QUARTZ CRYSTAL
Professional manufacturer of quartz crystal
SMD Seam
Sealing Crystals
2.0 x 1.6 x 0.5 mm Series
Features
产品特点
.Extremely small SMD type crystal units.
.非常小的SMD型晶体单元。
.高精度、高频率稳定度。
.优良的耐热性和环境特征。
.在PDA,DSC,DVC,PC应用程序,等等。
.符合RoHS和无铅。
.High precision and high frequency stability.
.Excellent heat resistance and environmental characteristics.
.Applications in PDA, DSC, DVC, PC, etc.
.RoHS Compliant / Pb Free.
电气规格 Electrical Specifications
Item/Type
22
Description
频率范围
Frequency Range
调整频差
Frequency Tolerance (at 25)
± 10 ppm,± 20 ppm, or specify
温度频差
Frequency Stability Over Operating Temperature Range
温度范围
静态电容
Shunt Capacitance (C0)
16 ~ 54 MHz
-10 ~ +70℃
or specify
3 pF Max.
激励功率
Drive Level
1 ~200 μW (50 μW typical)
负载电容
Load Capacitance
8 pF, 10 pF, 12 pF, or specify
年老化率
Aging (at 25)
贮存温度
Storage Temperature Range
± 3 ppm / year Max.
- 40 ~ + 85 ℃
等效串联电阻(ESR) Equivalent Series Resistance(ESR)
Fundamental
16 ~ 19.2 MHz
200Max.
19.2 ~ 30 MHz
100Max.
30 ~ 54 MHz
80Max.
3rd Overtone
尺寸图 Dimensions
尺寸图 Dimensions
Units: mm
物料编码 Material code
L
2
1
SMD2.00 ×1.60
5
S
Sense Number
D-Divided M-Multify
TEL:0755-27383055
Frequencecy(KHz)
FAX:0755-27381355
Voltage
Frequency Tolerance
网址:www.lucki.com.cn
CL
ESR
很抱歉,暂时无法提供与“L214S160FH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.43500
- 100+0.40600
- 300+0.37700
- 500+0.34800
- 2000+0.33350
- 5000+0.32480
