1N4001W~1N4007W
Rev.D May.-2017
DATA SHEET
Descriptions
表面贴装整流二极管,反向电压:50V~1000V,正向电流:1.0A,薄型 SOD-123FL 封装。
Surface Mount General Purpose Silicon Rectifiers,Reverse Voltage:50 to1000V,Forward Current:
1.0A,SOD-123FL thin package.
特征
/ Features
玻璃钝化芯片,适用于自动放置,铅符合欧盟 RoHS 指令 2011/65/EU,适用于表面贴装。无卤产品。
Glass Passivated Chip Junction,Ideal for automated placement,Lead free in comply with EU RoHS
2011/65/EU directives,For surface mounted applications.Halogen free product.
用途
Applications
一般用途.
General purpose.
内部等效电路
/ Equivalent Circuit
引脚排列
/ Pinning
印章代码
/ Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
1N4001W~1N4007W
Rev.D May.-2017
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
1N4001W 1N4002W 1N4003W 1N4004W 1N4005W 1N4006W 1N4007W
单位
Unit
Maximum Recurrent
Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
Maximum DC Blocking
Voltage
Maximum Average
Forward Rectified
Current at Ta= 65℃
Peak Forward Surge
Current 8.3 ms Single
Half Sine Wave
Superimposed on Rated
Load (JEDEC Method)
Typical Junction
Capacitance 1)
Typical Thermal
Resistance2)
Operating and Storage
Temperature Range
IF(AV)
1.0
A
IFSM
30
A
Cj
9.0
pF
RθJA
120
℃/W
Tj,Tstg
-55~+150
Note:
1)Measured with IF=0.5A,IR=1A,Irr=0.25A.
2)P.C.B. mounted with0.2X0.2"(5X5mm) copper pad areas.
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current
at Maximum DC
Blocking Voltage
符号
Symbol
VF
测试条件
Test
Conditions
数值
Rating
单位
Unit
IF=1.0A
1.1
V
Ta=25℃
5.0
μA
Ta=125℃
50
μA
IR
2/7
1N4001W~1N4007W
Rev.D May.-2017
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/7
1N4001W~1N4007W
Rev.D May.-2017
外形尺寸图
DATA SHEET
/ Package Dimensions
4/7
1N4001W~1N4007W
Rev.D May.-2017
印章说明
DATA SHEET
5/7
1N4001W~1N4007W
Rev.D May.-2017
印章说明
DATA SHEET
A7
说明:
A7:
为型号代码
: 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
A7:
Product Type Code
****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No
Code
6/7
1N4001W~1N4007W
Rev.D May.-2017
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOD-123FL
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3000
8
24000
5
120000
7〞×11
185X180X105
390X385X205
/ Notices
7/7
很抱歉,暂时无法提供与“1N4007W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11440
- 200+0.03795
- 1500+0.02376
- 3000+0.01881
- 国内价格
- 50+0.06158
- 600+0.04821
- 1200+0.04749
- 3000+0.04019
