LOPBS03579545S-MP4
LOPBS03579545S-MP4
    LUCKI(蓝晶芯微)
    HC-49S/SMD
    无源晶振 18pF 3.579545MHz 150Ω ±30ppm -40℃~+85℃ HC-49S/SMD
LOPBS03579545S-MP4 数据手册
QUARTZ CRYSTAL Professional manufacturer of quartz crystal Metal Can Type Crystals HC-49S Series Features 产品特点 .Surface mount type crystal units. .表面贴装型晶体单元。 .频点广泛。 .高频牵引率和低等效串联电阻。 .高质量的生产能力。 .PC,机顶盒,零件,和电缆调制解调器的最佳选择。 .符合RoHS和无铅。 .A great number of standard frequencies. .High frequency pullability and low equivalent series resistance. .Highly mass production capability. .The best choice of PC, STB, LCDM, and Cable Modem. .RoHS Compliant / Pb Free. 电气规格 Electrical Specifications Item/Type Description 频率范围 Frequency Range 调整频差 Frequency Tolerance (at 25) 温度频差 Frequency Stability Over Operating Temperature Range 温度范围 Operating Temperature Range 静态电容 Shunt Capacitance (C0) 激励功率 Drive Level 3.2 ~ 90 MHz ± 30 ppm, or specify ± 30 ppm, or specify - 20 ~ + 70 ℃, or specify 7 pF Max. 1 ~ 500 μW (100 μW typical) 负载电容 Load Capacitance 年老化率 Aging (at 25) 贮存温度 Storage Temperature Range Series, 16 pF, 20 pF, 30 pF, 32 pF, or specify ± 5 ppm / year Max. - 40 ~ + 85 ℃ 13 等效串联电阻(ESR) Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 3.2 ~ 3.686 MHz 200 Ω Max. 27 ~ 30 MHz 100 Ω Max. 3.686 ~ 5 MHz 150 Ω Max. 30 ~ 50 MHz 80 Ω Max. 5 ~ 10 MHz 80 Ω Max. 50 ~ 90 MHz 60 Ω Max. 10 ~ 14 MHz 40 Ω Max. 14 ~ 30 MHz 30 Ω Max. 尺寸图 Dimensions 尺寸图 Dimensions Units: mm 物料编码 Material code L 0 SMD11.4 ×4.35 P - B S Sense Number D-Divided M-Multify TEL:0755-27383055 Frequencecy(KHz) FAX:0755-27381355 Voltage Frequency Tolerance 网址:www.lucki.com.cn CL ESR
LOPBS03579545S-MP4 价格&库存
很抱歉,暂时无法提供与“LOPBS03579545S-MP4”相匹配的价格&库存,您可以联系我们找货
LOPBS03579545S-MP4
  • 1+1.45000
  • 30+1.40000
  • 100+1.30000
  • 500+1.20000
  • 1000+1.15000
