ESD9N5V
ESD9N5V
1-Line, Uni-directional, Transient Voltage Suppressor
http//:www.sh-willsemi.com
Descriptions
The ESD9N5V is a uni-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components that may be subjected to ESD
(Electrostatic Discharge), EFT (Electrical Fast Transients)
and Lightning. It is particularly well-suited for cellular phones,
DFN1006-2L
portable device, digital cameras, power supplies and many
other portable applications because of its small package and
low weight.
The ESD9N5V may be used to provide ESD protection up to
Pin1
Pin2
±30kV (contact discharge) according to IEC61000-4-2, and
withstand peak pulse current up to 10 A (8/20μs) according to
IEC61000-4-5.
Circuit diagram
The ESD9N5V is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
*H
Features
Stand-off voltage: 5V Max.
Transient protection for each line according to
* = Date code (A~Z)
IEC61000-4-2 (ESD): ±30kV (contact discharge)
H = Device code
IEC61000-4-4 (EFT): 40A (5/50ns)
Marking (Top View)
IEC61000-4-5 (surge): 10A (8/20μs)
Capacitance: CJ = 60pF Typ.
Solid-state silicon technology
Order information
Device
Applications
Cell phone handsets and accessories
Personal Digital Assistants (PDAs)
Notebooks, Desktops, and Servers
Portable Instrumentation
Digital Cameras
Will Semiconductor Ltd.
ESD9N5V-2/TR
1
Package
Shipping
DFN1006-2L 10000/Tape&Reel
Revision 3.0, 2016/12/13
ESD9N5V
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
150
W
Peak pulse current (tp = 8/20μs)
IPP
10
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
±30
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
TSTG
kV
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA = 25oC, unless otherwise noted)
I
IPP
VF
Forward voltage
VRWM Reverse stand-off voltage
IF
Forward current
IR
Reverse leakage current
VFC
Forward clamping voltage
VBR
Reverse breakdown voltage
IPP
Peak pulse current
VCL
Clamping voltage
IPP
Peak pulse current
VFC
VF
IBR
IR
VRWM VBR VCL
V
IF
IPP
Definitions of electrical characteristics
2
ESD9N5V
o
Electrical characteristics (TA=25 C, unless otherwise noted)
Parameter
Symbol
VRWM
IR
Condition
Min.
Typ.
VRWM = 5V
VBR
IT = 1mA
6.0
Forward voltage
VF
IF = 10mA
0.4
0.8
Max.
Unit
5
V
1
μA
8.0
V
1.3
V
Clamping voltage
1)
VCL
IPP = 16A, tp = 100ns
11
V
Clamping voltage
2)
VCL
VESD = 8kV
11
V
Clamping voltage
3)
VC
Dynamic resistance
1)
Junction capacitance
Ipp=1A tp=8/20μs
10
V
Ipp=10A tp=8/20μs
15
V
RDYN
Ω
0.25
VR = 0V, f = 1MHz
60
80
pF
VR =5V, f = 1MHz
30
40
pF
CJ
Notes:
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to
16A.
2)
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
3
ESD9N5V
o
100
90
Front time: T1= 1.25 T = 8s
100
90
Current (%)
Time to half-value: T2= 20s
50
T2
10
10
T
tr = 0.7~1ns
Time (ns)
Contact discharge current waveform per IEC61000-4-2
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
8/20μs waveform per IEC61000-4-5
Pulse waveform: tp=8/20μs
11
t
60ns
30ns
Time (s)
T1
10
9
8
70
f = 1MHz
VAC = 50mV
65
60
55
50
45
40
35
30
25
7
2
3
4
5
6
7
8
9
Ipp - Peak pulse current (A)
2
3
4
5
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
100
1000
% of Rated power
Peak Pulse Power (W)
Peak pulse current (%)
Typical characteristics (TA=25 C, unless otherwise noted)
100
80
60
40
10
100
Pulse Time(s)
1000
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
4
ESD9N5V
o
10V/div
10V/div
20ns/div
20ns/div
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
Z0 = 50
TLP current (A)
tr = 2ns
16
tp = 100ns
12
8
4
4
6
8
10
12
14
TLP voltage (V)
TLP Measurement
5
ESD9N5V
Package outline dimensions
DFN1006-2L
b
CATHODE MARKING
(Ⅰ)
L
E
(Ⅱ)
(Ⅲ)
D
e
Top View
Bottom View
(Ⅰ)
A
(Ⅱ)
A3
A1
Side View
Symbol
Min.
Typ.
Max.
A
0.340
0. 530
A1
0.000
0.050
A3
Recommend land pattern (Unit: mm)
0.55
0.125 REF.
D
0.950
1.000
1.075
E
0.550
0.600
0.675
b
0.200
0.250
0.300
L
0.450
0.500
0.550
e
0.60
0.30
Dimensions In Millimeters
0.650 Typ.
Notes:
0.85
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
1.40
group to ensure your PCB design guidelines are met.
6
很抱歉,暂时无法提供与“ESD9N5V-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15969
- 1000+0.10514
- 4000+0.10409
- 10000+0.10201
- 国内价格
- 20+0.17421
- 200+0.13598
- 600+0.11470
- 2000+0.10196
- 国内价格
- 1+0.53240
- 500+0.17820
- 5000+0.11770
- 10000+0.09680
