 V 1 uA 17 19 V 120 135 pF 友台半导体有限公司 SD05.TCT BI-directional TVS Diode Typical Characteristics Figure 2: Power Derating Curve 110 10k Percent of Rated Power for Ipp P pp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 360w 8/20μs waveform 1000 100 10 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs Ipp 80 Percent 100 125 150 Test Waveform Paramters tr=8µs td=20µs 40 Clamping Voltage–VC (V) 90 e-1 50 40 td=Ipp/2 20 75 45 Waveform Paramters tr=8µs td=20µs 100 30 50 Figure 4: Clamping Voltage vs.Ipp 110 60 25 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 70 0 10 35 30 25 20 15 10 5 0 0 5 www.umw-ic.com 10 15 Time (µs) 20 25 0 30 5 10 15 25 Peak Pulse Current–IPP (A) 3 友台半导体有限公司 SD05.TCT BI-directional TVS Diode Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER A MAX 1.800 MIN 0.063 MAX 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 0.106 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 D D L F H L L1 INCHES MIN 1.600 1.000 0.475 REF 0.039 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 Marking 5U 1 2 Ordering information Order code Package Base qty Delivery mode SD05.TCT SOD-323 3000 Tape and reel www.umw-ic.com 4 友台半导体有限公司
SD05.TCT 价格&库存
很抱歉,暂时无法提供与“SD05.TCT”相匹配的价格&库存,您可以联系我们找货
SD05.TCT
  • 10+0.08781
库存:2898
SD05.TCT
    • 1+0.41910
    • 200+0.13970
    • 1500+0.08723
    • 3000+0.06941
    库存:1475
