2
3
16.10 [0.634]
XKB CONNECITITY
2.23 [0.088]
9*1=9.00 [0.354]
2.00 [0.079]
1.95 [0.077]
1.20 [0.047]
4.60 [0.181]
10.80 [0.425]
FLANGE
0.10
0.62 [0.025]
14.00 [0.551]
SPECIFICATIONS
1.OPERATINGCURRENT:0.5A MAX.
2.OPERATION TEMPERATURE:-25℃ TO +85℃
3.DIELECTRICWITHSTANDING VOLTAGE:
500Volts AC BETWEEN ADIACENT TERMINAL(UNMATE)
300Volts AC BETWEEN ADIACENT TERMINAL(MATE)
4.INSULATION RESISTANCE:
100Mohm MIN(UNMATED);10Mohm MIN.(MATED)
5.HDMISPECIFICATION COMPLIANCE
6.17 [0.243]
12.14 [0.478]
PICK UP AREA
Ø6.00 [0.236]
0.10 [0.004]
5.96 [0.235]
M3X0.5
2.70 [0.106](X2)
3.40 [0.134]
8*1=8.00 [0.315]
(LAND)
3.30 [0.130](X2)
Pin 2
(THROUGH HOLE)
0.90 [0.035](X4)
(THROUGH HOLE)
(LAND)
2.70 [0.106](X2)
0.50 [0.020]
1.50 [0.059](4X)
(LAND)
14.50 [0.571]
11.06 [0.436]
A71-05H3-1X1N1
0.90 [0.035]
Pin 18
XKB CONNECITITY
2.06 [0.081]
5.96 [0.235]
4.55 [0.179]
1
(THROUGH HOLE)
2.10 [0.083](X2)
Pin 19
DIM H=9.97 [0.393]
Pin 1
14.50 [0.571]
2.60 [0.103] 0.50 [0.020]PITCH
0.28 [0.011]
1:Au 1U"
5:Au 15U"
6:Au 30U"
PCB EDGE
14.50 [0.571]
RECOMMENDED PCB LAYOUT (THICKNESS=1.6±0.15mm)
RECOMMENDED P.C.B LAYOUT (T:1.20mm)
TOLERANCE UNSPECIFIED ±0.05mm
15.70 [0.618]
R0.30MAX.(X8)
COPPER ALLOY,GOLD PLATED OVER NICKEL
ON CONTACT AREA AND 100u" MIN.TIN
PLATED OVER NICKEL ON SOLDER TAILS
4.50 [0.177]
6.20 [0.244]
X
3
CONTACTS
19
2
HOUSING
1
THERMOPLASTIC UL94V-0
1
SHELL
1
COPPER ALLOY, NICKEL PLATED
1.20 [0.047]
1.00 [0.039]
0.20 [0.008]
10.80 [0.425]
0.50 [0.020]
0.1 X
13.25 [0.522]
0.1 X
REFERENCE PANEL CUT OUT DIMENSION
XKB CONNECITITY
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
很抱歉,暂时无法提供与“A71-05H3-111N1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.93665
- 10+0.90090
- 100+0.79365
- 500+0.77220
- 国内价格
- 1+3.99600
- 10+3.22920
- 30+2.85120
- 200+2.46240
- 400+2.23560
- 1000+2.12760
