UM1B THRU UM10B
0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
Average Rectified Output Current - 0.8 A
High Surge Current Capability
3
Output Anode(+)
Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: UMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 45mg/0.0016oz
3
4
2
1
UMB Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
UM1B
UM2B
UM4B
UM6B
UM8B
UM10B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
at T c = 115 °C
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Forward Voltage per element
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@I F= 0.4A
@I F =0.8A
@ T a =25 °C
@ T a =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
IO
0.8
A
I FSM
25
A
VF
1.0
1.1
V
IR
3
30
μA
Cj
13
pF
RθJA
110
°C/W
T j , T stg
-55 ~ +150
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. P.C.B. mounted with 4×1.5"×1.5"(3.81×3.81 cm)copper pad areas.
2016.01
UMB-A-UM1B~UM10B-0.8A1KV
Page 1 of 3
UM1B THRU UM10B
Fig.2 Typical Reverse Characteristics
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
UM1B THRU UM10B
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
UMB
C
A
∠ALL ROUND
HE
VM
d
A
E
g
e
D
e
g
UMB mechanical data
A
C
D
E
HE
g
d
e
max
1.2
0.20
3.8
4.0
5.1
0.82
2.7
0.70
min
1.0
0.12
3.4
3.6
4.6
0.51
2.3
0.51
max
47
7.9
150
157
201
32
106
28
min
39
4.7
134
142
181
UNIT
mm
7°
mil
Marking
The recommended mounting pad size
2.5
100
1.0×1.4
39×55
4.3
170
2016.01
Unit: mm
(mil)
JD601094B2
Type number
Marking code
UM1B
UM1B
UM2B
UM2B
UM4B
UM4B
UM6B
UM6B
UM8B
UM8B
UM10B
UM10B
Page 3 of 3
很抱歉,暂时无法提供与“UM10B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.37510
- 500+0.12540
- 2500+0.08349
- 5000+0.06853
- 国内价格
- 20+0.16632
- 500+0.11197
- 2000+0.11085
- 5000+0.10863
- 国内价格
- 20+0.18144
- 200+0.14332
- 600+0.12215
- 国内价格
- 20+0.27960
- 100+0.16670
- 500+0.11670
- 5000+0.08340
- 10000+0.07920
- 50000+0.07340
